What is this thingy?
Discussion in 'Gen 2 Prius Main Forum' started by baboonia, Mar 5, 2008.
  1. baboonia
    baboonia New Member
    25
    Berkeley, CA
    My friend has 2 Priuses. One 2004, one 2005.
    The 05 has this doodad in the trunk to the left rear of the drive battery. What is it for?
  2. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    for doodading
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    some sort of control unit for the HV battery...I forget the exact name/purpose.
  4. EJFB1029
    EJFB1029 New Member
    4,726
    206
    Corpus Christi, Republic of Texas
    If we told you, we would have to kill you. :eek:
  5. baboonia
    baboonia New Member
    25
    Berkeley, CA
    If for the HV battery, why is there not one in his 2004 Prius?
  6. Flying White Dutchman
    4,376
    313
    yes wy only in the 2005 model? or is there suppose to be one there to.
  7. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Hmm. My 2004 doesn't have one, at least not that I know of. Now I have doodad envy.
  8. baboonia
    baboonia New Member
    25
    Berkeley, CA
    Here's a bit more info.
    The 05 has smartkey, 04 does not.
    Maybe the doodad is related to smartkey?
  9. timcarlos
    timcarlos Junior Member
    My '04 with SKS has it.
  10. patsparks
    10,664
    569
    Adelaide South Australia
    I was about to say smartkey antenna but you look like you headed that way so I wont say it.
  11. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Oh, that could explain it. I just have a dumb key.
  12. M. Oiseau
    M. Oiseau 6sigma this
    270
    Tulsa, OK
    That's not the inertial kill switch? If not, what does IT look like?
  13. hill
    9,014
    I have one. It's the SUV owner ejection seat ECU
  14. GreenLady
    GreenLady Member
    163
    Denver, CO
    It's a tracking device so the UN can track your whereabouts and transmit the information to the aliens preparing to take over the world.
    /tinfoil hat
    :heh:
  15. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    But seriously folks! ;). I think its the service cut out for the main battery. It is mentioned somewhere in the users manual that the service cut out is to the left of the main battery.
    Marvin
  16. baboonia
    baboonia New Member
    25
    Berkeley, CA
    No, the service cut-out is an orange device. You slide the lever then lift the lever to remove the orange service cut-out (which contains a very large fuse)
  17. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    There's one in my 07.
  18. TheAnnoyingOne
    TheAnnoyingOne New Member
    318
    -118.15476, 34.112134
    It is a "Hummer" sensor - when that beast is nearby the Prius reduces its consumption and transmits the fact to the Hummer to make it jealous :boink:
  19. ceric
    ceric New Member
    1,114
    Fremont, CA
  20. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    I have one in my '04 with SKS. Never knew what it did.
