Prius surged forward
Discussion in 'Gen 2 Prius Main Forum' started by yite, Apr 2, 2008.
  1. yite
    yite New Member
    Was at a stop light behind a truck with our Prius (bought December 2000) in Neutral and my foot on the brake. When I put the car in Drive, foot still on the brake, it surged forward FAST. Luckily the truck stopped me, though the front of the car is all crumpled up. Anyone heard of similar experiences?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Yea, it's called not keeping your foot on the brake enough.
    Why did you put it in neutral? I'm betting you foot was on the accelerator and when you dropped into drive it surged forward.
    There's no reason to put the car in neutral at a stop like that and several good reasons to leave it in drive.
  3. jiepsie
    jiepsie New Member
    267
    Could it be not keeping your foot on the brake at all, but on te accelerator instead? I think it will happily shift from N to D while rolling slowly without pushing the brake.
  4. yite
    yite New Member
    No, my foot was definitely on the brake because the car was facing up an incline and would otherwise have rolled back into the car behind me.
  5. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Check your floor mats to see if it got wedged on top of your pedals.
    If you hit both pedals, then it'll surge up if your not pushing the brake hard enough.
  6. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    first of all, if you were on a incline why the heck did you have it in neutral.
    and your car surged forward, your gas pedal had to be depressed.
  7. yite
    yite New Member
  8. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Sounds like a TROLL to me.
    New Member driving a Classic
    Won't say why car was in Neutral at stop light
    Frend sends anti-Prius links?????
  9. donee
    donee New Member
    2,956
    198
    Chicagoland
  10. Tripod137
    Tripod137 New Member
    145
    Long Island
    Interesting...if the floor mat is on top of the gas pedal (as has happened to me and my wife -- we have since gotten new winter floor mats), the engine will obviously rev like crazy. If you put the car in neutral, that will keep the car from revving (by design, it seems), so by switching back to drive...the pedal is still down...the engine immediately revs up and the car takes off.
    Sounds totally logical to me. The mat probably covered the gas pedal while at the stop on the hill.
    Does the poster, by any chance, have aftermarket floor mats?
    This problem can happen if you install them on top of the factory mats (bad idea) or install them correctly (removing the factory mats AND using the floor mat hooks).
  11. Patrick Wong
    18,210
    6,511
    Maybe; lets see if the OP will post photos of the damage, the car's odometer reading, and the driver's side footwell showing the pedals, the carpeted area, and any floormats used.
  12. patsparks
    10,664
    567
    Adelaide South Australia
    Yes, photos of the damage and of the floor around the pedals will help us give a good on line diagnosis.
    No one is saying you're lying mind you, it is just so we can make an informed diagnosis.
  13. patsparks
    10,664
    567
    A real consumer affairs site will not have banner ads on their site as it compromises their impartiality.
    This is a real consumer advice site, look no ads!!
    CHOICE - CHOICE Online
  14. richard schumacher
    7,664
    1,046
    United States
    Definitely sounds like a troll, or a shill for litigators, or maybe another old fart driver who can't tell where his feet are anymore and ought to surrender his license. These identical posts appear under a different name at
    PriusOnline.com • View topic - Prius surged forward
  15. NaptownPrius
    NaptownPrius Getting Greener....
    271
    Napolis, Merlin
    Why did you put it it in neutral on an upward incline?
  16. yite
    yite New Member
    We have only the original floor mats which haven't been moved or cleaned in weeks (oops) and none of which was on the accelerator pedal.
  17. ForTheGlory
    ForTheGlory New Member
    296
    Maryland
    Here's a question whose answer should help to explain some of what's going on here: I know that the Prius is "steer by wire", where the steering wheel is not mechanically linked to the tires. Does the go pedal work the same way? My impression was that the pedal mechanically actuates the throttle.
    If the pedal is mechanically linked to the throttle, there's no chance of a "false acceleration command" being the computer to the engine. The only possible command source is the pedal itself. I suppose that the "auto-creep" function of the transmission also sends commands, but the acceleration from that is not nearly on the level that the original poster is describing.
  18. yite
    yite New Member
    I'll ask the repairer to take photos or go there myself to take them. Our insurance company was incredibly efficient about getting us a replacement car and taking the Prius away: all done within about six hours.
  19. yite
    yite New Member
    I wonder about this, too. As I recall (no Prius here to test) pressing the accelerator pedal while in Park or Neutral does not cause the engine to rev, so they're not mechanically linked, right?
  20. ForTheGlory
    296
    Maryland
    I've never had cause to press the accelerator while in Park or Neutral, so I'm not sure what it does.
