FE in the WInter
Discussion in 'Gen 2 Prius Fuel Economy' started by gazz, Mar 3, 2008.
  1. gazz
    gazz Member
    216
    Coventry, UK
    I have had my Prius from 12 months and have worked very hard on FE.
    After going through the winter and seeing my FE drop by over 10mpg I still struggle to understand the cause.
    I except wind and rain will have an effect but why on a cold dry still air day does it drop so much. I have tried blocking my grill and using an EBH with my heater off but I still cannot get any where near my summer mpg. All I can think is that either cold air must put a grater drag on the car, the tires never get warm so the pressure stays lower or the Prius uses more fuel with the cold intake air.
    Or is it just all the little bits added together,
    Any thoughts?
  2. bwilson4web
    16,182
    In January I had occasion to drive to South Carolina and back, ~800 miles 1,280 km total, to pickup a failed traction battery. The temperatures ranged from 15F to 39F (-9C to 4C) in low wind at my standard, 65 mph / 104 km, cruising speed. What I found was my highway mileage varied in direct proportion to the air density.
    In city driving, the EBH helps but the thermistor hack works even more effectively. However, you still have rolling drag increases from cold effects on tires and other parts. Still, once the vehicle is warmed up and running at speeds that there are minimal ICE thermal losses, you can achieve nearly 90% of the summer performance. But these are very narrow conditions involving driving for at least 30 minutes to warm-up the vehicle and then keeping the speeds high enough to avoid ICE thermal running.
    Does this help or do you have some specific questions?
  3. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    In a Nutshell:
    Extra fuel needed to keep the engine warm
    Short drives 10 miles or less
    Winter blend fuels can cause a 10% drop in mileage, even when everything is warmed up.
    "Repost"
    My observation @ 0 (f), no block heater, no grill blocking, 5,000 miles since the end of November.
    Driving less than 10 miles gets me about 25 mpg
    10-25 miles gets me about 35 average
    20-40 miles gets me about 40
    @ 20 (f) add about 4 mpg to the 0(f) figures
    @ 40 (f) add about 6 mpg to the 0(f) figures
    In a nut shell Winter sucks. Between the winter blend of fuel (good for a 10% loss) and the cold weather, mileage will suffer.
  4. richard schumacher
    7,664
    1,045
    United States
    You do need to keep the tire pressures up. Check them whenever the average outdoor temp changes more than about 10'C/20'F, or at least monthly.
  5. gazz
    gazz Member
    216
    Coventry, UK
    Thanks, I travel 16 miles each way to work and if I don't use the heater it gets up to running temp and will stay there, so I assume there is minimal loss from the ICE. During the first 5 mins I find there is a difference but not enough to account for the next 30 mins. What ever is dragging the FE down is happening during the whole 35 mins, Its as if the car just has to use more fuel as no matter what you do makes little difference in getting near the summer mpg.
    Have you looked at tire pressure in the winter, I run mine at 42/40 but do not change that in the winter, should I although the max pressure is only 44.
    I do appreciate all the other environmental difference but just not cold air when the car is fully warmed. In fact had a great drive last Friday, we had very strong winds and going north on the Motorway got 99mpg for mile after mile, I was being blown along, paid the price on the way back.
    Thanks
  6. gazz
    gazz Member
    216
    Coventry, UK
    But do you compensate for the lack of increase in pressure because the tire will never warm in the winter?
  7. qbee42
    3,079
    It does use more fuel in cold air. The previous posters have answered your questions, but since you are still doubting the answers, I'll put it in my words:
    1) Cold weather means more fuel to heat the engine and catalytic converter, regardless of whether you run the heater or not. Not running the heater helps, as would a block heater, but those things only lower the mileage hit, not eliminate it. The top priority for the Prius control system is to minimize emissions. To do this, it must keep the engine and emission system hot, and that's what it does.
    2) Winter fuels are blended with lower energy per unit, which means lower miles per gallon regardless of what you drive or how you drive it.
    3) Short trips are mileage killers. Cold startup involves warming the engine and emission system. You use this fuel whether you drive or sit still. Longer trips amortize this overhead over more miles, making for better mpg. In the winter, the cost of warming up is higher, so the mileage hit for a short trip is even greater.
    4) Cold weather means increased friction. The rolling resistance of tires goes up with cold, and so does the drag from bearings and other lubricated devices.
    5) Cold air is more dense than warm air. This contributes a small but finite amount of increased aerodynamic drag.
    6) Cabin heat means fuel burned to stay warm, or electricity for the electric heaters.
    7) Slush, rain, and snow increases rolling resistance.
    There might be a few more lower order effects, but that should be enough to give you the general idea.
  8. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Not using the heater may be your problem.
    Remember the traction battery was designed to operate most efficiently at a comfortable temperature. The ICE is working harder to make up for the loss of battery effeciency.
    Keep the cabin at a comfortable temperature and your MPG will go up.
  9. bwilson4web
    16,182
    Check your defroster controls. In North America the defroster engages the AC and this is a real MPG killer.
  10. gazz
    gazz Member
    216
    Coventry, UK
    I agree with all the above points, but most of them primarily affect the first 5 miles, even in 0-5C weather the engine eventually warms if you are careful with the heater, but FE is still down for the remainder of a journey, so my question is on a dry still day and the car is fully warmed (driven 10 miles say) from that point what is dragging down the FE, I can only think it is resistance of some sort or the engine just uses more fuel because the intake air is colder/denser.
  11. Doc Willie
    1,717
    144
    Out there, somewhere
    Temp here has gone from the 20s to the 40s in the past week. My milage with no change in driving habits has jumped from 47 to 50 MPH.
    Bring on Spring.
    Soon, please.
  12. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    The biggest thing that will kill your MPG is how bad do you want to stay warm while you drive. If you turn the climate control off and crack a window so that your windows don't fog, you will get near summer driving averages if your grill is blocked. But I'd rather have some heat.
  13. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    It is not true that these only (or primarily) affect only the first 5 miles. Remember: heat transfer is proportional to the temperature differential, so the engine cools faster when it's hot. You still have to "spend gas" to keep the engine (and catalytic converter) hot, particularly if you're driving around town.
    Several of Tom's (and other's) points extend beyond the first 5 miles:
    • Winter gas is Winter gas and it's always gong to affect you; the mileage hit you take from this is very noticeable.
    • Slush and rain affect you no matter what speed you're going (obviously not important on a dry day).
    • The cold weather is still going to increase friction and rolling resistance (although this will get somewhat better after the first 5 miles)
    • Of course, not using the heater will improve the mileage, but the engine still has to run more than it would on a warm day to keep the catalytic converter warm.
  14. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    I believe everything work better on higher temperature.
    Energy Citations Database (ECD) - Sponsored by OSTI
    In the "3.2.3 Hybrid Drive System Losses Tests" section of above material, we can see less system losses on higher temp.
    Anyway, attached graph is made by Japanese friend, and it shows higher temp is better for FE.
    (X axis:temp in Celsius, Y axis:FE in km/L)
    Ken@Japan
  15. gazz
    gazz Member
    216
    Coventry, UK
    OK I concede, I suppose I'm trying to hard to what is straight forward, its just that my wifes Mercedes is not hardly effected at all. But I suppose it generates that much waste it does not matter what the temp is.
    Did anybody have any thoughts on winter tire pressure being different from summer?
  16. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    What he said.
    For the past few months I've been averaging 36-37 mph (all short trips) with temps in the 20s and 30s fahrenheit. With my current tank I'm up to 40 mph and the only difference is slightly warmer temps -- lows still in the 30s but highs in the 40s-50s.
  17. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    that is not quite correct. what Tom said is pretty much dead on...
    you imply that after the "car" is warmed up, that will somehow lower the density of the cold air pushing on your Pri... not gonna happen...
    that implies that somehow, the cold air rushing in to cool your Pri will not have an effect because your Pri, like other gas engines, puts out enough heat to keep the engine warm.... not gonna happen. (i did an experiment with CANVIEW, monitoring engine temps every 30 seconds... engine temps dropped as much as 20º F simply by waiting for a red light to change. when your engine does not run all the time, it struggles to maintain temps in cold air!)
    so if your efficiency only drops 10% from summer to winter, you are pretty much doing it right. a smaller change in your efficiency means you are doing a stellar job!!
  18. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    **sorry cannot edit my post...added to above**
    best way to check it... monitor your local area for the change in formulation. around here, its occasionally announced in the paper... so watch for it.
    usually the temps will be about the same... see the diff from one tank to another. it will usually be 2-3 mpg...without changing temps, driving conditions, etc...
  19. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    I agree with your second two paragraphs. Cold air is cold air, and engine and catalytic converter (which is not helped by a blocked grill) need to stay warm. So in cold weather the engine will run more often and for longer times. As I pointed out in other threads, 30-50% change is not uncommon from summer to winter in the Chicago climate.
    But that first part - density of the air? Is that really happening? Barometric pressure only varies a small amount, but I suppose a gradual cooling wouldn't affect the pressure significantly (is it still the same amount of air or does air at the top fill in from the sides as the cold air sinks). Can we measure density directly? At any rate, you should be able to see the same effect every time a high or low pressure system rolls into town if that theory is correct, summer or winter. Folks in Denver should average better mileage than those in St. Louis, if other factors are equal. Any readers here from La Paz?
  20. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    barometric pressure is a general thing that takes pressure of a column of air... not density in general...
    we all know that nearly everything (with exception of water) expands as it warms right....using the STP (standard temperature pressure) formula, it clearly shows that density of any gas is temperature dependent.
