Intermittent Lock/Unlock
Discussion in 'Gen 2 Prius Main Forum' started by jeffg369, Apr 8, 2008.
  1. jeffg369
    jeffg369 New Member
    midwest
    I've owned the car for 6 months so I think I know how to open or lock the doors. The problem happens occasionally - the doors will not lock or unlock when the door handle is held and the button is held in. I'll try two or three times and no go I can lock or unlock the door with the key fob and then the button works. This happens only once or twice a week. Any suggestions/thoughts?
  2. Patrick Wong
    18,200
    6,497
    I assume you have the Smart Entry/Smart Start system with the Smart Key fob.
    When locking the doors, it is not necessary to hold the door handle. It is only necessary to press the black square button.
    If you hold the handle and then press the button, the system might become confused as to whether you are trying to lock, or unlock.
    Try to press the black button without holding the door handle, and see if you still have a problem in locking the doors.
  3. ceric
    ceric New Member
    1,114
    Fremont, CA
    Jeff,
    I want to make sure you know this...
    - when unlocking, touch the inside pad of door handle. No need to press the black button.
    - when locking, press the black button, no need to touch the inside pad (it is OK to touch it).
    This is Toyota/Lexus way of SmartKey.
    Other automakers have slightly different procedures. I hope you are not confused by it. On Mazda, for example, one needs to press the black button no matter one is trying to lock or unlock the doors.
  4. airman
    airman New Member
    Cary NC
    I had the same problem. I was touching the inside of the handle and pushing the button. Just push the button with your finger and don't loop you hand around the handle. This solved my problem.
  5. captnpops
    captnpops Junior Member
    17
    Salt Lake City
    I've had this problem; mine was always linked to my cell phone... ie if my cell phone is in my pocket and fob on the bottom... there's a chance the signal is blocked... every time I pull my cell phone out... the fob works...
  6. jeffg369
    jeffg369 New Member
    midwest
    Thanks all. The cellphone seems to have fixed it. Black button would not work today removed phone from pocket placed it on the ground and pushed black button and door locked. If phone is in shirt pocket - no problem.
  7. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    Interesting, since I have both phone and key fob in my purse, and they're only inches apart, and I haven't had problems.
    The phone is in one pocket of the purse and the keys in another, but I can't imagine that a little thin fabric would make a difference.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    Oh jeez...I've been having the same problem too. I know about the handle thing but the push button to lock has been very intermittent. I go to push to lock and nothing...push again...nothing...push again and it locks...maybe. Thanks alot for your post because I carry my cell phone on the same side as my key fob. I bet thats it. Woo HOO!!! Gonna check it out right now!!
    Just went out to the car and it locked first try sans cell. Awesome! Thanks alot!!!!!
  9. richard schumacher
    7,664
    1,045
    United States
    Anything conductive can have the same effect: a mass of keys, a big ball of pocket change, etc.
  10. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    yet another thing where I thought I was the only one! I have started locking the doors/car by pushing the black button.
    I never push any buttons on the FOB anymore. cool feature that smart key!:pizza:
  11. Grunthos
    Grunthos Senior Azgoth Poetmaster
    81
    Minneapolis, MN
    Why not just lock the door using the lock button that's inside the car as you're opening the door? Then you just close the door as you get out and walk away. No need to hassle with the button at all, or wait for confirmation that the doors are locked.
  12. Sheepdog
    1,125
    Sanford FLorida
    One could. One could also just set the TV remote down then get up to change a channel. But most of use like to use the neat technology!
  13. Grunthos
    81
    Minneapolis, MN
    Not exactly a fair analogy. Using the tv remote is actually much easier than walking up to the tv. It's when the technology actually makes things more difficult and take more time that I'm forced to ask why someone would use it. In this case, you probably waste around three seconds after slamming the door to the car. You need to press the button, then wait to make sure it worked. Whereas I have already locked the door before I've even finished opening it. Assuming I save three seconds each time I get out of the car, and that I drive approximately twice each day (to and from work) and then around six times on each weekend day (give or take), I will have saved about an hour of time each year. If everyone who presently pushes the black button starts using the switch inside the car and they take that hour and volunteer at a food shelf, or something...well, just imagine the impact on our world!
  14. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    pick up the coastal autlock kit. I put mine in a few days back, work's like a charm once you hit about 12mph. took 40 mins to install, only because it was dark when i did it, and was juggling a flashlight. It is a set of simple 18awg wires, and some auto lock unit which is attached with some tap clips that you tap the car's wire's with. It's 65 bucks though...kinda of steep. I suppose if someone was so inclined and knew about real electronics enough they could easily do there own.
  15. patsparks
    10,664
    567
    Adelaide South Australia
    You just blew this weeks time saving typing the response.
    Are you sure the door remains locked after you close the door and does locking the drivers lock all the doors?
  16. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    I usually have things in the back where I need to open the hatchback after the car has been shut off and like pressing the black button from there. Locking the car from the inside would require me to waste time opening the locks again.
  17. Grunthos
    81
    Minneapolis, MN
    I'll climb out the window for the rest of the week to make up for time lost.
    It does stay locked, yes. (And it arms the alarm, too.) I'm talking about pressing the lock-all-doors rocker switch on the arm-rest--not the individual lock for a particular door. The rocker switch locks all doors including the hatchback.
  18. qbee42
    3,079
    That goes against my training which was learned at the school of hard knocks. In a normal car, doing it that way invited locking your keys inside the car. When I did use that technique, I would always make sure I was holding my keys in my hand. With my Prius, I never touch my keys.
    I like pushing the lock button on the outside of the car. It's easy, quick, you don't need to handle your keys, and you get instant feedback on whether it worked.
  19. Grunthos
    81
    Minneapolis, MN
    But I'm not suggesting touching the keys. (I don't touch mine, either.) The only reason people would lock keys in their car is they would leave them in the ignition. But with SKS, that doesn't happen. You know the key is in your pocket, so there's no reason to worry.
  20. patsparks
    10,664
    567
    Yeah I thought about the switch after.
    Funny thing is, just now I went out to my car and unlocked it, opened the door, locked it with the switch then closed the door and the drivers door unlocked. The only way to keep the door locked is to hold out the handle but if I had SKS the act of holding out the handle would have to trigger the unlock door via SKS wouldn't it?
    I guess Australian Prius are different in respect to the locks too.
