RAZR V3 Auto Connect Problems
Discussion in 'Gen 2 Prius Audio and Electronics' started by alkarajo.com, Mar 26, 2007.
  1. alkarajo.com
    alkarajo.com New Member
    I had a Motorola V600 and it worked fine with the Prius Bluetooth system. I upgraded my phone to RAZR V3 and I got problems.
    I can REGISTER (pair) the RAZR V3 with the Prius. However, it does not reconnect automatically.
    Any suggestions?
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(alkarajo.com @ Mar 26 2007, 07:35 PM) [snapback]412663[/snapback]</div>
    What carrier is your phone on? You may have manually turn on Bluetooth on the phone.
    On my Sprint Motorola Razr V3m, if Bluetooth isn't already on for an existing connection (or an earlier attempt), it'll shut BT off after a few minutes.
  3. alkarajo.com
    <div class='quotetop'>QUOTE(cwerdna @ Mar 27 2007, 03:57 AM) [snapback]412801[/snapback]</div>
    I use Cingular. With the same SIM card on my old Motorola V600 it works fine. But with the Razr V3 it does not connect automatically.
    I have Bluetooth on all the time.
    It does disconnects - so may be I have to give it more time to connect...I will look at the phone to see if there is a parameter for pairing time.
    Thanks.
  4. alkarajo.com
    <div class='quotetop'>QUOTE(alkarajo.com @ Mar 27 2007, 09:11 AM) [snapback]412840[/snapback]</div>
    I have just tried the RAZR V3 with Car Settings->Power-Off Delay in Automatic and 15 minutes - and no luck. It still disconnects.
    I also tried my V600 (which has Car Settings->Power-Off in 15 minutes) and it works fine.
    The RAZR V3 has to be registered manually. When I restart the car, the and BT comes back up the RAZR V3 DISCONNECTS!!!!!
    Any suggestions welcome!
  5. GKarschnick
    GKarschnick New Member
    Melbourne, FL
    <div class='quotetop'>QUOTE(alkarajo.com @ Mar 27 2007, 08:59 AM) [snapback]412854[/snapback]</div>
    Make sure that your RAZR Bluetooth is powered on. Go to settings, then connections, then select bluetooth link , then setup, then check that power is on.
  6. onerpm
    onerpm New Member
    477
    MN
    I seem to recall having a similar problem with my wife's RAZR, and then discovered that the "auto connect" button was not enabled in the car's bluetooth/phone setup page. It now works fine, connects every time (this is to her HyCam, though).
    For my blackberry to autoconnect to my Prius (or anything else), I also had to go into its (the blackberry's) bluetooth settings menu, find the Prius (once they had been paired), and change the "trusted" setting from the default of "no," to "yes." I don't recall that the RAZR had a "trusted" setting in its menus, though.
    rpm
  7. alkarajo.com
    <div class='quotetop'>QUOTE(onerpm @ Mar 27 2007, 11:33 AM) [snapback]412920[/snapback]</div>
    I do have the AUTOCONNECT ON on the BT. I do not see a TRUSTED option on the RAZR.
    Thanks.
  8. alkarajo.com
    <div class='quotetop'>QUOTE(alkarajo.com @ Mar 27 2007, 01:01 PM) [snapback]412986[/snapback]</div>
    This is how I solved the problem:
    1. Put the RAZR in its original Box.
    2. Closed the box
    3. When to the Post Office and
    4. Sent it back to Amazon.com
    I went back to my Motorola V600 that works great with the Prius.
  9. TheAnnoyingOne
    TheAnnoyingOne New Member
    318
    -118.15476, 34.112134
    Mystery solved ! :rolleyes:
    I was wondering who might have bought the Razr that I returned to Amazon some time ago. :lol:
  10. zijlstra
    zijlstra New Member
    30
    <div class='quotetop'>QUOTE(alkarajo.com @ Mar 27 2007, 12:01 PM) [snapback]412986[/snapback]</div>
    Did you make sure to select the RAZR as the primary phone? If you register several phones with the vehicle, you need to select which one to make primary to use. The system only works with one phone at a time.
  11. thomsentj
    thomsentj Junior Member
    I have a Blackberry Pearl. It was Autoconnecting fine when I first bought it and sync'd it with my Prius. It was working for about 5 months. Now I'm having the same issues as people mention above. I have deleted the profiles both on my Prius and phone, and re-registered the phone. It connects initially, but won't Autoconnect. The car is set to Autoconnect. The phone "Trusted" option is set to Yes. I haven't found any blog/forum posting that has correctly identified this issue. A pain in my butt.
    Any help is appreciated.
  12. mglindsey
    mglindsey New Member
    Milwaukee, WI
    I understand the frustration, but sending the phone back is only one option. IF you want to keep the phone I assure you that it works. I have had 2 Razr V3m (my first was stolen). The newest Razr (purchases in Feb '08) has different firmware - but Bluetooth connection was still easy and possible. I'm sorry I don't remember specifically how I set it up, but I know you need to go into service discovery mode on the phone and then set it to have Bluetooth on all the time. Then you need to go to the car's telephone security/recognition screen and any security settings between both need to be compatible.
    IT WILL WORK... i promise!
  13. Scott_R
    Scott_R Member
    443
    Long Island
    2024 Prius Prime
    The OP wasn't having problems setting it up, it was the Razr then connecting automatically after the initial pairing. I'm having the same problems, detailed here. As I note there, I put the SIM into a Samsung SGH-T329 and it re-connects perfectly. Since the Razr isn't reconnecting with two different cars (albeit both Toyotas) I'm guessing it's a V3 issue.
  14. Joekc
    Joekc Member
    265
    My wife's Razr V3 and my Blackberry Pearl 8130 both auto connect every time, so it can be done (Verizon). Since it's been 8 months since I set it up, I can't tell you the exact procedure, only that it's possible.
    Also, remember if you have two phones registered and you switch users, you have to go deep into the menu system to manually change users. I really hate this -- it's totally unacceptable in a technically sophisticated car.:(
