Hymotion Plug-in a123 battery pack available for consumer purchase
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by pelewis2, Apr 26, 2008.
  1. pelewis2
    pelewis2 Junior Member
    probably a repeat post but... pretty sweet
    Hymotion :: Enabling the new generation of hybrid owners to maximize their fuel efficiency
    A123Systems has fully launched the Hymotion L5 plug-in hybrid module designed to convert a Toyota Prius, model years 2004 – 2008, into a plug-in hybrid capable of achieving up to 100 mpg for 30-40 miles within the electrically assisted driving range. A123Systems acquired Hymotion in February 2007. (Earlier post.)
    The 5 kWh L5 Plug-in Conversion Module (PCM) is priced at $9,995, which includes a three-year standard warranty and installation. Currently, Hymotion is only conducting L5 installations in the United States through Certified Hymotion Installation Partners (Green CHIP dealers). Canadian vehicles can be brought to US installation locations.
    [​IMG] The A123Systems Hymotion L5 Plug-in Conversion Module (PCM) for the Prius. Click to enlarge. A123Systems is currently establishing and certifying its CHIP dealer network in cities around the country. Initial Green CHIP dealers will be located in Boston, Washington, DC, Minneapolis, Seattle, San Francisco and Los Angeles.
    In April 2008, in the absence of established PHEV certification procedures, the California Air Resources Board (ARB) outlined a path for conditional approval for A123Systems to sell up to 500 L5 PCMs in California as a means of initiating the rollout. The company is now in the process of finalizing that approval.
    A123Systems and others are working with ARB to establish full certification procedures for PHEVs. Once those procedures are final, there would be no restriction on quantities sold (assuming the L5 meets certification).
    The L5 module fits in the spare wheel well of the Prius, preserving trunk space.
    Green Car Congress: A123Systems Launches Hymotion PHEV Conversion Module for Prius
    Hymotion L5 Li-Ion battery for the Toyota Prius II and much more. - CleanMPG Forums
  2. joe1347
    joe1347 Active Member
    669
    44
    AZ
    $10K including installation. I wonder what the manufacturing cost would be (to Toyota) if the same A123Systems LiFePO4 battery was a factory installed option package? Few thousand less?
    Along the same lines, why do 5KW-Hr worth of LiFePO4 batteries cost almost $10K? The fundamental material costs (of Lithium) are low. Is the high cost simply an 'economy of scale' issue because A123Systems is still a small and relatively new company? What about if the US Government dropped a few billion dollars to build a 'massive' LiFePO4 battery manufacturing facility (in the USA for once). Would scaling then significantly reduce the manufacturing variable cost to less than half the current $10K cost? If so, wouldn't it make sense to spend a few billion dollars to allow car manufacturers to immediately build hundreds of thousands of 100mpg cars that only cost the consumer a few thousand extra dollars (per car)?
  3. pelewis2
    Cost for 1000+ packs is $6000 according to the website. A lot goes into a good pack design, charge management and charging, cost of testing, packaging, etc...
  4. pewd
    pewd Clarinet Dude
    331
    Dallas, Texas
    How would this affect the Prius warranty? Void it I presume?
  5. pelewis2
    I think that Hymotion said that if something goes wrong and toyota voided your warranty for that component that hymotion would pay for the repair.
    Your entire warranty cannot be voided, I am not sure if this is what you were asking, but a manufacturer cannot void your entire warranty, they can only say that they will not warranty a component if a modification was done that could cause the specific problem.
  6. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    I would like to know if any members are using the Hymotion module? It appears that the install uses the wheel well area. I wondered where the plug in is mounted. Thanks in advance, ---Kent
  7. Tideland Prius
    16,659
    nice! EV Conversion for a Yaris runs near US$40k.
    A Prius + Hymotion Pack is less than that and it's more useable!
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    The plug is usually mounted on the left rear bumper.
    I have photos of a complete install HERE.look about 4/5ths the way down the page.
  9. Gadgetdad
    Gadgetdad New Member
    462
    Modesto, California
    Ok guys and gals, it is here! Who will be first to jump in? I am tempted!
    Lee:cool:
  10. patsparks
    10,664
    569
    Adelaide South Australia
    Hands up everyone who hates the space saver spare tyre?
    Here is a valid reason to get rid of it. Yippee!!
    Now hands up anyone who would hate to be 50 miles from the nearest town with a flat tyre and no spare?
    I had a flat tyre last week, I was about 50 miles from the nearest town with no phone coverage, I love my spare tyre. My valve stem was broken so the sticky fix a flat stuff wouldn't have worked.
    It was bad enough that the flat tyre wouldn't fit in the spare wheel space, would have been worse if I had no spare.
    Please don't get me wrong, I love the concept but in practise there is a cost of removing the spare.
  11. clett
    clett New Member
    537
    Scotland
    They don't.
    A123 have said that they will be able to produce their LiFePO4 cells for $300 per kWh, which puts the battery in the Hymotion kit at $1,500. The rest of the $10k price is development, profit and electronics.
    BYD are already producing LiFePO4 batteries for well under $300 per kWh.
    If Toyota put these in a Prius, it would have 20 miles EV range for only ~$500 more than the standard NiMH battery Prius (since the NiMH battery in the Prius costs around $1,000).
  12. joe1347
    669
    44
    AZ
    Do you have a link?
  13. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    Put my deposit down. You can cancel up to 30 days before scheduled installation will full refund less $75.
  14. joe1347
    669
    44
    AZ
    With no spare, would it make sense to replace the existing OEM tires with runflats - similar to what's on a new BMW 3-series which do not use a spare tire? And we know just how much everyone loves the OEM tires :)
  15. pelewis2
    Are there any LRR tires that are run flats? I doubt it, I thought those things weighed a ton... Get 2 cans of fix a flat and avoid pot holes.
  16. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    Thanks Evan for the pictures. I know it does not make economic sense, but I'm ready to put down the deposit. Maybe on Monday or Tuesday. I'm going to ponder it for a few days.
    ---Kent
  17. priusFTW
    priusFTW Gen III JBL non Nav
    434
    White Mtns New Hampshire
    I soooo much would love to get this. If price weren't a factor... I would do it. I wonder... does anyone think the price will come down as production/demand increases?
  18. priusFTW
    434
  19. Marg
    Marg New Member
    155
    Eastern Ontario, Canada
    I am hugely tempted to put down a deposit as well. Two things are stopping me.
    First, there are only 5 official locations where one can go to install it: Seattle, San Fran, Los Angeles, Minneapolis and Boston. I live in eastern Ontario, Canada, so there is no convenient locatin for me.
    Second, I have questions about the warranty. As I understand it, in the US, due to some court cases, a car company is not allowed to declare your warranty void if, for example, you installed a hymotion then your steering column broke. If your car problem has nothing to do with the thing you added to the car, the the company must pay up. I don't know whether there is similar jurisprudence in Canada. I'll have to ask around.
  20. milazotes
    milazotes New Member
    22
    York, PA
    The value might be there if the 100 miles a gallon touted here actually worked for more than 20 miles a day. I drive 120 miles a day and this spare battery pack would be completely drained in the first part of my commute. Back "down" to 48 after that until I find a plug. No thanks. Even after 5000 charges, which is probably the limit for any commercially available battery at this point, you're looking at 100000 miles for 10000 dollars. That's 10 miles per dollar or about 37 miles per gallon at $3.70. Is that good? Justified?
