Wind Noise
Discussion in 'Gen 2 Prius Main Forum' started by omgitsroy326, Feb 25, 2008.
  1. omgitsroy326
    omgitsroy326 New Member
    267
    Los Angeles
    I'm getting a noise around my driver side mirror. Does anyone get this annoying noise at mid to high speeds?
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It may be caused by a missing screw under the mirror housing. If you see a hole there, it is probably the culprit. Just put a small piece of Scotch tape over it to see if it eliminates the noise.
  3. omgitsroy326
    267
    Los Angeles
    i'll give it a shot.. but my car is pretty new.. only 7k on it.. is this normal?
  4. Gilbert
    Gilbert Member
    255
    i have a 2008,and also have the same problem.. luckily this site exists and yes, thats the problem.. under the mirror you will see some screwholes with a thin plastic cover over them, some of mine are perforated and makes the wind noise at high speeds. just patch them up.
  5. CalvinL
    CalvinL 2025 Prius Plugin XSE Royal Green PPF
    100
    28
    Long Island, New York
    2025 Prius Plug-in
    XSE
    What!? *ugh* I didn't have such problems with my 2005 Prius... *sigh* I'm trading it in for a 2008... man - i gotta look out for some lousy screw holes?!
    what is this world coming too!?
  6. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I get some wind noise starting around 100 kmh. I usually just turn up the stereo, but the tape sounds like such a simple fix, I'll try it.
    Could it be the wind deflectors?
  7. omgitsroy326
    267
    Los Angeles
    the weird thing is that ... it just started happening 100 miles ago... it's annoying and assuming everything is symmetric..why isn't it happening on the other side.
  8. Gilbert
    Gilbert Member
    255
    mine didnt happen until some time after also, i notice it on my trip to vegas doing 99MPH with 99MGP :D (on a down grade)
    mine has both sides with the broken seals, absolutly no idea how they broke.
  9. thehabs
    thehabs New Member
    30
    Western Kentucky
    Mind did the same thing, coincidentally right after I had taken it through an automatic car wash. Several other posters have experienced this as well.
    Did you just wash your car recently?
  10. omgitsroy326
    267
    Los Angeles
    no... but doesn't rain count ??? hahaha....
  11. omgitsroy326
    267
    Los Angeles
    man.. now both sides are making noises.. i'm pretty disappointed... is there a TSIB for this?
  12. richard schumacher
    7,682
    1,063
    United States
    Are the screw holes indeed uncovered? If so apply clear tape.
  13. omgitsroy326
    267
    Los Angeles
    the tape is on there..
  14. Rest
    Rest Active Member
    1,210
    CA
    We have a 2006 and 2007 Prius. The 2007 has had wind noise on the drivers side. Lately the 2006 now had whistling wind noise on the drivers side. I have felt that the window seals are the cause. Well today we took the 2006 into the dealer and they said the gasket on the driver's side mirror was worn, so they replaced it under warranty. Surprisingly, no more whistling sounds. I am not exactly sure what they did, as I can't tell by looking at the mirror on the outside of it and I wasn't there to ask them. We shall see if this gets rid of all the wind noise as well. If so I get the 2007 taken care of then.
    Interestingly though, the 2006 doesn't have clear tape covering the bottom mirror screw holes, while the 2007 does.
  15. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
    Can anyone post a photo of the tape? My 2004 doesn't have anything covering the holes and I'd like to try to replicate it. Thanks in advance.
  16. Rest
    Rest Active Member
    1,210
    CA
    The tape over the bottom of the mirrors is clear cut in a circle to cover the screw hole.
  17. maseace
    191
    Poulsbo, WA
    So are there 3 pieces of tape on each mirror, one for each screw hole?
  18. Rest
    Rest Active Member
    1,210
    CA
    Yes. At least there is starting in the 2007 model year.
  19. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Actually, chewing gum works much better.
