Car is acting differently since trip
Discussion in 'Gen 2 Prius Main Forum' started by saminjax, Apr 9, 2008.
  1. saminjax
    saminjax Member
    769
    Jacksonville, FL
    Hello my dear Prius mentors,
    I recently took a weekend trip and drove about 400 miles. I have had my Prius for about a month and a half and have put about 1800 miles on it in that time. Before my trip, my MPG average was about 52. The trip caused it to drop to 49.5. Although my MPGs dropped, I was still pleased to get that average when driving at around 70 MPH the whole time.
    Well, since my return, I've been driving my usual routes and I'm not getting as good of an MPG average as I was getting before my trip. The car is also acting differently. Usually, when I leave home in the morning and the engine is cold, I am able to drive in stealth mode upon leaving my subdivision (takes about 56 seconds to get there, I suppose). Now, I can no longer drive in stealth at all on my way out of my housing development and most of the trip to my son's school and to work, like I used to. It wants to run the ICE, even when the battery is charged up and the engine should be warm. I'm not doing anything differently than I did last week on my routes. I'll take my foot off of the accellerator to try to get into stealth, but the ICE immediately kicks in (a little frustrating). After about 10 minutes of this, it will finally let me stealth. It's as if the engine is taking longer to warm up. The weather has not been colder, still fairly warm (65-75 degrees, depending on time of day). I usually get about 55-60 MPG on my way to work in the morning, but now I can no longer get that and MPG has stayed at 49.
    Can anyone explain this? I want to get back up over 50. :(
    I've already been told by my friend who also has a Prius that I'm obsessed with my MPGs. Maybe so, but she is only getting 45 MPG... :D
  2. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Just a thought: have you checked the tire pressures? They generally seem to have a fairly large effect on mileage.
  3. richard schumacher
    7,664
    1,045
    United States
    Check tire pressures.
  4. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    That is exactly my first thought.
  5. GoBeyondGreen
    GoBeyondGreen Go Beyond Green
    24
    Springfield, MO
    I have seen this as well. What is the optimal tire pressure and i will check mine?
  6. BIGGDOGG
    BIGGDOGG New Member
    298
    Morristown,NJ
    I had a similar problem but that was due to the weather hitting a chilly 15 degrees with a wind chill of 5 degrees. I just suggest to do the same as everyone else said. Check the tires then check the oil.
  7. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Did you fill the tank at a different station?
  8. saminjax
    saminjax Member
    769
    Jacksonville, FL
    Yes. I filled it up on the way home on my road trip. You know, the pump said "less than 10% ethanol." I was going to check on that because I seem to recall some posts here about ethanol, but I forgot about that until you mentioned the gas. Would that be a factor?
    I will check my tire pressure. I haven't done so since I first changed them to 42/40 the day after I bought the car.
  9. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    I've learned a number of things can cause ICE mode. Heater on, air conditioner on, cold starts when the catalytic converter must be warmed up.
    I can't get 50 feet from my house in the morning without the ICE starting and running for 5 minutes. I also have a short drive at 15mph in my mobile home park; sounds something like your situation.
    I think it's normal behavior.
  10. dogfriend
    7,512
    1,190
    Carmichael, CA
    Less than 10% is probably 9.9999% ethanol. Yes, it could be a factor if you were previously using gas that did not have ethanol.
    And just to be consistent with everyone else, check your tires. :D
  11. Michou
    Michou Member
    Oakland, CA
    I agree with everyone else that tire pressure has a pretty big impact on your overall mph, as does how much weight you carry in your car, and the type of gas you use. However, to get a very accurate idea of what your mph is, next time you fill up write down your mileage, then when you are down to empty again compare with your current mileage to find out what you are getting mileage wise.
    The fuel guages and nav screen consumption display aren't always the most accurate.
    Best,
    Michou
  12. saminjax
    saminjax Member
    769
    Jacksonville, FL
    Well, I've not been running the heater or air conditioner. Even with the air conditioner on in the past, however, I could stealth from the stoplight leaving my housing area. Now, I have to wait 10 minutes into my trip to do so. Something changed.
  13. qbee42
    3,079
    Just to make sure we are on the same page, here is what should happen when your power up your Prius:
    1) Power up; idiot lights flash, MFD comes on.
    2) In about 20 feet or 15 seconds the engine (ICE) comes on.
    3) The ICE stays on until the engine and catalytic converter heat up, AND you come to a complete stop.
    4) After the complete stop, and with a warm engine, the Prius will run for short intervals in EV mode, assuming the following:
    a) Good SoC.
    b) Warm engine and catalytic converter.
    c) Low power demand.
    d) Low speed.
    5) When any of the above are no longer true, the ICE will come back on.
  14. saminjax
    saminjax Member
    769
    Jacksonville, FL
    Sounds about right. I'm doing everything I was doing last week, but the ICE is acting differently. Wants to be on all the time for the first 10 minutes. I will, however, be mindful of coming to a complete stop. I have several stops on my route (stoplights, stop signs, other drivers, etc.). Thanks for the info.
  15. FBear
    FBear Senior Member
    355
    Maplewood, NJ
    2015 Prius v wagon
    I suspect that the reason your gas mileage dropped was the last fill-up contained ethanol which will lower your overall mileage.
  16. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    is it possible that you haven't reset your MFD by pressing the reset button and you may be seeing the trip avg combined with your local avg.
  17. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    Double check that your front and rear defrost is off. I had the same problem when I first got my car. I am not talking about the temperature or the head/foot selector. On the bottom of the screen are the 2 defrost switches. If either is on then the car will act this way.
  18. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    This is the perfect opportunity to point out the new ENGINE AIR-FILTER illustrated section in the User-Guide (pages 29-30).
    Build up of crud on that filter will have a negative impact on efficiency.
  19. richard schumacher
    7,664
    1,045
    United States
    Ethanol has about 70% of the energy content of gasoline, so E10 has about 3% less energy that pure gasoline and MPGs should decrease by only that same amount; in this case from 52 MPG to maybe 50 MPG.
  20. saminjax
    saminjax Member
    769
    Jacksonville, FL
    Umm...yeah, that is certainly possible. I've never reset my MFD. I've only had the car for a little over a month, though. 49.6 is my lifetine average, everything and the trip included. I thought I should leave it as is, so that I would keep my lifetime average displayed. That's the reason why it hasn't climbed up yet, I'm sure. However, my MPGs have been consistently lower with my ICE engine running more.
    Also, I do have ethanol gas in the car (less than 10%, according the pump.
    I will definitely check the tire pressure again and avoid ethanol-laced gas in the future, but I still don't understand why the ICE is being so stubborn about running longer. If I have the battery fully charged and I've been driving it for a few minutes, it should let me stealth, right? That is the main thing that's bothering me. It wasn't doing that last week, but it is now. After about 10 minutes, it will let me stealth, but before then, it stubbornly comes on when I am trying to stealth drive. Last week and before, it would let me stealth after approximately one minute. My drive to my son's school and to work is mostly 30-35 mph driving, so I can potentially get a lot of stealth driving in if the ICE will lay off. Maybe it will get back to normal in a couple of days - perhaps it is some kind of fluke after its first long trip. Before the trip, I had not run it at speeds over 60 mph for any consistent length of time. My trip was three hours each way and ranged between 65-70 mph.
    Thanks for all your input, everybody. :)
