intro & question about EBH in an 08
Discussion in 'Newbie Forum' started by earthman, Apr 12, 2008.
  1. earthman
    earthman New Member
    47
    Vermont
    Third time's the charm? Let's hope so. First time I wrote a bunch then thought I'd look at one of the similar threads. Of course when I came back what I had written was gone. So I start over, tried to cover the same stuff but an expanded version. Went to submit the new thread & discovered I was not logged in, lost what I had written again. That was all earlier today..........and now.
    Hey folks, writting to say "hello" from central Vermont. The last forum I was on was a BMW K1200RS site. I haven't been there in years, mostly because I'm not riding anymore. Not because I don't want to, just not up to the challenge at the moment. So here I am, K bike to Prius, that's a quantum jump.
    Actually I'm replacing a seldom used Chevy Trailblazer with the Prius. The price of gas & living 40 miles from everything, who can afford to run a Trailblazer. Having so far to travel for anything is sometimes a good thing, sometimes not. Skiing is nearby, thats a good thing. So replacing the gas guzzler & maybe balancing my use of a Ford Diesel F350 for work is the impetus for purchase of a Prius. I know, I know, it's for work, a necessary evil.
    I'm getting the Prius sometime next week, waiting for a dealer swap. I stopped at the dealer today and asked him to throw in a block heater to maximize effiency & so I'd have heat right from the get go. He brought me back to the parts counter & the guy behind the counter asked why a block heater. I explained what I've read here & he claimed that was not needed for the 08's. Is this correct? Are they just looking to not throw in a $60.00 item?
    I'm probably not in the right forum to be asking questions. But at this point the real question is, will this actually get posted......third time is supposed to be the charm.
    Thanks
    I was going to spell check this, I'm just afraid to screw around too much. So here goes.....................
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    You can pretty much expect that response from every dealer. They say it isn't necessary b/c the Prius has the thermos to store the hot coolant. But the EBH can help. It certainly is not 'necessary' by any stretch, but if you want heat quicker in the winter and better MPG year around it's a nice little addition.
    I suggest buying one for $35/$40 here or elsewhere and installing yourself or get a neighboring Prius owner who's done one before to install it for you...probably for the cost of a brew and some friendly conversation...if you can afford that!
  3. earthman
    earthman New Member
    47
    Vermont
    Thanks efusco, that's exactly what I want, heat quicker & better mpg's. It's hard to believe the dealers are not "on board" with that. Yup, I can indeed afford the beer & babble, no problem with that. It's the Trailblazer & F350 I'm having trouble with. For instance, this was about a month back. Went to the local service station & filled my diesel F350, fuel cost $3.99/gal. Two weeks later, maybe a bit longer but not much, I needed fuel again. Went back to the same station & fuel was now $4.49/gal. It had gone up .50 between fill ups! At that rate.........it could get expensive fast. Beer & babble, oh yeah, plenty to go around.
    Thanks for your reply.
  4. earthman
    earthman New Member
    47
    Vermont
    Hey Doc (efusco)
    Hope you don't mind my calling you that, think I saw it somewhere on this site. I see you have that BT Skid plate, wondered how you like it. Does it affect your mpg's at all? I live a few miles up a dirt road, this time of year lots of ruts & worse. I'm afraid the plastic panel I presume they have under the motor won't take much scraping & bashing. This panel looks to be just what the doctor ordered.
    Comments?
  5. efusco
    19,891
    1,192
    Nixa, MO
    No affect on MPG that I can discern. I think if you have a rough road it's a good idea. I'm glad to have it there...just a little added insurance, but I doubt I'd ever truely "need" it...but you never know. Just to add, I like having it to reduce the air circulating around the engine in cold weather...much like the grill blocking it helps create a bit of a pocket of air that will stay warm and that may help improve winter FE.
  6. road__rider
    road__rider Junior Member
    27
    Tacoma, WA
    Hey Earthman,
    I bought my 08 in September of last year. I read as much about the EBH as I could find on the site before I ordered mine. When it came, I procrastinated for another couple of months before I decided to give it a try.
    I printed out a couple of do it yourself instruction articles from this site. I think it was Green Hokie's (I hope I got that right) that I ended up using. It went exactly as he described. The hardest part was connecting the wire after the heater was clipped into the block. Total time was less than an hour, start to finish.
    The EBH and the grill blocking made at least a 5 to 7 MPG increase. Don't listen to the dealer......it WILL help!
    Good Luck
