PriusXM installed + *GREAT* tip for removing vents!
Discussion in 'Gen 2 Prius Audio and Electronics' started by riskable, Apr 7, 2004.
  1. riskable
    riskable Junior Member
    74
    Jacksonville, FL
    I ordered PriusXM from Jon on Sunday, it was shipped on Monday, and I received it Tuesday (not because I paid for overnight, but because Jon doesn't live very far away from me).
    I installed the XM kit in the afternoon on Tuesday and it took me about an hour. I've done an XM radio installation (and other car stereo stuff) before, so it didn't seem very daunting. However, I noticed that those vents are a PAIN IN THE nice person to remove. Some are easier than others, but I discovered a sure-fire super-easy way to pop them off: a plastic pot scraper.
    The $1.50 plastic pot scraper can be purchased from any kitchen store and it consists of a single piece of plastic in a wedge shape that is the perfect shape for wedging between the top of the vent and the dash.
    The reason I say use the pot scraper is because it's made out of plastic (like the dash) so it's unlikely to scratch anything. Also, it's just wide enough to distribute pressure very evenly along the edge of the vent making it pop right off in a few quick wiggles.
    So far, I'm loving the PriusXM kit. The DVD was priceless (love the hat Jon!) and the integration into the Prius is beautiful. I could've saved a lot of money and installed a cheaper kit, but I think the extra $200 is worth it for the DVD and the MFD integration.
  2. riskable
    74
    Jacksonville, FL
    I almost forgot to mention that when I called the XM people to switch my subscription to the new radio ID, I convinced them it was a new car with "integrated XM" so they gave me 3 months free.
    Some of you existing customers might want to give it a try (tell them that you accidentally threw out the XM packet that came with the car).
  3. jed
    jed Junior Member
    appreciate the tip. is there a specific order
    to removing the vents and panels, as i have
    read in some places, or does it really matter?
    jed
  4. riskable
    74
    Jacksonville, FL
    Yes, there's a specific order. Also note that in order to remove some vents, you need to remove other panels and screws. It's best to watch Jon's video =)
  5. DaveG
    DaveG Member
    806
    Vancouver, BC
    If you look at the PDF for installing the EV mode button that Evan authored, it has details on how to detach the side vents - should be fairly straightforward to work your way into the dash from there.
    Dave
  6. jed
    jed Junior Member
    thanks guys.
    jed
  7. Jon
    Jon Junior Member
    57
    Whippany, NJ
    Thanks Riskable. That's my favorite hat. :D
    -Jon
    PriusXM
    www.priusxm.com
  8. Wildzeke
    Wildzeke New Member
  9. riskable
    74
    Jacksonville, FL
  10. Wildzeke
    Wildzeke New Member
  11. vintagebob
    vintagebob Junior Member
    98
    San Jose CA
    Another successful installation here!
    Thanks Jon :mrgreen:
  12. Eisenson
    Eisenson New Member
    142
    Just curious whether you installed that unit in the trunk (antenna on the roof) or in the glove box (antenna up forward on the dash).
    I've gotten a lot of inquiry as to how far north one can be and still have the dashtop antenna work satisfactorily with my 10-minute installation. Seems to me that San Jose would be at an iffy latitude unless there are terrestrial repeaters.
  13. vintagebob
    98
    San Jose CA
    <div class='quotetop'>QUOTE(Eisenson\";p=\"58592)</div>
    I put it in the trunk with the antenna on the roof.
  14. Brian
    Brian Member
    480
    Bakersfield
    Here is how I pull off those vents, just grab hold and pull like there is no tomorrow. Works every time. ;)
  15. JoeyJoeJoShabadoo Jr
    48
    New Jersey
    Can someone post a link to john's video for removing the panels. I've searched his site and cant seem to find it...
  16. JoeyJoeJoShabadoo Jr
    48
    New Jersey
    Beuler...Beuler...Beuler...?
  17. Stocktrader
    Stocktrader New Member
    NY
    Heya Joey,
    Just making sure you know that was a thread from 2004.
    Not sure if it's the same for a 2008.
    Best of luck.
  18. JoeyJoeJoShabadoo Jr
    48
    New Jersey
    ahhh, good observation...
    Well does anyone have any tips for taking these vents off, ive tried a taped up scredriver, a plastic spatula, ive tried pulling and squeezing... i finally went to an audio installer and he said hed help me run the sgII wire for $50, but id much rather do it myself.
  19. patsparks
    10,664
    569
    Adelaide South Australia
    It may only apply to right hand drive cars but when removing any dash panels on the drivers side of the MFD start by removing the vent panel near the drivers door, then 2 screws under the dash, door side of steering column then remove the bottom then top dash panel and then the vent panel beside the MFD.
    Remember there are release tabs to press to remove electric connections.
    Be very careful when installing the drivers door side vent panel, there is a fragile square "hoop" that a peg goes into, it is very easy to break if you don't line up the peg properly.
