Anything you like better about the G1 over the G2 Prius?
Discussion in 'Generation 1 Prius Discussion' started by Optimus, May 4, 2008.
  1. Optimus
    Optimus Member
    274
    25
    For the G1 owners, what thing or things do you like about your G1 over the G2? The main forum seems to knock the G1 a little bit, so I want to see us geewunners (G1 owners) speak up for ourselves! To start, I like the more classic sedan look of the G1. While I like hatchbacks too, such as a Celica, I prefer the sedan look of the G1. Second, I like the cheaper price of a G1! I would not be able to afford a G2, but I want the technology, better MPG, etc... and G1 was the only choice. I didn't want a Matrix or Yaris either. Despite the fact people claim you can get a Matrix or Yaris for with half the miles of a G1 Prius, I couldn't find any deals like that here. That, and what's the fun in it??? The G1 Prius is still a very good car, and "higher miles" don't scare me a bit, especially since I like to work on my own cars.
    How about you?
  2. Wolfcub
    Wolfcub Junior Member
    Ludlow, KY
    2002 Prius
    I'd have to say I definitely like the price better. It's only a fluke that I got my car for the price I did and I definitely can't afford a newer prius.
  3. patsparks
    10,664
    567
    Adelaide South Australia
  4. kenmce
    kenmce High Voltage Member
    1,549
    522
    NY
    1.) The G1 has much better visibility.
    2.) The climate controls can be worked by touch.
    3.) Remote trunk release
    4.) normal gear shifter, so no *^%!! reverse beep needed.
    5.) The owner can buy and program a new key fob all by themself. With the G2 you need to make a dealer appointment and show up with a stack of fifty dollar bills.
    6.) On the G 1 there is a small fuse box near the driver. To get at it you open the door, open a hatch at the left end of the dash and change the fuse. On the G-2 you lie down on the floor, push the seat all the way back, the emergency brake all the way forwards, and work upside down in the dark with the fuses. This is not an improvement.
  5. Optimus
    Optimus Member
    274
    25
    very informative :D
  6. mikel 52
    mikel 52 Member
    128
    2002 Prius
    the heater A/C controls more
    The little blue light that tells you the engine is cold
    there is an oil pan on the transaxle
    14" tires are less expensive to replace
    The price.
    I'm sure there's more but taht's all I can come up wiht right now.
    Mike
  7. tochatihu
    tochatihu Senior Member
    9,844
    3,806
    Kunming Yunnan China
    2001 Prius
    Real lockable trunk. Start vehicle w/o foot on brake pedal. HVAC does what you tell it to. Use B mode and cruise control, together.
  8. ChapmanF
    18,447
    I think you nailed two of the big things with the price and the appearance. How much money a Prius can save you depends on how much you drive; if you have a long commute or a travel-intensive job or lifestyle, you can easily justify the cost of a G2, but it's nice that even I with my short commute was able to make the numbers work out for a used G1.
    And I do just like the look better. My decision to eventually buy a G1 was actually made in 2003 when I saw the first G2s and thought, "they made it look like a speedbump? Ok, I'll just wait for an opportunity for a G1." And just watched gas prices go up and G1 prices go down until the numbers worked for my driving conditions.
    Like you, I'm accustomed to taking care of my own cars, which is an important point when the warranty is gone. I won't say "doesn't scare me a bit" because there weren't a lot of these cars made and a lot of the parts are unique and limited-run. The traction battery gets talked about but there are a lot of jaw-dropper prices on the parts list. I feel lucky that everything seems pretty sound on mine, and I hope the luck holds out.
    Now if technical challenges and extra work interest you, there are other things to like about the G1. ;)
    Self-maintenance without a scantool isn't very promising, and nobody seems to have a third-party diagnostic scanner solution for G1. Generic OBD-II scanners can talk to the engine control just fine, but not the all-important Hybrid Vehicle and Battery ECUs, and can't activate various test/service modes. The Ecrostech Mini-Scanner could retrieve some subset of HV and Battery data, but is out of production, and seems to have been designed more as a dash display than a service tool (though it could be used in a pinch and would be a lot better than nothing).
    Nobody advertises an iPod input/control kit for G1. It uses the AVC-LAN bus like the G2, but apparently the connectors are different or something, and nobody developed a product. Vagabond posted in the audio/electronics forum that there's a DICE unit that supposedly has the right connector and /ought/ to work, but there's no record of anyone confirming it. I haven't been able to find out which DICE model Vagabond meant, or whether it's the one available from the priuschat shop. There is a pinout for the required connector: Audioeingang (Nachrüstung P1) - Prius Wiki
    PriUPS conversions are probably harder; Richard Factor has found UPSes that will work off the 204 V battery of a G2, but hasn't found any that would like the 274 V of a G1. (He has said he's looking into solutions for the higher-voltage Ford Escape Hybrid, though, which would probably apply.)
    No G1 coverage by the usual trailer hitch sources. (Not that a Prius would do any real towing, but bike racks etc. are handy.) Coastaletech sells one. I haven't got one yet so I don't know how it fits around the exhaust. Somebody else who did a custom fabrication wound up deflecting exhaust up at plastic bumper/body parts and melting them.
    My favorite thing about the G1 appearance? People by now are used to the G2 look, so a G1 is a stealth hybrid - some of your friends won't even know they're getting into a hybrid until it's TOO LATE! Bu-wahahahahahahaaaaaaaaa!
    -Chap
  9. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    The G1 has been saving me gas for 8 years, the G2 cannot make that claim.
  10. ScubaGypsy
    ScubaGypsy Live Free & Leave No Footprint
    95
    Aquidneck Island, RI
    These are all true as well as the comments about not having to step on the brake to start and the lockable trunk. I'd also like to add the following,
    - My G1 has a dealer installed sunroof that they can't put on the G2 because G2 doesn't have the structural support
    - I have both a cassette and CD as dealer installed. I like having both as I enjoy the books on tapes and this provides greater options.
    I have friends and relatives with G2's (who I recommended their purchase) and I have had G2 loaners but I still am not convinced that it is an upgrade. Their mileage is not higher than mine and in particular I do prefer having the sunroof. I'd prefer a bigger jump in technology (plug-in someday?) before I consider trading in as I have had very few problems and I have over 100k miles.
  11. Synergy
    Synergy New Member
    33
    Ware, Massachussetts
    ROFLMAO
  12. Optimus
    Optimus Member
    274
    25
    Do you happen to know the brand and model # of that sunroof? I was under the impression that sunroofs were not possible in the G1's either.
  13. bwilson4web
    16,326
    • Graham miniscanner
    • No warranty fears (they've expired)
    • Toyota SAE paper on improvements of G2 over G1
  14. Devil's Advocate
    922
    Las Vegas, Nevada
    The G1 color - "Blue Ice", it was cool.
  15. ScubaGypsy
    95
    I'm sorry but I don't know. My dealer was Toyota of Newport (888.234.7014) and it was a popular add-on as I have a friend that also took delivery of his 2003 with it. They also added in leather seats which have held up wonderfully.
  16. RinMI
    RinMI New Member
    132
    SW Michigan
    I own a G2, but there is a G1 that I see quite often when I go to my sons' baseball games. While I do applaud the G1 for it's "traditional" sedan design; I specifically bought the G2 because it is a hatchback design and the seats fold down. When I compared the G2 to the other competitors (Civic Hybrid) I liked that the Civic looked like a regular car but the fact that the seats did not fold down due to battery placement decisions was the nail in the coffin that got me to choose the G2. If I could fit my family and my drum kit in a G1 at the same time, you can bet I would have done so.
    That said, if we (G2 owners) have come across that way, I am sure it was purely unintentional and for myself, I apologize for any negative comments against the G1 that I may have made. The G2 owners should not downplay or denigrate the G1. For without the G1, we would not have our G2s. And thank you to the early adopters that were willing to take a chance on a dream. Without the G1s and their owners; Toyota may have decided to take a different road and abandoned the hybrid concept altogether.
  17. ChapmanF
    18,447
    Judging by the recent "lost front brakes" thread over in Technical, where the G2 brake bleeding instructions got posted, I think I like the G1 better for brake work. Yikes!
    If I can trust the G1 manual here (no direct experience yet), a THHT is still involved, but only in one step, to actuate one solenoid. For the G2 it looks like the THHT is the only thing that knows what the dickens you're supposed to be doing.
    -Chap
  18. Patrick Wong
    18,210
    6,511
    I flushed the brake fluid in my 2001 last year without using THHT. My procedure was to first use a rubber squeeze bulb to suck out as much of the old fluid in the reservoir as I could reach. Then I refilled the reservoir with new fluid.
    I made the Prius IG-ON and had my wife gently press the brake pedal slightly. I cracked opened each wheel cylinder bleed valve in turn, with a vinyl tube leading to a collection jar, starting from the right rear, and a tremendous flow of fluid came out. Then I tightened the valve before she let go of the brake pedal. Refilled the reservoir, then moved on to the next wheel, etc. I used two small containers of Toyota DOT3 fluid.
    I agree that THHT will be required if you allow air into the system upstream of the wheel cylinders.
  19. tochatihu
    9,844
    3,806
    2001 Prius
    If you allow air into the brake lines, then you need the Special Hybrid Integrated Tester.
    Patrick did you happen to get a % water content on the old brake fluid?
  20. ChapmanF
    18,447
    Even better, then. We have a lot at work.
    -Chap
