Abrupt Engine Cut Out Stall?
Discussion in 'Gen 2 Prius Main Forum' started by SPIKES911, Apr 30, 2008.
  1. SPIKES911
    SPIKES911 New Member
    hi
    i am in my second week of ownership and find that a few times i really feel an abrupt noise sensation when the engine cuts out and goes to battery.
    is this normal?
    thanks
  2. brick
    brick Active Member
    1,083
    79
    Upstate NY
    It's normal. Happens the first time the engine shuts down during a trip.
  3. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    I can almost sense now when it's gonna happen. It can feel like you went over a bump in the road! It can be subtle too. Like a whisper at the red light. Sometimes mine will shudder almost roughly when it's cold at a stop. it isnt supposed to do that until it warms up but it has happened.
    Ive only got 2500 miles on my lil rachel, so it could just be something to adjust a bit my first service.
  4. Bill Lumbergh
    Bill Lumbergh USAF Aircraft Maintainer
    537
    NorCal
    Sometimes it runs, sometimes it doesn't. Sometimes you'll feel it, sometimes you won't. There's no adjustment needed (or even possible). I don't even think about it anymore....the car knows what it's supposed to do.
  5. Sufferin' Prius Envy
    3,998
    If you are decelerating or at a stop, yes, absolutely normal.
    If, on the other hand, you are accelerating and the ICE (gas) engine cuts out and you feel the car lose massive power, no, that would not be normal.
    My guess - you are decelerating or at a stop, and you are rightfully being overly sensitive to what this newfangled car is doing. Relax. As stated before, IT knows what it is doing. You on the other hand haven't been acclimated . . . yet. ;)
  6. SPIKES911
    thanks...i have noticed it more pronounced with the first cold stop but noticed it a few times today. i did run around today so i am sure it must be that first stop everytime.....:)
  7. qbee42
    3,081
    It happens more often with new engines and cold weather, but is possible under any conditions. The Prius always shuts down the engine in the same position. It does this to make restarting as efficient as possible. Sometimes the shut down will miss the target spot and have to rotate the engine around again for another try. That's when you feel the shudder.
  8. drees
    drees Senior Member
    1,782
    247
    Yeah, I typically get the shutdown engine shudder if I stop long enough when the car is still warming up and the engine shuts off.
    Sometimes it's pretty rough. I always thought it was due to the car trying to really make sure it burned off all the fuel left in the engine, but spinning the engine over another time to line it up for the next start makes more sense.
  9. SPIKES911
    great forum...thanks for all the knowlegable replies.:D
  10. patsparks
    10,664
    567
    Adelaide South Australia
    If under hard acceleration you can have a situation where the traction control cuts power and it feels like the engine stalled but power is restored in a fraction of a second. Normal.
  11. Sufferin' Prius Envy
    3,998
    Thanks for adding that! I didn't think ahead.
    You probably saved us from a bunch of threads about how their ICE stalled during acceleration.
