I finalysed my DIY plugin
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Flying White Dutchman, Apr 1, 2008.
  1. Flying White Dutchman
    4,376
    313
    Ok today i got it working
    with my rewritten software thx to tim and ken@japan
    i have a canview of my own
    and it connects en disconnects the extra battery pack based on state of charge and voltage.
    I now get a range of about 20km keeping the battery voltage high so i keep the soc high and the prius keeps driving in EV mode
    The battery pack is connected with relais so when i am charging the HV battery pack from the prius its 12 volts in parallel and i have a DC- DC converter that puts out 240 volts
    when the extra battery pack is depleted its put in series and in parallel to the HV prius battery and can take in regen energie when braking.
    Pictures soon....:cheer2:
    i am thinking about setting up a company for plugins in the EU
    the price wil be somewhere around 2000 euro (3000 dollar ) for 20km range
  2. Flying White Dutchman
    4,376
    313
    later today i will post a link to a website explaining everything
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Good work and congrats. I look forward to seeing your finished product.
  4. Pinan
    Pinan Member
    173
    Murrieta, CA
    Excellent! Looking forward to pics and more info. :)
  5. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Glad to know you did it!
    Assume you posted on wrong date.
    It should be on April 1st, 2011. :)
    Ken@Japan
  6. Winston
    Winston Member
    614
    SF Bay Area, California
    Congratulations. Let's see if all of the naysayers show up and swallow their words.
    While I was glad to see that you kept working at it, I really did not expect you to be successfull this quickly.
  7. patsparks
    10,664
    567
    Adelaide South Australia
    You have surprised me, well done.
  8. adept
    adept the prius novice
    Grantsville, UT
    If this isn't an april fools post...
    What did you use for the battery pack, and how much did it cost you???
  9. Flying White Dutchman
    4,376
    313
    here is a link to a fully self explanatory website KLIK
    :peace:
  10. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ok...not funny...;)
  11. Flying White Dutchman
    4,376
    313
    :sorry:to all. :behindsofa:
    :pound::peace:
    3000 dollars and 20km range? really now one that started to disbelieve that? the amount of battery's you need to do that cost more than 3000 dollars. even is you use lead acid battery's
  12. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    Ok, that was pretty funny. :p
    Rob
  13. sugar land dave
    137
    houston
    It IS April 1st. Best to take any unusual claims with a BIG grain of salt! :)
  14. Winston
    Winston Member
    614
    aaackk! I went about my day after making my congratulatory post, then just realized what day it was. Oh well, good joke!:pound:
  15. Flying White Dutchman
    4,376
    313
    yhea your post one of the best "Let's see if all of the naysayers show up and swallow their words":D
  16. clett
    clett New Member
    537
    Scotland
    Actually, you can get lead-acid for about $300 per kWh at the moment.
    A Prius typically uses 200 Wh per mile, or 125 Wh per km, so for 20 km you would need 2.5 kWh, or say 3.6 kWh to allow for only 70% discharges of your battery.
    The battery for a 20 km range could cost as little as $1,080, but of course the problem of lead acid is cycle life (and weight, 3.6 kWh would weigh in at 120 kg). This is why there is the scramble for lithium.
  17. Flying White Dutchman
    4,376
    313
    ok maybe the DIY plugin being ready was a joke
    but i am still working on it
    and below are some pics of the firts testdrive with the canbus monitoring.
    and i can say that when you start from a dead stop and you do it slow then you can get -20 to -30 amps @ 210 volts = between 4200 - 6300 watts
    and when driving along i get -15,5 @45kmph = 3255watt
    so... a lot more!!
