"Doggie in the car Mode"-- READY Mode, AC On & Remotely Lock doors?
Discussion in 'Gen 2 Prius Technical Discussion' started by bob749prius, Apr 21, 2008.
  1. bob749prius
    bob749prius Junior Member
    33
    Venice, FL
    2018 Prius
    This Summer when it is HOT out and our pets are in the car, we want to be able to keep the AC on while the car is in READY mode with the doors LOCKED. Will be be able to LOCK the car doors before we walk into McD and able to have the ICE keep the system running if needed without worrying someone might want to steal Fido? I know 1st we would have to disarm the remote entry system and use the key for re-entry but is the above possible?
  2. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    To leave my Prius running I do the following. First off I make sure the keyfob is in my pocket. I then roll down the drivers window. I exit the vehicle and close the drivers door. I reach in and hit the door lock to lock all the doors. I then hit the auto-window up and yank my head out before it get's caught in the window. ;) The vehicle is now running with all the doors locked.
    When I get back I use the metal key from the fob to open the door.
    Keep in mind if someone broke in to your car they could drive away without the fob. This is unlike my other vehicle where the car will idle (for up to 10 mins) without the keyfob but the moment someone tried to put it in gear and or touched the accelerator the car will shut off.
    Mike
  3. b777
    b777 New Member
    24
    Just leave the car running, use the lock on the door panel to lock all the doors then unlock the drivers door manually, get out of the car, take the key out of the key fob and lock the drivers door manually using the key. You must also use the key in the key fob to unluck the door. You may want to put a sign in the window if you cannot see the car as someone may call the police. Here in the Fort Worth area the police will break the window if they see a dog in the car with windows rolled up.
    We do this all the time, but I always try to be able to see the car. I also make sure the dog has water. I bought a rear seat deluxe car seat cover from Petsmart that covers the entire seat. I sprayed it with scotchgard and my German Shepherd has no problems sleeping in the back. You probably want a good seat cover since the leather is pretty thin.
    George W and Dutch like this.
  4. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    Interesting. I forgot about the car not necessarily running with the A/C on and what people outside the car may think if a dog is in the car. I suppose I no longer have a dog and never used to leave him in the car anyway because I didn't want my interior torn up. :cool:
  5. Prius Prime
    Prius Prime Junior Member
    68
    Macomb, MI
    2016 Prius v wagon
    Just make sure your dog doesn't know how to drive! ;)
    I've seen news stories where the dog has accidentally moved the car. In the Prius they probably won't be able to figure out how to move the lever to get it in drive, while having their paw on the brake.
    Hey, another safety feature! Probably keeps kids from "driving" too.
  6. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Hmm, you got me wondering now. Can I, or my dog, shift the car from Park to Neutral without putting a foot on the brake? I know I need to press the brake for Drive, but I can't remember if it's necessary for Neutral.
    Definitely want to put up some sort of sign. Many people are unfamilliar with the Prius and when they don't hear the engine running, they're likely to assume that the A/C isn't running.
    You shouldn't need to disable the SKS. Just use the metal key to lock the doors from the drivers door after you get out of the car. This will lock all the doors in the car and the car will then only unlock with the metal key. I'm pretty sure the SKS won't work to unlock the doors from outside the car, and the button on the fob won't work to unlock them either. I'm less certain what would appen if the dog manages to figure out how to lift up on the lock lever on the armrest.
    Speaking of the armrest, keep in mind that if the dog accidentally steps on the window button while watching the world outside, he might open the window. You can reduce the likelihood of this by using the window lock on the drivers door armrest, but that doesn't lock the driver's window. So, if the dog manages to make his way to the drivers seat, he can still accidentally open the window.
    If you are not going to be within sight of the vehicle, you may want to include a cell phone number on the sign. This way if something should go wrong (dog opens window, car breaks down, dog appears uncomfortable, etc) anyone who notices will have some way of contacting you.
  7. aDogsLife
    aDogsLife New Member
    Pittsburgh
    Those are all great ideas for how to keep my pups safe this summer. I have four dogs, two labs, one yorkie (wife's dog) and another that we have no idea what he is and he isn't telling. . .
    All this talk in the last couple of posts about having a dog shift the car to make it move has me thinking about the opposite. What would happen if we are cruising down the road and all of a sudden the little rat dog, uh, I mean yorkie hits either the park button or the power button?
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I believe the car shifts into Neutral. You can practice this (and the recovery) at low speed in an empty parking lot.
  9. PriuStorm
    PriuStorm Senior Member
    2,239
    149
    Davis, CA
    Hey, I just wanted to mention one time we left our pug in the car (car off on a cool day in February) while we went in to a tile shop to look at tile. Somehow, we had forgotten one of the FOBs in a bag in the car.
    Anyway, I happened to look out the window of the store, and lo-and-behold, the windshield wipers were on! Our pug is looking out the front window, and she looks a little distressed, so I go out there. Not only are the wipers on, but the radio is on, and very loud.
    Apparently, she had watched us go into the store, then stood up with her front paws on the dash and had been pushing the power button, activating the windshield washer lever, and what not! Probably when things started moving by themselves (the windshield wipers) and making noise (the radio), she got a little surprised and probably scared, too. :D In retrospect, it was kind of funny. Naturally, I removed the FOB and went back in the store after making sure she was calm and ok.
    The moral: Yes, be careful about the dog pressing the buttons and accessing the controls. I think if I had backed into the spot, she would probably have occupied herself looking for me out the back window, and would have left the dash alone, but I don't know that for sure, of course. :)
  10. neon tetra
    neon tetra Member
    309
    Do yourself & the planet a favor though & go somewhere other than McDonalds ;)
  11. Linden
    Linden New Member
    47
    For the window lock button - I call it the 'dog lock' .. one of my dogs is very adept at putting the window's down if its not locked.
    Since I got the new car, my dogs have been confined to doggie booster seats with their harness' on. In my other car my dog liked to stand on the centre console - in this car, I don't want him wrecking the material covering the centre console - so he's gotta sit in his car seat.
    And if its dirty dog weather, I take along the dog crate - it fits very nicely in the cargo area. That's definitley a nice thing about having a hatchback again is that I can put the dogs in the back in the crate if they are dirty.
  12. tochatihu
    tochatihu Senior Member
    9,874
    3,821
    Kunming Yunnan China
    2001 Prius
    I would leave 2 windows slightly open and the parking brake fully engaged in this scenario - even highly reliable Prius systems can fail or behave not as we expect them to.
  13. Alt
    Alt New Member
    fl
  14. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    Wow, that's very sad news indeed.
  15. Tardis Wannabe
    Tardis Wannabe New Member
    47
    Atlanta
    When I took guitar lessons my instructor told me - never, never, never get out of the car in the summer and leave the guitar inside. Take it with you or take it home. I figure if a guitar is that important, a dog or other pet is priceless. Please stop at a place where you can sit outside and eat with them by your side. Slip them a treat while you are at it. ;)
  16. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    My 2 chocolate Labradors are also "safety harness" in the Prius. I know it won't be long before they learn to use the window buttons.
    Dbcassidy
  17. aminorjourney
    aminorjourney Mum to two prius!
    335
    27
    Bristol, UK
    Taking things completely off track...
    Eddie and Pepper, our Golden Lab and Border Collie, both travel in our Priuses with car harnesses. Instead of sitting them on the rear seat (Eddie has diabetic cataracts so sometimes falls off seats) we put the boys in the trunk. We attach their harnesses to the luggage tie-down hoops using climbing carabinas. The dogs are secure and safe from going flying if you stop suddenly, but also get to lay down.
    :focus:.
    I wonder if it's possible to install a cut-off switch to prevent someone breaking in and driving away. Of course, the easier option is to take the dogs with you! ;)
    Or wait and get a 2010 with A/C while parked! :)
  18. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    A switch in the brake light circuit would do that. If you can't get out of Park, the car isn't going too far.
  19. RobH
    RobH Senior Member
    2,385
    991
    70
    The product Can-C reverses cataracts. One place I know you can get it is at INTERNATIONAL ANTI-AGING SYSTEMS . The active ingredient is N-acetylcarnosine. There are a number of other products available in the states that probably are equally effective, but the FDA would have a hissy fit if the vendors mentioned what they did.
  20. dcarlson
    dcarlson New Member
    ohio
    please please do not do that in any car under any circumstances - any slight mishap/unforeseen circumstance will result in you torturing your dog to death. never ever leave a pet in a car in warm weather. thank you.
