New prius owner got a few questions
Discussion in 'Newbie Forum' started by sandman, Mar 30, 2008.
  1. sandman
    sandman Member
    277
    32
    kentucky
    OKay I thought I had this pulse and glide thing down pat but the more I read the more confused I get..I got the pulse its the glide thing I am having hard time understanding...When I glide should there be no arrows? Coming home I would try and get the arrows from battery only when gliding to help glide farther but I read this is a bad thing..ONe more question when I leave on my commute there is a big hill I go down about a mile of coasting what is the best most efficent way to coast down that hill? 1. Get screen with no arrows? 2. Just let off gas? 3.Go to B on shifter and continue letting off gas 4.Go to N? ( I know this is bad idea just throwing all options out there)
    I thought it would be just let off gas but read somewhere if you go to b and coast it charges battery anyways thanks for all the help..LOving this car!!!!
  2. richard schumacher
    7,664
    1,046
    United States
    To improve fuel economy:
    - accelerate briskly
    - gliding (no arrows) is better than coasting
    - coasting is better than braking
    - braking is better than coming to a complete stop (or losing control!)
    B always reduces fuel economy. Don't use B unless the downslope is so long that you would otherwise ride the brakes. On your big hill the strategy is the same as anywhere else: glide if you can; if that's too fast, coast; if that's too fast, brake; if the brakes start to fade or smoke, shift to B. (Don't use N: it's not safe, and the car does not recover any energy to recharge the battery.)
  3. sandman
    sandman Member
    277
    32
    kentucky
    Thanks richard schumacher for your reply you make it seem simple... I am pretty sure coasting down this hill will be no problem its got a long run out..:) Gliding (no arrows): I had it wrong, all the way home I thought I was gliding what I was doing was draining my battery:rolleyes: I will have to work on that gliding seems hard to keep it there...Thanks
