Mazda Tribute HEV
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Flying White Dutchman, Jan 16, 2008.
  1. Flying White Dutchman
    4,376
    313
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    You did know the Mazda Tribute and the Ford Escape are the same vehicle didn't you? This is the FEH in Mazda trim. It's been coming (promised) for two years now. You can also get the same vehicle in "luxury finish" as the Mercury Mariner.
    If I recall correctly, the next Motorweek episode will be testing it.
  4. cnschult
    cnschult Active Member
    772
    97
    Michigan
    there's also an altima hybrid that you probably have never seen cause its also only avail in a few states, i saw one on a trip to vegas
  5. PoulStaugaard
    PoulStaugaard Now a PriusOwner
    95
    Copenhagen, Denmark
    Is the reviewer correct in describing the transmission as a conventional CVT, or is it Toyota's e-CVT solution (I thought Ford/Mazda had licenced Toyota's technology) ?
  6. alam99
    alam99 Member
    98
    33
    midwest
  7. charansr
    charansr Member
    107
    Concord CA
    Too Bad FORD ended up buying Mazda. Its just an Escape Hybrid in a different shell.(Just like the mercury Mariner Hybrid) I really hope ford can make more reliable cars.
  8. Tbirdtony
    Tbirdtony New Member
    57
    Beaver, Pennsylvania
    According to Mazda customer service, Ford is only building 250 Mazda Tribute Hybrids in 2008. They will all be sold in California.
