Prius exhaust system
Discussion in 'Gen 2 Prius Main Forum' started by theoriginalwheelstv, Apr 3, 2008.
  1. theoriginalwheelstv
    theoriginalwheelstv New Member
    Hello all,
    I'm probably going to buy a Prius in the near future. I do have a question about the exhaust system. The gas engine is run sparingly. Does the exhaust system warm up enough to dry the water out of the exhaust pipe and muffler?
  2. qbee42
    3,082
    Sometimes, and sometimes not, which is why the Prius uses a corrosion resistant exhaust system.
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    The ice will run long enough to heat up the catalytic converter and that should clear any moisture from the exhaust system. What qbee42 said.
  4. theoriginalwheelstv
    Thanks for the replies. What exactly is a corrosion resistant exhaust system? My first Taurus used stainless steel and that was great.
  5. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    Corrosion resistant exhaust means that it is made of a material that is resistant to corrosion. :D
    Probably stainless.
  6. qbee42
    3,082
    Stainless steel. They were going to use unavailablium, but the supply has been very limited.
  7. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    I checked on unavailablium...out of stock! :(
  8. Spectra
    Spectra Amphi-Prius
    3,123
    17
    S NJ
    mine is kryptonite :eek:
  9. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    :D
    Very good sir!
  10. theoriginalwheelstv
    Thanks for the replies,
    As I understand the exhaust system, it is not made of unavailabium, perhaps it's made of mysterium and maybe stainless steel but nobody knows for sure. Though at least one exhaust system was made of kryptonite but we don't know if that was after market.
  11. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    Regardless of the material used in construction of the exhaust system, keep in mind that the muffler does have certain fiberglass bearings that need periodic inspection, servicing and replacement.
  12. theoriginalwheelstv
    You'all must be from Montana.
  13. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    can anyone confirm if its stainless?
  14. theoriginalwheelstv
  15. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    The NCF says it's stainless, and on close examination of it
    underneath, it certainly looks like stainless that's gotten a
    bit warm on occasion. I'm not 100% certain about the final
    muffler, though, as that's got a bit more rust on it than I'd
    expect. And I think the hangar fittings are generic steel.
    _H*
  16. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    I think Doc Willie's are made of reinforced Dilithium Crystals.
  17. theoriginalwheelstv
    Thanks for looking. It seems a bit odd that it's so difficult to get this basic information.
  18. patsparks
    10,664
    569
    Adelaide South Australia
    I heard as a second choice they looked into an exhaust made from unobtainium but that was also very hard to find so in a fit of madness and completely disregarding for the pollution around nickel mines, they settled for stainless steel. Unobtainium may be near impossible to get but it causes no pollution.
  19. qbee42
    3,082
    Doesn't most unobtainium come from somewhere around Sudbury?
  20. Highly ImPriused
    Highly ImPriused Impressive Member
    250
    Western NY
    My previous car ('99 VW Jetta) had a stainless steel exhaust system that I thought was going to be great (never have to replace it!). Until one day I managed to hit a stray tire on the Thruway. I came up on it just as I was cresting a slight hill and didn't have time to to avoid it all together. I was able to straddle it between my wheels, but it ended up tearing up my exhaust system. Everything from the converter on back had to be replaced. The cost would have been over $1500 to go with OEM stainless steel parts! Fortunately I was able to get it replaced using regular steel for about $200. It was getting pretty rusty a couple of years later, but that's when I traded it it for the Prius. Fortunately they didn't notice on the trade.
