ICE turning on and off
Discussion in 'Gen 2 Prius Technical Discussion' started by nosliw, Mar 29, 2008.
  1. nosliw
    nosliw New Member
    76
    PNW
    Last night my car did a very funny thing.
    I had just gone down a long slope, so the battery was fully charged, and my foot was on the brake at a redlight.
    I noticed the engine start and then shut off a few seconds later. I could feel it start and stop every 2 or 3 seconds. I can't remember what the MFD said. It continued doing this for a minute until the light turned green.
    My foot was firmly on the brake, and it hasn't done it since.
    Anyone else experience this?
  2. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    This has never happened to my since my battery is almost never fully charged, but I remember some people talking about that here. Apparently, the ICE will run and burn off some of the extra charge. I can't explain it but I'm sure someone will chime in and be able to explain it.
  3. patsparks
    10,664
    567
    Adelaide South Australia
    The electric motor will spin the ICE (internal combustion engine) to dump excess energy if the battery is over 80% charged. If the battery is at full charge regularly at the bottom of a hill this is the only time I would recommend using B mode to slow the car on the hill. Basically this manually dumps some of the energy before it gets to the battery.
    This isn't compulsory, the Prius can look after itself.
  4. qbee42
    3,079
    In case it wasn't obvious from the previous post, the engine isn't running when it does that, it is just being spun by MG1 to throw away excess charge. The motor spins the engine for a few seconds, then checks the battery. If it is still too high, it spins the engine some more. The cycle continues until the charge is down the the proper level.
  5. MPGsnob
    MPGsnob New Member
    Arthur, IL
    Is it ideal to have the battery green?
  6. nosliw
    nosliw New Member
    76
    PNW
    Interesting. Thanks for the replies.
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    No, it is ideal to have 6 blue bars...or about 60% SOC...that's what the car is programmed to shoot for to maximize battery life.
  8. nosliw
    nosliw New Member
    76
    PNW
    What's wrong with letting the battery charge all the way up (like down that hill) and utilizing the battery more for a while to drain it back down?
    Doesn't that not waste the *free* energy from going downhill into something I can use for transport later?
    I noticed the ICE didn't kick back on to propel me until I hit about 25MPH after that (it was only very slightly downhill after the stoplight. I used up most the battery on the stop-and-go traffic before I got home.
  9. pewd
    pewd Clarinet Dude
    331
    Dallas, Texas
    for all the car knows, you're fixin' to go down another hill ; the computer is trying to protect the battery from an overcharged situation.
    the computer cant see whats ahead, so it makes assumptions that fit the majority of situations.
  10. nosliw
    nosliw New Member
    76
    PNW
    It didn't burn off much (not a bar) when it was churning the engine those few times. And on the way home I hardly used the ICE. Great mileage.
    In THIS situation do you think it would be best to just let 'er charge?
    If I use 'B' and understand it correctly, I'm just wasting that potential power.
    Or maybe I'll approach the hill slower and glide down the whole thing.
    Or maybe I should drive the thing like any other car and let it do its own thing.
  11. richard schumacher
    7,664
    1,046
    United States
    If the cabin heater was on then the engine was running to supply heat.
    The only reason to use B is to avoid riding the brakes on a loooonnng downgrade. Any other time it pointlessly reduces fuel economy.
  12. efusco
    19,891
    1,196
    Nixa, MO
    It won't burn off 'much'. But it'll burn off a few percentage of the state of charge. As stated above, when the SOC goes above 80% the car will do all it can to get you back below that...it's too small a difference for you to see on the rough Energy Screen Battery display.
    yes. And in future generations we may well have GPS integrated into the programming of the HV ECU and the car will know that you're planning on going up a hill next and leave that higher charge there for you to use. But, as stated above, the car has no idea if you're going to go up hill, level or down hill and keeping the SOC above 80% will, potentially, shorten battery life just as being below 40% can.
    Probably...if the hill is very long and you're going to max out the battery SOC (80%+) either way then B-mode is fine. Most of us just don't bother as more often than not you're burning gas unnecessarily with the ICE running as it does in B-mode.
    NOW you're talking!!:hail:
