cleanmpg.com
Discussion in 'Newbie Forum' started by sleonardelli, Apr 13, 2008.
  1. sleonardelli
    sleonardelli Junior Member
    141
    Ruskin Fl
    I've searched this site and would like to use the database however I cannot find where I register my car. Any suggestions?
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Uh ... because this is priuschat, not cleanmpg?
    _H*
  3. sleonardelli
    141
    Ruskin Fl
    Please allow me to clarify; I have notices many posters have cleanmpg.com badges and have talked about using the cleanmpg.com database to their mileage. I was hoping one of the gurus who use cleanmpg.com would be able to assist me in registering.
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    GreenHybrid.com has a database as well. It was easier to sign up for IMO.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Just go to cleanmpg.com and you'll go through a nearly identical registration process as you did for Priuschat. Once you do that look for the 'mileage database'. that's where you put your car's vital stats and enter your mpg data. There's plenty of useful threads to walk you through the process. Once that's done you just grab the url for the little mpg chart and come back here and paste that into your signature (under usercp above).
    As mentioned http:// Greenhybrid.com is easier to enter, but doesn't allow you to give specifics such as the date of the fill up and such...so it doesn't chart by temp or month or anything like that. There's another site that has the same kind of deal... Ecomodder.com Fuel Economy Forum , I haven't used that one so don't know how good it is.
  6. sleonardelli
    141
    Ruskin Fl
    Was able to register Green Hybrid using F8L as the referrer. Still can't find a register link on cleanmpg.com
    Thanks for the help! I plan to use all three sites to help build my experience with fuel economy (among other things).
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    Glad you got it set up. :)
    Liek Evan said, Cleanmpg has the date tracking portion with is nice to track MPG changes with temp changes (if all else is kept equal).
  8. efusco
    19,891
    1,196
    Nixa, MO
    Wow, it was a little hard to find...
    CleanMPG Forums - Register
  9. sleonardelli
    141
    Ruskin Fl
    Thanks so much! I am now registered at cleanmpg.com!!!
