mpg?
Discussion in 'Gen 2 Prius Main Forum' started by halleyscomet, Apr 10, 2008.
  1. halleyscomet
    halleyscomet New Member
    36
    Southwest PA
    My display read 48.7 mpg, on 398 gallons of gas
    down to 1 bar so I filled up, 9.49 gallons.
    Something is off..
  2. strider5
    strider5 New Member
    Philly
    something is definitely off, but I dont think it's your car ;)
    (hint: 398 gallons of gas) :D
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Nothing is off. There's a bladder in the gas tank.
  4. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Nope, nothing is off. Sounds about right.
    I assume you mean 48.7 mpg on 398 miles, that the gas gauge was down to 1 bar (pip), and that you managed to get 9.49 gallons into the tank when you filled it up.
    One pip on the gas gauge sounds like a good time to fill up. Adding 9.49 gallons when the gauge shows one pip is not unreasonable. 48.7 mpg seems resonable depending on your personal driving habits, topography, prevailing weather, etc. And 398 miles on one tank when you are getting 48.7 mpg isn't surprising either.
  5. mrblaise
    mrblaise Go Lakers!!
    2,248
    525
    Southern California
    That's a huge tank! Must be the European model. ;)
  6. ceric
    ceric New Member
    1,114
    Fremont, CA
    I think the OP meant
    398/9.49 = 41+mpg while the computer shows 48+mpg. Something is off.
    I am guessing that you are using the fill-up method to compare the computer MPG.
    Two factors here:
    - the pump click-off points are different from station to station, even pump to pump
    - the bladder can change its volume depending on temperature
    Combining both, you could see 10% error. However, I can't explain the big difference
    you are seeing. Maybe .... don't go to that station again. Their pumps seem to be off the chart. Usually when the final pip blinks, I can only put in around ~9 (US)gallons.
  7. richard schumacher
    7,666
    1,047
    United States
    Trust the MFD. The amount of gas you put in at the last fillup is almost never the same amount as you have actually burned since the previous fillup, so the manual method will always be inaccurate for a single tank. The variable-capacity tank bladder in the Prius makes this effect much larger than for non-bladder cars.
