1st Oil change - oil leaked out...
Discussion in 'Gen 2 Prius Main Forum' started by PattiK, Apr 20, 2008.
  1. PattiK
    PattiK New Member
    Prescott, AZ
    Hi everyone,
    I am new here - HI...
    We just bought a new 2008 Prius. It went in yesterday to selling dealership for 1st oil change at 4900 miles. This am (after my husband drove from dealer to work, parked all day, then home [100 mi], then back to work this am - my daughter's playing in the garage, "Mommy, there is oil all over the floor in here"...:(
    Immediate call to husband - checked oil dipstick - some oil on it - way below bottom hole (I guess it has two holes - one for low, one for full?).
    I called the saleslady and she called the sales manager who called the general sales manager who came in on Sunday. What they are going to do bring a car to my husband to use and in the morning (apparently they cannot get ahold of the service manager on Sundays) have the service manager go out to where the car is parked (with a pool of oil under it), and I guess we go from there.
    What do you all think? :confused:
    PattiK
    Prescott, AZ
  2. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    Sounds like they didn't tighten the oil plug all the way. If you still have some oil in there and you didn't get a light while driving it's probably safe to say it didn't run dry driving. I'd say the dealer is doing better than most dealers at making this right (most probably wouldn't offer up a loaner unless really pressured) so hopefully it doesn't inconvenience you too much and they clean the oil up to your satisfaction.
    Mike
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Yikes....make sure they make this right and pay to properly clean up the oil.
    But, get under the car and see if the plug is in the oil pan at all. If it is tighten it up all the way (should be 14mm socket).
    Use another car, buy some oil and add about 3 - 3.5 Liters of oil (5W20)....make them pay you back for that too.
    If the oil leaks again you need to check for damage to the oil pan and may need to make sure they put a wash/gasket/seal before they replaced the plug...let the dealership do that.
  4. PattiK
    PattiK New Member
    Prescott, AZ
    What do you mean by 'properly clean up the oil"?
    Can my husband get under the car while it is parked on level ground (to look at the oil pan)? it seems the car sits pretty close to the ground.
  5. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    By clean up properly we mean oil can't just be tossed in the trash and sent to the landfill. It has to be dealt with properly. Typically the do it yourselfer will bring the oil to the auto store and they have a tank that's emptied on occasion by a oil recycler.
    If you pop your head under there you can certainly see the oil plug. You literally have to put your head on the ground. You can also reach it to see if it's handtight (assuming of course it's there).
    Mike
  6. Patrick Wong
    18,200
    6,471
    Yes, it is possible to view the oil pan drain plug without raising the car, although if there is oil everywhere, it will be a messy thing to accomplish.
    My guess is that the oil filter canister is loose, allowing some oil to leak out. If you have a flashlight, take a look at the oil filter canister located at the front of the engine as well as the oil pan drain plug. Or, since the service mgr is coming to your home, let him/her worry about the problem and how to fix it.
    Can you estimate how much oil is on the garage floor? If you decide to replenish the oil yourself, the correct viscosity is 5W-30, especially since you live in AZ.
    Accidents can happen and mechanics are only human; however this is an inexcusable event.
  7. PattiK
    PattiK New Member
    Prescott, AZ
    Can you tell by touch if the gasket was not put on the plug without removing the plug? Would it be loose or unable to really tighten it down?
    Doesn't the oil filter require a special tool to tighten?
    So far the dealer is being very responsible in their actions today.
    The light did not come on so hopefully no damage. I am a lot more calm now than this morning...:rolleyes:
    Thanks for the replies.
  8. Patrick Wong
    18,200
    6,471
    The drain plug gasket can be viewed, if you are able to see the drain plug. If you can't see the plug, I don't think that your sense of touch would allow you to determine if the gasket is there or not. However your sense of touch would allow you to determine if that is the source of the oil leak.
    The oil filter can be tightened by hand, but the Toyota repair manual suggests using a cap wrench and tightening 3/4 turn after the gasket contacts the flange on the engine block.
  9. PattiK
    PattiK New Member
    Prescott, AZ
    Thank you all so much. I've learned so much today about this topic that I feel like I could change the oil and filter myself...I won't, but maybe my husband will after I explain all the help you have given us today.
    I'll let you all know what happens.
    This place is great.
    Patti
  10. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    get a refund for the oil, you shouldnt have to deal with squat. He may have over torque'ed the plug..and caused damage..hope not. More like either was too loose and fell off, which will be obvious, or he forgot the washer. Although not having the washer on shouldnt leak that quickly, if at all. I ran a car once without the plug washer on my last car on accident, and had no problems. Check under the car if you havent all ready..In fact you should have toyota have a pro come out and clean up the mess on your garage floor, there will be a stain if it sit's
  11. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    That's one reason I do my own oil changes, tire rotation and filter changes. Why would you want the dealer to mess with your car? Writing them the big check was bad enough. I've never set foot in the dealer since the first day.
  12. PattiK
    PattiK New Member
    Prescott, AZ
    Well, the service manager from Power Toyota Tempe came out to my husband's workplace with a tech and he said it was two gaskets on the plug. Apparently, it is a common problem on the first oil change that the gasket sticks to the oil pan?
    The service manager said that there was still a good amount of oil in the engine. Apparently the dipstick curves towards the bottom and there was oil still on it. There was also a lot of oil in our garage and under his car at work (they put kitty litter on it when they fixed the car).
    So, they put jacked it up and drained the rest of the oil and put new oil in it and fixed the gasket and set us up for a free oil change for 10K and had given my husband a loaner (2008 RAV with full tank of gas) and then they fixed the car before he got off work yesterday. So we are pleased with their response and thank the Lord there was no damage to the car.
    Thanks for all your help everyone.
    We are purring in our Prius again!
    Patti
  13. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    It's good you're back on the road without much trouble. Yeah, it's common to accidently double up on that washer although I would have thought the tech would have also known this. :( Personally I've always reused the washer a few times before replacing it on past vehicle. :)
  14. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Patti
    Yes, that is a common thing for uninformed owners to get tripped up on. They change the oil at home, put a new gasket on the plug, and cinch the plug down, not realizing the other gasket is stuck to the pan
    For some reason, my FJ Cruiser is bad for this. I usually have to use a gasket scraper to pop the gasket off the oil pan
    However, I find it very hard to believe the Toyota service department isn't aware of this. More than likely, the kid who last week was scrubbing the urinals or the s***house was promoted to lube boy
    It's one thing when a person changes their own oil and innocently makes a mistake. It was with good intentions. Quite a different matter when you *pay* somebody to do something like an oil change, and they fubar it
    jay
  15. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I agree with you completely on this, I've done all the oil changes on my cars, my parents cars, and my sisters car for the past 13 years. In that time I once accidentally forgot to put the washer back on my mom's car. Noticed a slow drip after I was done. Learned my lesson now I always check for the washer regardless what car I'm doing. And one other time the gasket for the oil filter stuck to the car without me knowing. Put the new filter on over the old gasket, started up the car and it sounded like buckets of water were being splashed below me. Needless to say I learned my lesson and now I also check to make sure the oil filter gasket stays with the filter. Basically my point is that someone who does oil changes all day long should be aware of checking this on every vehicle even if he is a careless a-hole who just got promoted from car wash jockey.
