information screen replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by wreckdiving, Feb 22, 2008.
  1. wreckdiving
    wreckdiving New Member
    ny
    Last week I asked for advise on installation and removal of Multi information screen. Thanks to all for your help. Now my problem is I had recently installed a replacement bought on ebay, same model #, same unit. Same problems!!! Whats the chance of buying another sour screen, or is there a reset somewhere on unit? Seems like a no brainer just unplugging and replugging, am I missing something??? Is there a way of checking units to make sure the screen is bad prior to contacting seller for a refund.
    Thanks,
    Ron:(
  2. richard schumacher
    7,686
    1,068
    United States
    The classic fault takes a few minutes of careful dis-assembly and soldering to fix. I'd bet a Prius technician or geek could make a few hundred or thousand bucks on the side by repairing dead ones.
  3. PRIUS PARTS KING
    PRIUS PARTS KING New Member
    winnipeg, mb canada
    what is the classic fault that has to be done here? split wire? or ?
    thanks
  4. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    Well, nobody's sent me any MFDs to be repaired yet...
    _H*
  5. richard schumacher
    7,686
    1,068
    United States
    I expected hobbit to jump up here with a pointer to his excellent diagnosis webpages (I don't have it bookmarked)... One of the original circuit boards had an incorrect design for the attachment of a mezzanine board connector. This allowed the solder joints of this connector to break under repeated stress (apparently, most likely thermal stress). Dis-assembling the thing and re-soldering the connector repairs it.
  6. hobbit
    4,089
    470
    Bahstahn
    I try to strike a balance between tooting my own horn and shoving
    obvious URLs down everyone's throats at the slightest opportunity,
    and letting folks research these things for themselves and maybe
    find a variety of references. At this point in time if you google
    for "hobbit" and "prius" I'm usually the first hit, which is
    rather gratifying but may not last forever and heck, that's
    probably a fairly obscure combination of words. But if that
    works, then a couple more clicks away is the link-farm to many
    other resources or some of my own stuff. One string search for
    "MFD", and there it is.
    I guess I see the Prius as a tool to teach people to fish. Or
    drive better. Or something..
    _H*
  7. richard schumacher
    7,686
    1,068
    United States
    Do you re-work them as they come in, or do you sell them (and so presumably keep one or a few on hand ready to go)? If it becomes necessary I'd be happy to buy one from you as long as I don't have to ship mine to you to be reworked and returned. A gaping hole in the dash for some days and two trips to the dealer, for removal and installation, would be too annoying.
  8. hobbit
    4,089
    470
    Bahstahn
    If that was to me, well, I have no stock on hand. You might
    be able to ask "p626808" if he'll sell you the one I reworked,
    which as far as I know he still has. Steve at Autobeyours is
    probably starting to get into the game and he certainly *does*
    have stock of the units, probably at both ECO levels.
    _H*
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Given your obvious depth of technical experience in general electronics and the Prius in particular, I certainly do NOT see it as "tooting my own horn." The few times I have had an issue or question, your reply has been prompt and courtious.
    You could really clean up just refurbishing MFD's. Or set up something like a Hybrid Tech Training roadshow. The genuine THHT or Panasonic ToughBook version are still priced +$5,000, with yearly TIS subscriptions around $1,000.
    No reason why you can't charge to cover the cost of such an investment
    So keep tooting that horn!
  10. imwoody36
    imwoody36 the prius parts guy
    143
    116
    southern Indiana
    Thank you Hobbit, I have added MFD repair to our services. Your research has been instrumental to the community. I look forward to another visit when we test drive the new pluginsupply 5kw battery pack.
    anyone interested may visit autobeyours.com/priusparts.htm
  11. richard schumacher
    7,686
    1,068
    United States
    Hobbit's work shows pretty convincingly that the problem was an error in the design of the solder footprint for a particular connector on one circuit board. See
    Prius MFD
    The circuit board was redesigned for '05 or '06, and these newer units do not have this failure. If you do have this failure on an '04 or an early '05 it is possible to fix it yourself, or have it fixed locally by someone who can remove the unit (a dealer, if nothing else), and someone handy with a soldering iron.
  12. BerkshirePrius
    BerkshirePrius New Member
    121
    Berkshire, NY
    Do you by chance have a Dice Ipod kit in your car? If so try unplugging it. Here is a link to my experience with a failed MFD screen over the last few days: http://priuschat.com/forums/care-ma...d-replacement-screen-question.html#post601699
