PIAA Sports Horn
Discussion in 'Gen 2 Prius Accessories & Modifications' started by olmanwompa, Nov 7, 2006.
  1. olmanwompa
    olmanwompa New Member
    Over the weekend I installed a PIAA Sports Horn. The plan was to provide pictures, but the reality is, the install was super easy and uncomplicated-took about 20 minutes total. I anticipated having to relocate the second horn due to space issues, but the both fit perfectly in the original horn locations. Basically, just disconnect the old horns, and connect the new ones-same wiring, same position, MUCH improved horn. I picked one up after internet searching for $35 shipped. See horn install for pics of similar install (again- these horns fit in stock locations, no need to relocate the second horn).
  2. H2OSkier
    H2OSkier Member
    276
    Did you happen to compare the sound to the JDM horn from Sigma Auto ? I'm curious how the sound of the PIAA compares. The horn is on my list of gotta change items.
    Ken
  3. Ari
    Ari New Member
    165
    <div class='quotetop'>QUOTE(olmanwompa @ Nov 7 2006, 11:58 PM) [snapback]345288[/snapback]</div>
    Where did you order these horns? Thanks.
  4. olmanwompa
    i ordered mine about 4 months ago from lightning motorsports. i see they now charge for shipping. i have to say, it wasn't the easiest transaction, as i never received any confirmation of my order, shipping was delayed, and they never responded to emails. the item did arrive, however, eventually. you may find a better deal or site elsewhere. i did not compare the sound of this horn to the jdm horns, though i heard the wav files at the sigma site. this horn sounds like a german car, and is not super-loud, but louder and more masculine than the stock horn.
  5. richard schumacher
    7,664
    1,046
    United States
    So the PIAA horns just plug into the original wiring connector?
  6. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(richard schumacher @ Nov 21 2007, 12:30 PM) [snapback]542564[/snapback]</div>
    +1 Is it truly a plug-and-play install?
  7. CDAVIDANDERSON
    CDAVIDANDERSON Junior Member
    <div class='quotetop'>QUOTE(H2OSkier @ Nov 8 2006, 09:28 AM) [snapback]345495[/snapback]</div>
    Amazon sells them for $39, free shipping for Amzaon Prime members. They actually have two kinds, one with 400 & 500 Hz horns, the other with %00 & 600. For some reason, this latter one, which I assume is higher pitched, is much more popular. Anybody have any idea what the sound difference is like?
  8. patsparks
    10,664
    567
    Adelaide South Australia
    Most likely stupid people think the bigger numbers mean louder.
  9. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    I like the sound of the 500/600, but then again I am not very bright.
  10. blamy
    blamy Member
    380
    Central Florida
    LOL; right on brother!!!
  11. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
  12. SgtTurtle
    SgtTurtle Junior Member
    Chandler, AZ
    I just installed the PIAA Sport Horns 500/600 tonight. I installed them in the stock locations and it took about an hour. Sounds way better then the wimpy horns the Prius came with.
    I made a short extension for each of the power wires using a male prong to fit into the stock wiring harness and an insulated female prong to fit on the horn. I attached the included grounding wires to the mounting bolts. I was able to get better access and retrieve dropped items by removing the grills by the fog lights.
    This morning, I had to honk (with the stock horns) at a woman who tried to change lanes into me; my 9 year old and 7 year old daughters both agreed that the stock horns were wimpy. Now, in a sick way, I almost can't wait for the opportunity to honk at someone with my new horns. :D
  13. yams69
    yams69 Junior Member
    Bucks County, PA
    I also discovered mid-install of my PIAA 400/500 horns that I needed an extension for the 12V cable. I mounted mine in the stock locations, and in both places the 12V cable was just about an inch or two too short to get it on the horn without putting a lot of strain on the wiring harness. (On the stock horns, the electrical connection is pointing down, whereas the connections on the PIAA horns point up, so you need a slightly longer cable.)
    Fortunately, the grounding wires included with the horns are way too long, so I cut them to size for the ground connection and used the remainder for the extension cable. I used the male lugs from 1/4" insulated crimp-on quick disconnects from Radio Shack (part 64-4040) for the end on the wiring harness and the female lugs from 1/4" fully insulated crimp-on quick disconnects from Radio Shack (part 64-3133). You could probably get the job done with the former only, since I doubt it matters if the ground connection is exposed. Each package is only $1.99, and I would highly recommend having them on hand just in case you also find that you need them.
    I didn't have to pop the whole grill off to get the horns in place, but I did remove all the top fasteners on the grill to pull it forward enough to access the area in which the horns are mounted. I observed at the end of my install that the connectors on the passenger side are jammed against one of the braces. Hopefully there will be no long-term heat issues for the wiring because of that.
  14. hackIT
    hackIT Oceanic Member
    98
    Central Florida
    I just installed the PIAA 400/500 Hz horns this morning... what an improvement! I found them on Amazon for $40.77 with free shipping.:)
  15. chinalfr2
    chinalfr2 Member
    234
    New England
    I installed the PIAA 500/600 Hz horns. No problem with the installation. No need an extension and pretty much straight forward install. The horn sound meaner now. :D
  16. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I gotta agree, the 500/600's do sound much better than the stock horns!!!
    Simple install. I made jumpers to extend the wires, but thats just me, it will work OK with out the extensions!!
    But by all means, upgrade the horns!!
    You will be glad you did. And yes, I got mine from Amazon, FREE SHIPPING, good price!!
    73 all de Pat KK6PD
  17. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    That could have been a good opportunity to educate some of us about sound instead of calling those who do not know or have never heard of decibel ratings stupid....just a thought.:)
  18. KK6PD
    4,003
    946
    118
    Sound pressure level
    Sound pressure is defined as the difference between the average local pressure of the medium outside of the sound wave in which it is traveling through (at a given point and a given time) and the pressure found within the sound wave itself within that same medium. A square of this difference (i.e. a square of the deviation from the equilibrium pressure) is usually averaged over time and/or space, and a square root of such average is taken to obtain a root mean square (RMS) value. For example, 1 Pa RMS sound pressure in atmospheric air implies that the actual pressure in the sound wave oscillates between (1 atm [​IMG] Pa) and (1 atm [​IMG] Pa), that is between 101323.6 and 101326.4 Pa. Such a tiny (relative to atmospheric) variation in air pressure at an audio frequency will be perceived as quite a deafening sound, and can cause hearing damage, according to the table below.
    As the human ear can detect sounds with a very wide range of amplitudes, sound pressure is often measured as a level on a logarithmic decibel scale. The sound pressure level (SPL) or Lp is defined as
    [​IMG] where p is the root-mean-square sound pressure and pref is a reference sound pressure. Commonly used reference sound pressures, defined in the standard ANSI S1.1-1994, are 20 µPa in air and 1 µPa in water. Without a specified reference sound pressure, a value expressed in decibels cannot represent a sound pressure level. Since the human ear does not have a flat spectral response, sound pressures are often frequency weighted so that the measured level will match perceived levels more closely. The International Electrotechnical Commission (IEC) has defined several weighting schemes. A-weighting attempts to match the response of the human ear to noise and A-weighted sound pressure levels are labeled dBA. C-weighting is used to measure peak levels.
    Examples of sound pressure and sound pressure levels
    Source of soundsound pressure level dB
    Nuclear Weapon explosionapprox 248
    Krakatoa eruptionapprox 180 at 100 miles
    Stun grenades170-180rocket launch equipment acoustic testsapprox. 165
    threshold of pain134
    PIAA 500/600 115
    jackhammer, 1 m distant / discothequeapprox. 100
    hearing damage from long-term exposureapprox. 85traffic noise on major road, 10 m distant80–90moving
    automobile, 10 m distant60–80 TOYTOTA STOCK HORN
    TV set – typical home level, 1 m distantapprox. 60
    normal talking, 1 m distant40–60
    very calm room20–30
    quiet rustling leaves, calm human breathing10
    auditory threshold at 2 kHz – undamaged human ears0
    IN SHORT THE MORE THE dB RATING, THE LOUDER THE SOUND
    IT DOESN'T GET SIMPLER THAN THAT!!!
    73 DE PAT KK6PD
  19. DIV
    DIV New Member
    35
    Seattle
    I just received my PIAA sports horns and I ran into problems. This is NOT an easy install, not for me anyway. I'm a pretty accomplished dentist and pretty good handiman. The grilles were quite hard to remove and I broke 2 clips despite my best efforts--that plastic is super soft.
    Then I would have needed to do some major wiring work. Let me explain.
    The stock horns are each attached by a single plug connector. The PIAA's use 2 blade connectors and I would need to splice the stock wire to a female blade connector. The PIAA packaging only included 2 connector wires, and you need 4 since each of the 2 PIAA horns has 2 blade connections.
    So, my question is: **did your PIAA's come with single slot connections like the stock ones or the double blade connectors that require some splicing??? I can't imagine splicing wires and crimping connectors in that very tight, limited space even with the grilles removed.
    Please help!
    thanks!
  20. KK6PD
    4,003
    946
    118
    Actualy it's a rather EASY install. I took 20 minutes, did not have to use "Novacaine" either... of course a couple of beers helped!!
    Why did you remove the grill, that is just NOT necessary!
    The existing wires if routed correctly will fit 1 spade lug on the horn, the other lug goes to car chassis ground, about 5 inches from the horn.
    I reused the existing holes, used their wire to go to the mounting screw hole for the horn gnd lug, that's ground.
    Just because I could,I made a 3" cable with a Male/Female Spade Lug, an "Extension Chord" so to speak, for the existing power plug for the horn, which will fit on the PIAA lugs, plugged it together, ALL With the Grill on!!!
    Works Great!!!
