JBL amp hot even when not used
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Flying White Dutchman, Feb 24, 2008.
  1. Flying White Dutchman
    4,376
    313
    today i have driven 70km's and did not use the radio
    so it was OFF
    after the drive the jbl amp under need the front passenger seat was hot.
    it this normal? i shutoff the radio and the amp still waisted heat?
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    That's not normal. I know there were some issues with the 04 (and maybe 05) models that had to have the amp replaced as it was draining the 12v battery when the car was off. Have you been experiencing any 12v battery problems?
  3. Flying White Dutchman
    4,376
    313
    yes i do
    thats wy i asked
  4. richard schumacher
    7,664
    1,046
    United States
    Yes, you have a faulty JBL amp or a faulty installation. Search here for much discussion on how to fix this.
  5. Flying White Dutchman
    4,376
    313
    yes already searching
    but for now no topics on how to test it be unplugging the amp....
    there is a casing around it ii can not remove at this moment
  6. jammin012
    jammin012 The man behind The Man
    510
    Cali
    Maybe the amp is angry you're not using it enough.
  7. Flying White Dutchman
    4,376
    313
    here you can see a lot off info
    Prius JBL Audio system response, specs, and photos
    and that the amp is always on because it also provides beeps when pressing buttons on the MFD
    so thats why its hot
    thats normal
    i can test my battery drain problem when i disconnect the larger plug on the amp where the power line's are connected on
    (info also on that website )
