Why the low rolling-resistance?
Discussion in 'Gen 2 Prius Main Forum' started by jamarimutt, Dec 18, 2004.
  1. jamarimutt
    jamarimutt New Member
    985
    I have read many times that the standard tires are of the low rolling resistance type, but what exactly gives them that low rolling resistance quality? Just the fact that they can be inflated to a higer pressure or is there someting else?
  2. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
  3. daniel
    14,487
    1,519
    Spokane, WA
    Note, however, that that page refers to the 2001-2003 Prius. All references on that page to the OEM tires refer to the tire that came with the Classic Prius. The '04/'05 Prius comes with a much better tire (though still not as good as many that are available).
    The general info about tires on that page is good. But all references to the original tires are obsolete if you are driving a new Prius.
  4. jamarimutt
    985
    The information in John's page is intereresting but does not answer the basic question: What gives a low rolling-resistance tire it's low rolling-resistance properties?
  5. TonyPSchaefer
    14,816
    2,501
    66
    <div class='quotetop'>QUOTE(daniel\";p=\"58567)</div>
    Ah crap. I just figured that John had something and when I came across that page, I posted it. Sorry. :-(
  6. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    <div class='quotetop'>QUOTE(jamarimutt\";p=\"58612)</div>
    One property would be stiff sidewalls. A tire with flexible sidewalls (or an underinflated tire) will deform its sidewalls as it rolls. It takes energy to flex the sidewall as the tire rolls, so a car on tires with stiff sidewalls takes less energy to push down the road. One way to give a tire stiff sidewalls is to design it for higher inflation pressures. My guess is that stiffer sidewalls is the major contributor to low rolling resistance.
    Tire compound probably has a slight effect. Since car suspensions are designed with a degree or two of toe-in, the tires are really scrubbing all the time. A harder compound is going to have less friction as it scrubs across the pavement, so it should roll easier.
  7. daniel
    14,487
    1,519
    Spokane, WA
    And yet the Potenzas on the Classic Prius were notorious for wearing out fast.
  8. grantiehill
    grantiehill New Member
    I just picked up my 2005 with p185/65 R15 Goodyear Integrity tires. My tire dealer says those are not "LRR" tires. He was unable to find LRR tires in that size on any of his lists. Seems strange the car would not come with LRR tires. I've read the MPG tests are done with LRR & that's why the dealer has to supply them. Any comments? My owners manual says 35 PSI front/33 rear. The dealer had 40psi for all. Should I run with the higher pressure or will it wear out the tires in the middle prematurely?
  9. jamarimutt
    985
    I thought that the factory tires are LRR; can someone confirm if they are or not? Does the tire carry some code to indicate that they are LRR?
  10. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    The 04/05 OEM tires are not formally "LRR".
    For some reason, manufacturers are very averse to handing out any information about the actual relative rolling resistance of their tires. Some folks have gone so far as writing the manufacturers with no joy.
    There was a Green publication that did some research/testing but it's out of date, so I don't know of any reliable way to find out the RR of any given tire.
  11. ceric
    ceric New Member
    1,114
    Fremont, CA
    Goodyear Integrity
    Unfortunately, our Prii come with poor tires like the Goodyear Integrity. Read the review here.
    http://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes
    Especially read the "reviews" from owners of various models from Ford and Toyota. The major complaint seems to be with hydroplanning. Drive slowly in rain, people.
    For more on tires of LRR, you may try this good article.
    http://www.hybridcars.com/tires.html
    It says that Toyota no longer use LRR tires due to customers' complaint.
  12. grantiehill
    Thank you Ceric,
    Good info on tires and driving, especially specific tires to look for.
    Rick
