changing cabin filter -- I SWEAR, I checked several places already??
Discussion in 'Gen 2 Prius Main Forum' started by cyberprius, Mar 4, 2008.
  1. cyberprius
    cyberprius Mtn Bikes don't need foglights
    185
    oregon
    I've looked at John's Web site and have downloaded his great documents on how to change this air conditioning/cabin filter.
    But either:
    1) Toyota changed something for 2008.
    2) I am too weak.
    3) I am afraid to push too hard.
    So, can somebody reassure, or reinstruct me.
    I am following John's instructions here: John's Stuff - Toyota Prius Maintenance - Air-Conditioner Filter
    But, when I squeeze together the sides of the box at the very beginning, nothing comes free. Do I need to press REALLY hard?:eek:
  2. M. Oiseau
    M. Oiseau 6sigma this
    270
    Tulsa, OK
    Not too hard. Shine a light in on the sides and upper edge to get an idea of how far you're pushing to get past the "catch" or "detent" or "pokey outey thingy" and watch as you push in on each side. (The right side mounted damper is off its post already and the entire lower glove compartment just kind of hangs straight down, right?)
    I doubt you're too weak, likely you're afraid of breaking something, just like the rest of us.
    Edit: It doesn't hang straight down until after you squeeze the sides past the catch. Sorry, stupid me.
  3. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
  4. hill
    8,726
    I push hard, though maybe not all are as tough as mine. I aint no weenie. In my day I could bench press over 425lbs. Ah to be 20ish and stupid again. It's the same push strength as out Lexus cab filter box too. It does take a bit of inward oomph.
  5. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    Sometimes you just need to be slightly fearless and willing to use a little force... Persuade it!:boxing:
  6. darelldd
    6,059
    389
    Northern CA
    Man, how dirty can your filter be already in a 2008?? Where you driving, lady?
  7. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    feel free to wiggle it. i've pulled mine out several times so i'm familiar with it. mine was one to stick on the first several times.
    once you have it out, be careful. don't tap the white tray.. you can break the clips off rather easily. (bad experiance with an rx400h)
  8. cyberprius
    185
    oregon
    OK, thanks to all I got it off, I also managed to break off the "lifter arm thing." Maybe I can get that back on?
    Mee-ceess,,,,or Mice's or Mice or Mouses. However you spell it, they totally blocked the filter and they left behind a good amount of stuff that fell underneath the "fan thingy."
    In other words, there is a hinge-type foam covered "trap door sort of thing" down below the fan and there is a bunch of mice nest stuff there too, no mice that I can see. It's late, cold and dark, and I gave up for the night.
    I will tackle it in the daylight....Don't know how I will get that stuff out though.
  9. dogfriend
    7,512
    1,189
    Carmichael, CA
    Maybe you want to try this sober, in the daylight next time. :boink:
  10. cyberprius
    185
    oregon
    I had to drink the wine to get up the nerve to chase the mice....YUCK:(
  11. dogfriend
    7,512
    1,189
    Carmichael, CA
    Remember, you are bigger than they are. :yo:
  12. darelldd
    6,059
    389
    Northern CA
    The lower glove box dampener? That just pops off both ends. Unless you have *extra* pieces, it should just snap back on. Use the hole toward the middle of that dampener to attach to the dash, and the hole at the end of the arm slips over the post on the glove box.
    Or are we talking about something totally different?
    I need a drink.
  13. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Those stinky mice. They bring up other potential issues. If they were nesting in your car (i) they might come back and (ii) they have to eat and have been known to cause serious damage by chewing on engine compartment wire/cables.
    Regarding their possible unwanted return, I understand that there are spray-on products out there specifically to repel mice and rodents from your engine area. Relatedly, and this may be urban legend, I heard that mice and rodents particularly liked to chew on Hondas' and German cars' wires/cables. Something about the coating/covering Honda and German car manufacturers use to cover wires/cables. Haven't heard the same thing about Toyota. But that doesn't mean that Toyota's wires/cables are immune.
    Has anyone else heard about any of this, especially the spray-on rodent repellants? I don't have a mice problem. But I live and park squirrel central (seriously, I think there are more squirrels on the grounds of my NYC apartment complex than there are in the woods), and have heard stories of the squirrels eating out the wires and cables of Hondas and German cars parked here.
  14. cyberprius
    185
    oregon
    John calls it a damper. Anyway, I am here looking at it and hope someone can help me about how to reattach it. Luckily, it is in one piece:D
    But, I could see it going back on two ways. Either the thick barrel is up toward the dashboard, or the thick barrel is closer to the floor. Does that make sense. I guess if it was earlier, and I wasn't tired, and I had more wine, I could take a pix and post it....Anyway there are two holes on the solid barrel of the damper. So, do those holes go up toward the dash, or down toward the floor.
    Also, which hole do you attach to the car body...the one adjacent to the retractable arm or the one at the top of the barrel....Yes, I know, I now have everyone confused. :confused:
    Finally, I have not heard of Mice repellents for cars, but if they have them, let me know. I had oddles of problems in my Corolla, but it was much simpler to drop the glove box on it and reach into the fan and remove the mice and mice nest, than it is on the Prius.
  15. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Darell described exactly how to do it.
    Middle hole on the barrel (the one closest to the piston/retractable arm) goes on the dash pin/car body. The thinner/mobile part on the glove box.
  16. cyberprius
    185
    oregon
    You are right. He did, except, which end up....or am I being dense. Does the hole side face upward or does the barrel side...or is it obvious once I go out tommorrow. For the heck of it, I did just snap a pix.:rolleyes:
  17. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Where is hubby during all this? He needs to "man up" and come to your rescue.:D
  18. efusco
    19,891
    1,196
    Nixa, MO
    up/down...irrelevant...it pivots on the hole. Just snap on the barrel portion first. You'll have to close the glove box part ma bit and wiggle your fingers in to snap on the piston part (it's a little clumsy but doable). Then you push in the sides of the glove box to get the tabs past the edge of the glove box and it'll close right up.
  19. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    Mice and squirrels eat the wiring and harnesses in just about any automobile -- they don't seem to have a preference. The rodents (just referring to them as an animal class) start out making a nest because the car's interior and engine compartment are drier and warmer than outside. I've also seen squirrels use engine compartments as a nut warehouse for the same reason. Vehicles that sit idle for a long period of time are big targets. The gnawing happens not too long after the nest is built.
    Here is a link where other folks are discussing some solutions: AnandTech - Mice nesting in engine compartment
    Two solutions that seemed interesting were mothballs and Bounce dryer sheets. I would try the Bounce sheets first since putting mothballs next to your air filter might make the cabin smell like your grandmother's closet. One poster's suggestion of dousing the engine with gasoline and setting it on fire every other day would probably work but then we would have more posts on the "My Prius Spontaneously Combusted" thread.
    On the more comical side, my neighbor let his Ford F350 sit over the winter and squirrels made a nice nest in there. They snacked on the wiring insulation all winter and had a great party until spring. He found the squirrels and the babies that were born sometime during the process but couldn't get them out -- he didn't want to hurt them. I finally saw him go back inside and bring his cat out. He called his cat a de-squirelling tool and wasn't sure if Ford mechanics had anything like it in their toolboxes. The cat refused to go into the engine compartment (smart cat). He finally resorted to a garden hose with a nozzle on the end. We both felt sorry for the squirrels until he got the bill to replace all the wiring harnesses.
  20. patrickindallas
    patrickindallas Shire rat
    676
    36
    Vancouver, WA
    This entire thread needs to be printed and sold.
    Title: Changing Filter-thingie (using many super technical word like things)
    I don't have much to add though. I changed my cabin filter and don't recall any problems. But, then again, I don't think I had been drinking.
    Long live the Toyota electrical gas mix car type thingie!!!:grouphug:
    Thanks for the laugh; I needed it.
