REd sign on dash when opening door
Discussion in 'Gen 2 Prius Main Forum' started by Flying White Dutchman, Mar 29, 2008.
  1. Flying White Dutchman
    4,376
    313
    Today i opened the door when i was in "D" and the red triangle came up
    ok thats not a bad thing warning that i am stil in D.. BUT on the MFD the message came up that when i am in "N" the car wil not recharge te HV battery... but i was in "D" only opent the door for a sec...
    is this normal or do i need a software upgrade?​
  2. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    That's normal.
  3. Flying White Dutchman
    4,376
    313
    ok but i was in "D"not in neutral and it tells me to not put it in "N"
    i was not in "N"... software program mistake
  4. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    It really is normal for it to say that. I don't know WHY it says that, but it does.
    Others have mentioned this before.
  5. qbee42
    3,081
    It's a red herring error. It doesn't make sense, but that's the message that comes up. It scares the bejesus out of you the first time, but it is normal.
  6. Flying White Dutchman
    4,376
    313
    i did not panic:cool: i keeped it cool:cool:
    even opened the door several time's to check what was going on!;)
    maybe this is a good thing you never leave the car in "D" when exiting the car. ( when you maybe on a small incline road the car wil stand stil )
  7. richard schumacher
    7,666
    1,047
    United States
  8. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    The Prius one of the only cars on the planet that will move under power when its in D and the engine is not running. Toyota probably made the only decision they could in this case, to keep you from getting out and having the car run away.
  9. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Yeah, unfortunately, thats the message that appears when a door is open and your still driving.
  10. LochNess
    LochNess Junior Member
    30
    Yeah, it sure freaked me out when I saw it.
