NY times article on "health risks" from driving hybrids
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Ichiro, Apr 27, 2008.
  1. Ichiro
    Ichiro Member
    335
    SF
    http://www.nytimes.com/2008/04/27/automobiles/27EMF.html?_r=1&oref=slogin
  2. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    What's Next??
  3. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Did they fail to mention that the measured fields in the passenger compartment of the Prius are less than the magnetic field of the Earth ? So, just spinning around in an open field will induce more current in your body than the being inside a Prius.
  4. patsparks
    10,664
    567
    Adelaide South Australia
    I have lost my sense of direction in my Prius more than once.
    Must be the magnetic fields interfering with the compass in my head.
    Come to think of it I did that in all my cars.
  5. Neicy
    Neicy Member
    834
    Wakefield, MA.
    :mad:I am so sick of hearing this BS out of the media. Let's scare the sh__ out of people and then check our facts. Anything for sensationalism:deadhorse:.
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,195
    Nixa, MO
    Come on people...look at the facts. That woman in the picture said driving a hybrid "made her drowsy"...now if that isn't F'n proof I don't know what is.
    I'm wearing my tin hat for now on dang it...!:tinfoil3: Then who'll have the last laugh?!:bowl:
  7. grinthock
    grinthock New Member
    And he measured this with?
    Sorry, but that's BS. :pound:
  8. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Wait til Bob Lutz hears about this...
  9. donee
    donee New Member
    2,956
    197
    Chicagoland
  10. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    Thanks, that and the links within were informative. If the quoted source had it right, the 14 milligauss in the back seat is pretty high -- high enough to fall within the range of concern at NIOSH (below), for persons exposed all day at work:
    EMFs In The Workplace
    Even then, the epidemiological data provide only ambiguous evidence of systematic risk despite long exposure times at those levels. Some say risk, some say no, no agreement on dose-response relationship. In my experience, that means that the risk, if any, is small enough to be largely indistinguishable from background noise (ie., the rate at which leukemia appears anyway). But that's a study waiting to happen -- cancer rates f Prius-owning families. Anyway, little or no systematic risk seems to be the conclusion of many studies over time, summarized here:
    SCE - EMF Questions and Answers
    That reference one also gives data on the strength of various magnetic fields. The earth's magnetic field is given as an average of 500 milligauss, but presumably that's pretty much constant and so not an issue (though I guess if you're traveling through it, that's not necessarily true.) The only health advisory listed in that cite above was for exposures over 800 milligauss. The average home exposure is 1 milligauss, but exposure near appliances can be much higher.
    I'll put this on my list of things to worry about some other time.
  11. texnet
    texnet Junior Member
    30
    Houston
    Google leukemia and emf and the first item says:
    The statement by NIEHS (and its director, Ken Olden) that the EMF/leukemia association is "weak," because there is no confirming biological evidence, ..
    Sounds like someone trying to get media attention.:rolleyes:
    The Times article is a clear case of Prius envy to me... Just have to laugh!:pound:
  12. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Chogan,
    As the field of 14 mGauss is next to the battery, one can infer that is static, or slowly varying level. As batteries have a large damping effect on the change in current. The only induction effect would be when the current reversed directions, such as switiching from electric drive to electric braking.
    Movement through a static field is the same as a varying field, with respect to the current induced. Its the vector dB/dt magnitude that induces current. So, turning in a static field, like a generator armature does, induces current.
    When one makes a turn more than 90 degrees out-of-doors the effect of the earth's magnetic field is probably larger. So the thing is, do people turn on their heels as fast as a Prius changes from electric drive to electric braking. I would guess the change is similar, or the Prius has a slightly greater vector rate of change, but static field is much less. Even if the Prius had a quicker current rate of change than a person turning a corner, it would need to be 35.7 times quicker (500 mG/ 14 mG) for the effect to match the effect of walking around a sharp corner in a magnetically unshielded room on the surface of the earth. Say people turn a corner in 1/2 a second. Then the Prius would need to change from electric power to brakes in 14 msec. Which seems unreasonably fast for motors and drive in a Prius. What is more typical in driving is one eases off the accellerator peddle, slowly droping current to 0, then one goes into glide, and evenuatlly brings the brake pedal up, all over a period of about 10 seconds, not .014 seconds.
    The issues with EMF's in the workplace, is that these are continuously varying fields driven by AC line currents. Such as large transformerers without shielding (aluminum or plastic enclosures), or workers right next to a 4 foot diameter printing press motor with aluminum end caps (for example). Its not the same thing.
  13. chogan2
    1,066
    756
    Virginia
    Fair enough and true enough. I was mixing apples and oranges.
    But.
    But my only reservation -- and the reason I was willing to look further -- is that it's an assumption that the induced current is the only effect.
    For sure, induced electrical currents are known to affect certain types of cell growth. The key example is the bone growth stimulator, a device used to help heal broken bones. Here's a description of one of the larger manufacturers, Biomet:
    Biomet Europe: EBI® Bone Growth Stimulators
    The odd thing is (here's the "but" part), researchers also show effects with static or slowly changing magnetic field alone, in vitro. But the fields are huge (cite below, 0.4Tesla = 4000 gauss). So, really strong static magnetic fields will also mess with bone cells in various ways. But the strength is, what, 5 orders of magnitude stronger than what you could possibly expect from sitting in a Prius.
    Effects of static magnetic fields on bone formatio...[J Dent Res. 2003] - PubMed Result
    Static magnetic fields promote osteoblast-like cel...[Ann Biomed Eng. 2007] - PubMed Result
    I should have quit while I was ahead. I mixed standard based on 60 hz fields with the (largely) static field in the Priuis. Not smart. My only excuse is that it's not clear that the induced current is the only possible biological effect. But the effect of static field has only been shown for very large fields.
  14. Godiva
    Godiva AmeriKan Citizen
    10,339
    And don't drive your Prius when it's raining or you might get electrocuted.
  15. tasker109
    tasker109 New Member
    147
    Illinois
    i wonder who funded the research? that reminds me of a joke i once heard....
    a man was interviewing accountants to hire to work for him. he had the first interviewee come in and asked him what 1+1 was. the interviewee said well 2 of course. the man said, thank you very much. we will be in touch. the second interviewee came in and the man said, what is 1+1? the interviewee looked at him funny and said, it's 2. the man said thank you very much, i will let you know. the third interviewee came in and the man said, what is 1+1? the interviewee looked around the room, looked over both shoulders, got up and looked up and down the hall outside the office, went over to the window and pulled the blinds. came back and sat down and said.......what do you want it to be? the man said.........YOU'RE HIRED! :pound:
  16. neon tetra
    neon tetra Member
    309
    I don't think it's necessarily an anti-Prius thing. People have been talking about this for a while on other vehicles, and especially airplanes.
    If it's a concern, then it should be examined. If it turns out to be nothing, then even better.
    But I do see a bit of a trend on this board to be overly apologetic about car & to almost deny that some of the problems exist.
  17. burritos
    burritos Senior Member
    4,946
    252
    Then shouldn't studies be done to see if regular car batteries have any risk?
  18. qbee42
    3,079
    I'm probably in trouble then, as I've spent a lot of time in a 1.5 Tesla field.
  19. chogan2
    1,066
    756
    Virginia
    Well, these were cells in petri dishes, so to speak. And it didn't cause them to mutate, just caused them to change. No effect was demonstrated in people. Scanning the literature at the National Library of Medicine, as far as I can tell there's complete agreement that there's no hazard to patients from the magnetic field other than the obvious ones.
    But there's always something. Googling it, it looks like the EU published a regulation limiting chronic exposure for MRI technicians.
    MTB Europe - European Directive on radiation exposure will ban MRI scans
    Despite a lack of evidence:
    Impact of electromagnetic field exposure limits in...[Acad Radiol. 2005] - PubMed Result
    And the NZ standard is that technicians have to stay far enough away to keep the field down to 0.2T.
    http://www.nrl.moh.govt.nz/publications/mriguidelines.pdf
    All of these exposure limits appear precautionary (ie, there's no evidence of harm from chronic exposure), all are hugely higher than what was measured in a Prius. I looked for any epidemiologic study of MRI technicians and found nothing.
    Your point's well taken. If there's no hint of harm from chronic exposure to MRI-strength fields, it's foolish to worry about the magnetic field in the back seat of a Prius.
  20. qbee42
    3,079
    That's where my exposure came from. I managed the design engineering group for a large MRI company.
