HID Should I turn them off during the day?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by limetime13, Feb 22, 2008.
  1. limetime13
    limetime13 Junior Member
    86
    Indianapolis
    I'm wondering if I need to readjust my "habit". My former cars had a system similar to the Prius - I could just leave the headlights on all the time and when the power was off, they were off.
    Well, with the addition of the HID headlamps, I'm wondering if I should still do this, tho it's a nice convenience - with the replacement cost of the bulbs (seem to be significantly more expensive).
    What are some opinions out there? Should I leave them on all the time or learn to turn them on and off. (Just to prove that you can indeed teach an old dog new tricks!)
    Limetime13
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Pick your priority.
    Yes, they'll burn out faster if you leave them on (particularly if most of your driving is in the day) and they are expensive to replace.
    But safety is important too.
    Also, they use a little energy and will have a slight impact on fuel economy.
    I leave mine off...YMMV.:hippie:
  3. sugar land dave
    137
    houston
    I think off is the winning move.
    YOMV - your opinion may vary....
  4. qbee42
    3,079
    Off. The safety studies for daytime headlamps have very mixed results. Not only are HID lamps expensive to replace, they also degrade over time, which means your lamps get dimmer and dimmer, long before they burn out, which is also a safety issue. I leave mine off during the day.
  5. NoMoShocks
    1,292
    83
    Camas, WA
    But please do use them at dusk and on heavily overcast days when most others have their on. It seems to me that on darker days with heavy overcast of 1/2 hour after sunset, a car with healights off sort of dissapears if it is in a line of cars with their headlights on.
    I have stoped using my HID during the day since I heard replacement bulbs run in the hundreds of dollars. Now I really want to rig my fog lights for DRLs.
  6. sparkyAZ
    sparkyAZ übergeek
    311
    Mesa, AZ
  7. Tideland Prius
    16,602
    It's really up to you.
    however, if it's sunny in the winter, please leave them on during the day. It helps others see you against the sun's low angle.
    I wish I could have them off in the summer and on in the winter (We have DRLs). Cause the headlight compound gets quite hot in the summer and combine that with the hot headlight (halogen) bulbs and it's a recipe for short bulb life.
  8. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    running them constantly really shortens their life.
  9. glavigne
    glavigne New Member
    Ontario
    Thats what sucks about the Canadian Prius you cant get the HID here as an option, i assume they arent recomended to run all the time, you are definatley safer with something on, i dont care what anybody tells you.
  10. NoMoShocks
    1,292
    83
    Camas, WA
    I really want some DRL of some type, and I have the HID option, so I was seriously considering the Fog light on only mod, but have read in the last couple days and confirmed that this is not permitted in the US. I may do it anyway, as I cannot for the life of me see how they would be worse on other drivers eyes during the day that lower powered high beams.
  11. georgekessel
    georgekessel Member
    182
    DRL's are ultra important - there are not really 'mixed results' other then some lobby groups.
    Every true real-world study has shown that DRL's reduce collision rates and head on accidents by 30%. Check the before and after in Canada or by GM on their stats they ran several years back when they switched over.
    Keep the lights on - it's safer - people can see you more.
    The nay sayers tried the same arguments in the 1970's when Motorcycles had to have their lights on all them time. In the end, science and statistics prevailed...
  12. Tideland Prius
    16,602
    Try the indicators. They're quite large and reasonably bright (not as bright as those GMs with DRLs sidemarkers but it could work if the foglights aren't allowed)
  13. georgekessel
    georgekessel Member
    182
    I use my HID's as DRL's. This is because fog lights are too low (on the vehicle) and actually use more power then the HID's according to this board.
    The dealer first programmed my side marker lights to be the DRL's but they were WAY too dim - couldn't see them during the day at all. If you could program the turn-indicators to be your DRL's that would probably work.
    Bottom line; please use DRL's and check for yourself on the stats. Car Manufacturers Lie, Stats don't....
  14. qbee42
    3,079
    Here is a link to get started with your reading: Daytime running lamp - Wikipedia, the free encyclopedia
    And a brief quote from above to stir things up:
  15. georgekessel
    georgekessel Member
    182
    Please don't quote Wiki as science. I could have put up that post yesterday on Wiki.....
    Best to quote true reliable sources such as the AAA, CAA or the IIHS - who all say the same thing...........
    Q&As: Daytime running lights
  16. georgekessel
    georgekessel Member
    182
    4 | How effective are DRLs?
    Nearly all published reports indicate DRLs reduce multiple-vehicle daytime crashes. Evidence about DRL effects on crashes comes from studies conducted in Scandinavia, Canada, and the United States. A study examining the effect of Norway's DRL law from 1980 to 1990 found a 10 percent decline in daytime multiple-vehicle crashes.1 A Danish study reported a 7 percent reduction in DRL-relevant crashes in the first 15 months after DRL use was required and a 37 percent decline in left-turn crashes.2 In a second study covering 2 years and 9 months of Denmark's law, there was a 6 percent reduction in daytime multiple-vehicle crashes and a 34 percent reduction in left-turn crashes.3 A 1994 Transport Canada study comparing 1990 model year vehicles with DRLs to 1989 vehicles without them found that DRLs reduced relevant daytime multiple-vehicle crashes by 11 percent.4
    In the United States, a 1985 Institute study determined that commercial fleet passenger vehicles modified to operate with DRLs were involved in 7 percent fewer daytime multiple-vehicle crashes than similar vehicles without DRLs.5 A small-scale fleet study conducted in the 1960s found an 18 percent lower daytime multiple-vehicle crash rate for DRL-equipped vehicles.6 Multiple-vehicle daytime crashes account for about half of all police-reported crashes in the United States. A 2002 Institute study reported a 3 percent decline in daytime multiple-vehicle crash risk in nine US states concurrent with the introduction of DRLs.7 Federal researchers, using data collected nationwide, concluded that there was a 5 percent decline in daytime, two-vehicle, opposite-direction crashes and a 12 percent decline in fatal crashes with pedestrians and bicyclists.8
  17. limetime13
    86
    Indianapolis
    Thanks for all the input. I went to the gym yesterday and when I was leaving, it was early dusk (tho dark enough that if I had seen me, I would have thought - why doesn't that idiot have their lights on??) Someone flashed their lights at me and my first thought was - I don't have my brights on. Second thought was - Holy Cow! I don't have my lights on at all! Needless to say - turned them on....
    Not 2 minutes down the road I saw an approaching Prius and, don't you know, they didn't have their lights on either! I flashed at them - hopefully they didn't just think I was saying "HI".
    This old dog is a slow learner - I'm still not sure what the outcome is going to be. ;)
    Limetime13
  18. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    This will obviously not be something that some of you will not agree with but, I see no difference in the number of people who try/tried to pull out in front of me when driving my '99 Saturn(has DRL's) than my Prius(doesn't have DRL's).:confused:
  19. georgekessel
    georgekessel Member
    182
    Living in Canada you get really used to DRL's. When a car is driving without them we know it's 90% probably someone who drove up from the USA.
    You notice the difference the DRL's really make. You know for sure that a car is on when you see their lights. You get so accustomed to them that the few times you see a car without them it's almost like a fear reflex.
    One thing I have noticed for sure is that it helps differentiate between cars that are driving and cars that are parked. Your concentration is shifted towards the cars with the headlights on and you 'ignore' the ones on the side of the road better.
    It's hard to explain, perhaps Tideland can do a better job.
  20. Tideland Prius
    16,602
    Well you've covered most if it. That fear reflex is also partly because it takes us a few seconds more to figure out if that car is parked or moving towards us with DRLs on (either because it's from the US or it's an older car).
    DRLs may not make a difference in Florida, but I can tell you they sure as hell make a difference up north in th winter. Again, it's because of the low zenith angle of the sun that creates glare. Those of you that haven't driven in the middle of winter when it's sunny won't understand. DRLs in that case really help cause you don't see the cars AT ALL, you just see the DRLs coming towards you.
