Detailed maintenance instructions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cliffman, Feb 29, 2008.
  1. Cliffman
    Cliffman New Member
    Hollister, Ca
    I'm looking for detailed instructions on how to perform regular maintenance on my 05. Oil and filter, Air filter and so on. Can someone point me in the right direction please?
    Thanks in advance...
  2. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    John1701a has one of the best repositories of Prius info, including instructions (with good pics) for basic maintenance. PriusChat does too, of course, but it's scattered throughout thousands of threads, and sifting through search results can be a little tedious, so I suggest you start with John's site.
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    The Haynes Prius Repair Manual is now available on Amazon.com. It has 25 pages on routine maintanence.
  4. Cliffman
    Cliffman New Member
    Hollister, Ca
    Went to "John's" place and while his oil change and AC filter directions are great it would be nice if I could find everything in one place. for example there's no directions on the air filter replacement on John's web site.
  5. JimboK
    2,817
    188
    49
    Chesterfield, VA
    Yes there is. Check out page 29 of his User Guide for 2004-2008 models (downloadable in PDF or Word). It's linked from his home page, but here's a link to save you a little time. That and other common maintenance tasks are indeed grouped together in one section entitled "Maintenance."
  6. Cliffman
    Cliffman New Member
    Hollister, Ca
    You are absolutely correct. Guess I thought the year was incorrect for some reason. Thanks!
  7. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    Please don't use that direct link.
    It causes support/bandwidth problems for others. Sharing the document with as many as possible in a quick & reliable fashion depends on you downloading copy from the webpage instead.
