power loss "big hand syndrome" can not be fixed
Discussion in 'Gen 2 Prius Main Forum' started by av_in_bc, Dec 22, 2004.
  1. av_in_bc
    av_in_bc New Member
    just had my accelerator pedal assembly replaced (800.00$)
    didn't even make it through the day and am already the power loss problem again.
    1- what else could be wrong
    2- was there nothing wrong with the acc. pedal
    3- is this a lemon??? (used purchased, 20000km no problems)
    4- all these problem started after i lost my key and had to
    have a new transponder installed (and they also killed
    my car battery). could this be related
    (this is the same post as on priusonline, sorry for the duplication)
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Re: power loss "big hand syndrome" can not be fixe
    if it's still doing it I'd take it back to the dealer and complain that their diagnosis was incorrect and you want a refund on a very expensive part that didn't solve your problem. Get them to check it again and provide you with a reasonable explanation why the repair was unsuccessful.
  3. av_in_bc
    av_in_bc New Member
    yes, i have done that and they have been very understanding but i'm still worried that this problem will not go away. the engine completlely shut down last friday and the car was unusable until they cleared the error code from the computer.
  4. DaveG
    DaveG Member
    806
    Vancouver, BC
    Perhaps they messed-up one of the ECUs when they managed to kill the battery and replace the transponder?
    Have you tried taking it to a different dealership and getting them to look at it?
    Did they tell you what the error code was? That should give them a whole bunch of info on what's wrong.
    N.
