Warning light, 10 codes, any thoughts?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by drive2much, Mar 17, 2008.
  1. drive2much
    drive2much Junior Member
    42
    Denver
    My Prius is back at the dealership since the idiot lights came on. They have 10 codes but don't know what it means. Said they haven't seen this combo before. They are in touch with Toyota Techline. Here are the codes:
    C2300
    C2318
    P0A93
    P3102
    P3108
    B1421
    B1462
    B1200
    B1207
    B1271
    Does anybody have any experience with multiple unrelated codes showing up? Any suggestions?
    (I have a feeling that this is going to set me back a pretty penny.)
  2. jdenenberg
    jdenenberg EE Professor
    3,956
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    One possibility that can cause multiple random codes (and not be too expensive) is a weak 12v battery. Check the 12v battery voltage when the car is off and again in ACC mode. If it is below 12v, that may be the cause.
    JeffD
  3. drive2much
    42
    Denver
    Thank you. I'll check into that.
  4. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    the last three are strictly from someone trying to start the car without the smartkey (or without the car detecting smartkey). these are "communication stop" codes. these are called soft codes- they will set a dtc in memory but will not light any kind of light because, well, they're insignificant.
    the 1421 is also a soft code. that was a solar sensor circuit.
    this sounds very, very much like a 12v electrical system issue. a lot of electrical stuff, a low voltage concern, wiring, etc. first things first, replace the 12v battery. monitor voltage output to the 12v with a meter on the battery terminals.
    instead of going through all those diagnostics, get a new 12v and have them clear the codes.
  5. Patrick Wong
    18,210
    6,514
    C2318 "Low Voltage Error" is reported by the transmission control ECU and triggers when the available voltage drops to 9.3V or less for more than one second. It would be very reasonable to first suspect the 12V auxiliary battery, especially if the battery is original equipment.
    If the battery is not the problem, P0A93 "Inverter Cooling System Performance" might point to an overheated inverter assembly resulting in a failed DC to DC converter. Hence the 12V bus voltage would fall below the normal 13.8V, again causing the other DTCs.
  6. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    During much of last year, my car had a whole litany of codes set
    across various ECUs that came from playing around and having
    various parts disconnected at times. I didn't clear them --
    I left them there as a good exercise for the tech-training effort,
    telling the students to go pull all the codes and then I could
    explain every one of them and even recreate a few.
    But in a total unknown situation, where stored codes could
    reflect unrelated stuff that happened months ago, f'geddaboudit.
    SOP is to record and then clear the codes, go for a test drive,
    and see what returns to indicate any CURRENT problems.
    Stored codes also gradually disappear, as there's logic to remove
    them if the original problem doesn't recur in something around
    40 "trips". Note that the MIL isn't on that whole time, as there
    is different logic to clear *that* after only 4 reboots if a
    problem cause isn't found. History codes just sort of hang out.
    _H*
  7. Patrick Wong
    18,210
    6,514
    Hi Hobbit,
    I'm assuming the OP was not experimenting with the vehicle as you do.
    Suppose the tech spends 15 minutes retrieving codes and drives around 30-45 minutes. No warning lights come on. Then the service writer explains to the customer that s/he is being charged for one hour of diagnostic time but the car is NTF...
    If the customer is expecting warranty coverage for the repair, I suppose s/he then has to wait for another episode of warning lights before any action will be taken?
    In this particular case the problem seems to be 12V bus-related given the low-voltage DTC. I've seen instances where posters related that the 12V battery was suspected, tested, found to be good, and restored to service. Then a few days or weeks later the problem reappeared and the battery had to be replaced, solving the problem. What would cause this - an intermittent short in a cell?
    If this particular situation happened to me I would be inclined to purchase & install a new 12V battery.
  8. galaxee
    9,810
    471
    MD
    more realistically the tech spends 10 minutes waiting for a scantool, 2 minutes clearing codes, and takes the car on his usual test drive loop. unless he cuts a corner and just starts the car and lets it run. but chances are he will not be paid for his time if there is no repair to do so he does end up getting the short end of the stick.
    if no codes come back, yes.
  9. Patrick Wong
    18,210
    6,514
    Hi Galaxee,
    I could see that this would really upset the tech, especially if the customer was charged but the tech doesn't get his/her cut.
  10. galaxee
    9,810
    471
    MD
    fairly standard operating procedure, really.
    diag techs don't make it long in the field before they leave for something that pays more than minimum wage.
  11. Patrick Wong
    18,210
    6,514
    Thanks. I've noticed the occasional post about a difficult intermittent problem (ranging from HID headlights to sudden unexplained acceleration) and lack of support from the dealership. Your comments help explain why intermittent problems are not welcome there.
    Hence the customer must live with the problem until it becomes obvious and demonstrable.:rolleyes:
  12. galaxee
    9,810
    471
    MD
    well... i've made a couple posts on diagnostics and such, and what it comes down to is that it's pretty tough to sort out some of the intermittent or small issues. mentally a fun challenge, but does not put food on the table, that's for sure.
    a lot of the time, if the problem is not present right in front of the tech, there is no way to diagnose it. so they send it back out rather than sit around tapping their foot waiting for the problem to recur. that's called a cnr or could not replicate. no sense standing around doing nothing (getting paid nothing) when one can be earning a paycheck with all the other work that's waiting to be done.
    the system is all wrong, but it's not going to change.
  13. drive2much
    42
    Denver
    Here's a follow-up on what the dealership did:
    They replaced the cooling pump because they believe it failed, causing the engine to begin overheating. They did not think that it became too hot or that it damaged anything else. I asked them about checking the 12v, and they said they already had and that it was fine. (I think they may have perceived that as meddling on my part because they stressed that they had a PRIUS TECH working on the problem.)
    Lucky for me, they replaced the pump under the powertrain warranty. Since my 3 year / 36,000 mile warranty is up, I would have gone with your suggestions of trying the 12v battery first if I had to pay for the repair myself. I believe I will do that anyway just to be sure.
    I can't say that I'm convinced that the cooling pump was the problem: When I was in a few months back for the red light of doom, they got a P1116 code and replaced the coolant overflow temperature sensor. So this weekend I will take it for the same longer drive I did both times I got the warning lights and see if it happens again.
    In any case, thanks to everybody who responded! I'll let you know if something else happens.
  14. Patrick Wong
    18,210
    6,514
    Changing the temp sensor was the appropriate response to DTC P1116. The alternative would be that the engine coolant system is clogged.
    Which cooling pump was replaced: the inverter coolant pump or the engine coolant pump? If it is not obvious when you look at the service invoice, please let us know the part number. Given the DTC P0A93 that you provided I would expect the inverter cooling pump to be replaced.
    If you have a digital voltmeter, I suggest measuring the voltage either across the 12V battery terminals; or (perhaps easier) at the positive jump start terminal located in the main relay/fuse box near the inverter, to a bare metal ground. See what the voltage is when the car has been IG-OFF 10 minutes or more. If it is below 12.4V, the battery is getting marginal or needs to be recharged. You would expect to see 12.6V or better if the battery is strong.
    Then see what the voltage is when the car is READY. It should be ~13.8V and hold steady, showing that the DC to DC converter is working. Try turning on the headlights, ventilation fan to max speed, rear hatch defroster on, and set the cabin air temperature high (to turn on the PTC electric heaters and maximize electrical load.) The 13.8V reading should hold steady.
    The nice long drive, as you mentioned above, should be a good test as well. Good luck, hope that your car is restored to full health.
  15. drive2much
    42
    Denver
    The invoice says "G9020-47031 PUMP".
  16. Patrick Wong
    18,210
    6,514
    Thanks, here is the part description per Champion Toyota Gulf Freeway's parts website:
    Cooling - Radiator and components - Motor assy - W/pump
    W/pump - Inverter 2004 - 2008
    MSRP: $110.63, their price $84.08
    Hence this pump is for the inverter and transaxle coolant loop, which corresponds to your DTC. Hope that this solves your problem.
