Will Dealer Honor Oil Changes Done by Myself?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Aaron, Mar 13, 2008.
  1. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Getting ready to purchase a 2008. I have always done my own oil changes and would like to continue this tradition.
    Questions:
    Will dealerships honor the warranty if I do my own oil changes?
    How do I show proof?
    Do I still need to come into the dealer for my service intervals?
    If I do change my own oil, will the Toyota Service be cheaper since they don't have to do it?
    Finally....which oil? 5w-30, 0w-20, or 0w-30
  2. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    You may do your own oil changes with no effect on your warranty, but you should save the receipts for your oil and filters. you may have an independent shop do these changes as well. Save all receipts. Any dealer that tells you this must be done in his service department is lying.
    Use the oil specified in the manual.
  3. Aaron
    Aaron Member
    260
    Monroe, Ohio
    What if I decide to use Mobil 1 "15,000" oil and change it every 15K and not 5K? Do you think I'll have a problem with this from the dealer?
  4. tochatihu
    tochatihu Senior Member
    9,744
    3,761
    Kunming Yunnan China
    2001 Prius
    Aaron, for the US Prius is specified 5W30 engine oil. In other markets, other grades are also approved, inlcuding the thinner oils you mentioned. Your local climate should influence your decision.
    Other Prius are being driven with synthetic oil for 15k miles or longer. Used engine oil analysis (UOA) typically shows the total base number to be quite depleted after 10 or 12k, but all of its other characteristics remain good. I suggest that anyone running extended oil intervals consider UOA. If unwilling to pay the $20-30, then limit yourself to 10k. OK?
  5. jdenenberg
    jdenenberg EE Professor
    3,941
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Yes, you will have voided the warranty if an engine failure can be blamed on lubrication. Stick with 5,000 mile changes (I still use synthetic oil) for at least the first 60,000 miles (or 5 years), then you can do whatever you want.
    I'm at 110,000 in my 2004 Prius and it deserves good oil. I still change it every 5,000 miles myself.
    JeffD
  6. galaxee
    galaxee mostly benevolent
    9,810
    470
    MD
    write the VIN, date and mileage on your receipt for the oil and filter.
    if you should have an oil-related failure, the 15k mile oil changes will exclude you from warranty coverage for that instance. toyota requires 5k oil changes across the board to cover you under warranty.
    knowing that, it's always your choice how you treat your car.
  7. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Thanks all.
    Looks like the safe way to go is every 5K with regular, slightly cheaper (NOT extended 15K) synthetic Mobil 1 oil.
    After 60K...I'll do it every 10K.
    Will my warranty be void if I use oil besides 5w-30 (ex. 0w-30, 0w-20)?
  8. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    I'll probably do the same thing after 60K (still got 21K to go), with the UOA that Tochatihu suggests. FYI, here's a good discussion on the subject.
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Or you could use Mobil 1 0W-40, which is approved for even longer service
    Mobil 1 0W-40
    That said, Mobil does have a legal "out" should you happen to take them up on the offer of running the oil every 15,000 miles
    Mobil 1 Extended Performance FAQs
    Remember that Toyota got burned by having a 7,500 mile interval, combined with crap North American oil. The same motors that were prone to sludge here in North America didn't appear to have any issues in the EU, running ACEA oils
    The API/ILSAC wonderful motor oil specs will specifically exclude protection from the following: ring land fill, crown land fill, cold stuck rings, cold sludge, and cold gellation
    I started the UOA program on my Prius after reports of sludge on other vehicles. Had some unusual readings, so contacted Toyota Canada. They BLAMED ME for using Mobil 1, started a "file" on my Prius as a result
    So after chasing a lot of dead ends, finally sampled the bulk dealership oil. Guess what? It was pure crap! I might as well have pooped in the tank, it wouldn't have made the oil that much worse
    Once I sent THOSE results back to Toyota Canada, suddenly they closed the file, and said nothing more. Hmmmm, wonder why??
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Read the book. The only things required are filter changes. Do them yourself with Toyota filters bought on-line and save yourself a pile of money.
