Has anyone used solar chargers in the Prius?
Discussion in 'Gen 2 Prius Main Forum' started by neon tetra, Apr 25, 2008.
  1. neon tetra
    neon tetra Member
    309
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I had one early when I first got my Prius. Mine came with some alligator clips that I attached directly to the 12v battery rather than using the power outlet. My intention was to plug it in when the car would sit for a few days unused.
    I think I plugged it in once. Eventually I just got tired of the thing sitting unused in the back of the car. If you do park, in the open sun, for a week to 10 days at a time it might benefit you to plug it in at those times, but other than that I think you'll find it to become more clutter than any actual benefit.
    What I thought you were asking about was something like this:
  3. richard schumacher
    7,666
    1,047
    United States
    What Evan wrote. I bought one and slowly realized that it wasn't worth having it cluttering up the rear seat.
  4. Flying White Dutchman
    4,376
    313
    i have a 13watt panel and it works great!
    keeps the 12 volt battery charged when its standing still long periods of time
    efusco : where is that photo from?
    any specs?
  5. ForTheGlory
    ForTheGlory New Member
    296
    Maryland
    If there was a way to hook it up to the HV battery (there definitely is not a way to do it easily...voltage is too low) I could see myself using one. But I don't see that I'd want it for 12v battery charging.
  6. efusco
    19,891
    1,196
    Nixa, MO
    I took that (terrible photo) at hybridfest last year. It's a plug-in solar prius build by veridian corporation.
  7. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Jeez, Evan, I can tell you're not using a Mac with iPhoto. Two minutes. Not the prettiest with that quickie editing, but it sure looks more usable.
  8. efusco
    19,891
    1,196
    Nixa, MO
    yea yea, I took over 800 photos there, I'm not going to edit them all. I actually did edit that one a little after I saw how bad it posted....
    But, it's an irrepairably bad image bc of that nasty glare coming off the left rear column of the hatch screwing up the exposure. But it's my own fault for not checking it and then adjusting for it.
  9. efusco
    19,891
    1,196
    Nixa, MO
    But, it's an irrepairably bad image bc of that nasty glare coming off the left rear column of the hatch screwi[​IMG]ng up the exposure. But it's my own fault for not checking it and then adjusting for it.
  10. Optimus
    Optimus Member
    274
    25
    hmmm, a new style of "sun" roof....
  11. NoMoShocks
    1,292
    83
    Camas, WA
    I wonder how many solar panels it would take to fire up an invertor to create 120 V at about 10 Amps. Then you could plug in your Hymotion Plug In pack and run at 100 MPG all day long on a sunny day.
    Well, actually, I guess you would run the equivalent of 30 miles at 100 MPG evey 4 hours, because it is supposed to take about 4 hours to charge the 5kWh battery pack.
  12. timtim2008
    timtim2008 Member
    204
    22
    Alpharetta, GA
    i was thinking of getting one also.
  13. timtim2008
    timtim2008 Member
    204
    22
    Alpharetta, GA
    lol, maybe a 6x10' Trailer full of them.
