Tuned Suspension - What is it???
Discussion in 'Gen 2 Prius Technical Discussion' started by Whiteyprius, Mar 12, 2008.
  1. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    I know how to tune a radio; I know how to tune a guitar. I know what tuned exhaust is - but what on earth is a tuned suspension system? My '08 Touring came with it, and I'm darned glad - I guess! C'mon PC'ers, help me.
  2. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I think it involves stiffer struts/shocks, springs, and stabilizer bars than the standard Prius.
    But, one unanswered question that has been posed here (I can try to find the thread later) is whether all the struts/shocks, springs and stabilizer bars are stiffer on the Touring Prius
    I asked my Toyota dealer's service and parts departments several times by email, telephone and in person:
    Exactly what parts do I need to convert my standard Prius' suspension into the Touring Prius' tuned suspension?
    Haven't gotten a decent answer yet. My Toyota dealer is by far the worst dealer I've ever dealt with.
  3. Boo
    5,051
    488
    97
    Flushing, NY
  4. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Whitney...,
    Tuning a Mass and Spring system such as a car suspension is the process of selecting spring constants, and damping rates (shock absorber valving) so that the wheel resets to the road as quickly as possible after hitting a bump. The goal is to maintain the pressure between the tire and the road at the undisturbed level, or greater, through-out the tires progress over the road surface discontinuities.
    Think about a heavy ball hanging from a spring. Push up on the ball and let it drop. It oscillates up and down. Your car is the same thing, only rather than having a extension spring, its upside down with a compression spring. The ball and spring system does not have a shock absorber, so it vibrates for a very long time. If your car did not have shock absorbers (dampers in european and engineering terminology), the car would bounce up and down for a long time. Each time the car went high in this response, the pressure between the road and tires would get small, and traction poor. In a turn, the car would slide at this point.
    A tuned suspension is setup so that when a bump happens, the wheel follows the bump, and rebounds to the road nearly instantly, and the car does not oscillate. If there are side or accelleration loads on the tire during the bump, the car continues to track down the road as steered, and does not slide sideways, within the capabilities of the tire.
  5. RonH
    RonH Member
    556
    A car's suspension is basically composed of springs, masses, and dampers of one sort or another. So, theoretically, any suspension is tunable, that is the combination of spring constants and damping factors resonates at a specific forcing frequency and has certain Q, the narrowness of the frequency response. Normally you want your suspension to be detuned. Not going boing-boing down the road. I had a Corolla that did that on a certain patch of freeway at a certain speed. An old trick is to push down on the fender and watch whether it bounces or not to check the condition of your shocks. "Tuned" is marketing speak for stiff which really means the resonant frequency is well above that which might be encountered.
    In another sense, a car will sway when going through a turn and will rock back and forth when negotiating an S curve. If the suspension is "tuned" right the turning forces will be out of phase with the swaying forces and cancel. The car will seem to go through the turns on rails, up on its toes as they say. Obviously, this condition exists for only certain values of turning radius and speed and car. Watch a NASCAR race as the pit crew inserts and turns a crank in the rear fender, changing the tuning of the suspension as the tires wear or the track condition changes. At a certain speed and banking no tuning would be needed as the suspension forces would be neutral.
    Hope that helps.
  6. RonH
    RonH Member
    556
    Good description from a time-domain perspective: the impulse response's (bump), rise time (instantaneous return) and overshoot (bouncing). Mine was in the frequency domain: resonant frequencies and Q's. In passive linear systems (masses, springs, dampers) they are equivalent. An interesting exception, which is why I'm belaboring this, is active suspension which adjust its parameters (stiffness, damping, its kind of hard to change mass!) as conditions change on a moment by moment basis. Is it raining, is a tire sliding, no problem for the micro-controller. I think they banned them in formula one racing to slow the cars down and make driver skill more of a factor.
  7. Whiteyprius
    389
    105
    North Carolina, USA
    :clap2:Thanks to all who replied! - I think I understand now - I'm also glad that I don't have to make that conversion - sounds like not much help from your dealers!:blah:
  8. qbee42
    3,079
    Yes, but do you know how to tunafish?
  9. Boo
    5,051
    488
    97
    Flushing, NY
    Supplementing RonH's and Donee's good answers above (and correcting an error in my answer):
    Ken1784, in the Touring Suspension Parts thread, made the interesting point that the Touring Edition's rear springs are actually softer than those on the standard Prius; evidencing that the suspension's performance depends on the totality of its parts (shocks, springs, stabilizer bars, and even tire stiffness).
  10. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Short answer, the shock rates are set with the spring rates in mind for the handling/ride you want.
    Be aware as well that a "tuned suspension" isn't the same every time. You could tune the suspension for an extremely soft ride or for best handling (the normal meaning). If you were the Mythbusters you could even tune it for maximum bounce. ;)
    Usually you choose the spring rate for the ride or handling you want, then choose the shock dampening to ensure the motion stops after 1/2 cycle. There is no "right" way however. It depends on what you want, and there are always compromises. A "best handling" setup usually rides pretty rough, for example.
  11. getthedata
    getthedata Junior Member
    Great Info!
  12. tmanson
    tmanson Geetar-playin' Traveler
    71
    Frederick, MD
    You can tune a piano (and a geetar and a Prius) but ya cain't tunafish!
    :focus:
  13. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    You Can Tune a Piano but You Can't Tuna Fish,
    REO Speedwagon's seventh studio album,
    Released March 16, 1978 Recorded1977-78 at Sound City, Los Angeles
    Vocals recorded at Record Plant Studios
    Too old to Rock and Roll, Too young to die!!!
    73 de Pat KK6PD
  14. patsparks
    10,664
    567
    Adelaide South Australia
    All the springs in a tuned suspension have subtle changes made to them which allows bored technicians to play a tune on the springs by hitting each spring in order. A soft face hammer is used to reduce damage and normally 4 techs need to co-operate to play a tune. Most techs start by learning simple tunes like 3 blind mice then progress to more difficult, complex pieces.
    Fortunately most of us have standard, discordant suspension so services are quicker and less expensive.
    I hope this helps you understand your car better, I would ignore all the other answers, those people are just taking the pi**. I must say I was rolling with laughter reading some earlier posts in this thread.
    You can't tune-a fish but can you eat a tune-a sandwich?
    My son just asked if, a tuna sandwich is what people who fit huge loud mufflers to little japanese cars with 5 horsepower engines eat?
