Back Window Wiper Question
Discussion in 'Gen 2 Prius Main Forum' started by cyberprius, Mar 9, 2008.
  1. cyberprius
    cyberprius Mtn Bikes don't need foglights
    185
    oregon
    Just a quick question. Washed the car for the first time and found that Back Windshield Wiper hardly moves much off the window, making it a bit, just a bit, difficult to wash around it.
    I assume this is "normal," but just wanted to check??
  2. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Just lift it up.
    Photos of how to remove the locking clip are shown in this document.
  3. Pinan
    Pinan Member
    173
    Murrieta, CA
    Normal yes. Pain in the butt, also yes.
    You can actually mod the cover so that the wiper will lift all the way up. The directions (very easy) are on evnut.com
    Here you go: Prius Wiper
  4. Pinan
    Pinan Member
    173
    Murrieta, CA
    Well....now you have two views on it, LOL! John beat me to it.
  5. paulccullen
    paulccullen New Member
    276
    Seattle, WA
    The Prius has some brilliant design features, but then there's this (the rear wiper) and that inane reverse beep.
    Makes me think that a complete moron found his/her way onto the otherwise highly innovative Prius design team.
    Then there's the fact that the Prius will still run (and not even protest much) if you walk away with the key. That one's not just stupid, it's downright dangerous! :confused: :confused:
    Yeah, I know, the reverse-beep and key-less running have been discussed ad nauseum in previous threads.
    John and Pinan: Thanks for the wiper info...
  6. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    For a while, I didn't want to do the mod since it requires the removal of the part. What I did instead was to simply remove the black cover whenever I wanted to list the wiper all the way up. I found that the need presented itself only a few times but in the end, I just went ahead and modified the part.
  7. qbee42
    3,079
    I don't wash that well. Sometimes it pays to be a slob. :rolleyes:
  8. patsparks
    10,664
    567
    Adelaide South Australia
    I think if you ever use a car wash it is best to leave the cover unmodified. I believe the reason it won't lift off the rear screen is to prevent it lifting in a automatic car was and being torn off by the brushes.
    I use a micro-fibre mitt to wash my car, I can just get my fingers under the wiper to wash that line away then I put the chamois around my fingers to dry the window under the wiper and it dries the wiper blade at the same time.
    PS. I never use an automatic car was but my wife may or I may if on a trip, so I leave the cover unmodified.
  9. Pinan
    Pinan Member
    173
    Murrieta, CA
    I wondered about the aerodynamics of it all. If you were going xxx speed and you met a xxx speed head-wind, could the wiper then be lifted and perhaps torn off. Still.....I modded mine.
  10. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    It's fairly simple to remove the stopper and replace it so I will probably not modify it.
  11. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    I did the snipping mod nearly four years ago with zero problems. the wiper arm stays put, no problems in the car wash or otherwise. Cut away that plastic.
  12. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I haven't bothered modifying the wiper cover on mine, since it only take a second or two to pop it off and on again when I want to clean the windows properly. Given how easy this is to do and how infrequently I need to lift the wiper, I don't feel the mod is worth the time. IMHO. ;)
  13. hill
    8,827
    Darell's got a nice pic of the mod.
    Go to EVNUT.com then check the Prius pages, then the mod pages. Basically it's just a matter of snapping off a tab. here's his pic:
    Simple !
  14. tedroberts
    tedroberts Junior Member
    22
    Edina, Minnesota
    I found it easiest to just remove the rear wiper, greatly improving rear vision, ease of cleaning the back window and aerodynamics. I never used the wiper during the first two years I owned the prius.
  15. Pinan
    Pinan Member
    173
    Murrieta, CA
    That was posted on the 1st page. ;)
  16. hill
    8,827
    eeek, I hate it when I do that :confused:
  17. ebsmythe
    ebsmythe Junior Member
    45
    Port Perry, Ontario
    We have 2 2007 Prii and have done the mod to th rear wipers on both cars.
    We have had many automatic car washes with no problem. The spring load keeps the wiper hard against the rear window.
    Just out of curiosity, has anyone had a car wash lift the rear wiper and wreck things?
  18. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    While I haven't heard of any problem with the rear wiper, I HAVE heard of problems with the antenna going through car washes... So that would be probably one of the things I'd remove before I go in there.
