Why didnt my Prius shut off?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MPGsnob, Mar 28, 2008.
  1. MPGsnob
    MPGsnob New Member
    Arthur, IL
    Hi all,
    I drive a 2005 Prius package 4. I forgot to press the power off button as I got out of the car on the way to class. I did try and lock it using the key fob but didnt listen for the beeps as I had headphones on.
    3 hours later I walk back to my car and hear the car running. I thought maybe it was the SKS system kicking in- not so. My car had been running the entire time. My MPG went from a 49 mpg ave down to 44.3 and the heater was hot.
    Any ideas as to why my car didnt shut off- and yes, I had my key in my pants pocket and my classrooms are several hundred yards away from the parking lot.
    Thanks,
    Steven.
    :spy:
  2. Patrick Wong
    18,204
    6,505
    Well, since you didn't press the POWER button to make the car IG-OFF, why would you expect it to turn off by itself?
    If the Smart Key is removed while the car is still READY, the amber key icon will come on in the instrument panel to show you there is a problem, and the car will beep at you. However the car will continue to remain READY until you press the POWER button to turn the car IG-OFF.
    You are lucky that no one drove away in your car; I'm not sure whether your doors would lock or not.
  3. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    I think you answered your own question in the first sentence:
    If you don't turn your car off, it won't turn off. I don't know what more there is to say.
  4. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    What happened was that the HV battery had run down to the point that the engine needed to fire up to recharge it. If you have SKS, the car won't shut off unless the power button is pushed. I'm pretty sure it operates this way so that the car doesn't die at an inopportune time if the battery in the fob were to go dead.
  5. diamondlarry
    559
    Elkhart, IN
    It most likely wasn't locked. I know that if you try to use the black button on the door handle to lock it when the car is in "ready" you'll get beeped at and the doors won't lock.
  6. MPGsnob
    MPGsnob New Member
    Arthur, IL
    Deeerrr I feel so stupid. Indeed I am lucky- and thanks for the information.
  7. Patrick Wong
    18,204
    6,505
    Hi Steven,
    No desire to make you feel stupid.
    Consider a situation where you are driving along, and the Smart Key fob battery decides to die while your car is in operation. The fob is in constant communication with the Smart ECU, so the ECU will think that the fob has been removed from the car.
    If Toyota set up the logic in that situation to turn off the car automatically, you would not be happy. Hence, visual and audible warnings are provided in hopes that you'll notice.
    I've attached an excerpt from the 2004 New Car Features Manual that you might find interesting to read.
  8. qbee42
    3,079
    There is an auto-shutoff feature. When it runs out of gas, it will automatically shut off.
  9. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Welp, good thing you had a prius instead of a normal car.... You might have run out of gas if you left a normal car running :)
  10. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    I thought I had tested this before, but went ahead and did it again:
    With the car on and in [READY] mode:
    • The doors will lock once closed.
    • Once open, when you press the door lock button the armrest the doors lock and then immediately unlock. They simply will not stay locked.
    • Once the door is closed, the car delivers three beeps.
    • Pressing the SKS black button delivers one long beep and the doors do not lock.
    • Pressing the "Lock" button on the fob simply does nothing. Doesn't even try.
  11. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    A number of years ago someone at work locked his car door with the engine running without realizing it. By lunch time it did shut-off - out of gas. If it was a Prius it still could be running;)
    Gabe
  12. TonyPSchaefer
    14,816
    2,500
    66
    When I'm at car shows and events with Wayne (FireEngineer) he tends to leave his car running all day with the XM Radio playing. It comes on from time to time to recharge the battery but for the most part it just sits there.
  13. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    If the A/C or heat isn't on, I'll bet the Prius will stay on for a very long time -- days, perhaps.
  14. patsparks
    10,664
    567
    Adelaide South Australia
    Where is Wayne?
  15. TonyPSchaefer
    14,816
    2,500
    66
    I talk to him every now and then on the phone and we're planning a Chicago event for April 27th (shhh we haven't announced it yet) but he just doesn't seem to be coming around here much these days.
  16. qbee42
    3,079
    People have used them for auxiliary power after ice storms. There was a great story last year about someone running their furnace from their Prius. About every three days they would drive to the gas station and fill up. Other than that, they just left it running in the driveway.
