2002 Prius Jumpstart - HORN?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kardinal, Feb 27, 2008.
  1. Kardinal
    Kardinal Junior Member
    Northern Virginia
    (I have searched for this problem, pretty extensively, and find no threads about it. Forgive me if I missed any.)
    My wife's 2002 Prius' battery was completely dead today (no lights, no locks, no response when ignitition was turned, literally nada), so I did a jumpstart according to the manual. I followed the instructions meticulously, though I did not detect anything different about the Prius method than any ohter.
    The instant that I connected the negative terminal to the trunk latch (recommended exposed metal ground), the horn on the Prius started going...constantly...and did not stop.
    I figured something was wrong, but I could find no infromation anywhere (except one question on Edmund's that was not answered with anything definitive or even specific) about this error. I plan to have it towed via USAA to the Toyota dealer tomorrow, but I figured I'd ask here in case it's a known problem.
    Thank you very much for any help you might provide.
  2. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    Could there be a short in the horn that caused your battery to die in the first place?
  3. Kardinal
    Northern Virginia
    Not a bad idea, but I'm pretty sure it was the map light left on, since one of the buttons for the forward right map light was depressed. <sigh> And I was the last driver.
    One speculation I heard was that perhaps this is the alarm going off? Is that normal?
  4. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    Absolutely. But I don't think the alarm has one long continuous horn sound.
  5. Reegman
    Reegman New Member
    Detroit
    Did you ever get an answer for this problem? I'm having the same problem with my 2004.
    Thanks, Craig
  6. Patrick Wong
    18,200
    6,493
    My guess is that your car has an aftermarket alarm installed. If so, then as soon as you hook up the 12V battery and hear the horn sound, do whatever is needed to deactivate the alarm (typically, by using the fob's unlock button.)
    If my guess is wrong, then simply disconnect the horns (both are located in front of the radiator) so that you can drive the car until you have a chance to take it in for service. You probably have to remove the black plastic cover over the radiator to gain access to the horns.
