Helping a dead one
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hobbit, May 6, 2008.
  1. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    So this afternoon, I'm cruising up I-93 through heavy but moving
    traffic, and spotted a silver Prius that just pulled into the
    dead zone in an on-ramp merge with its flashers on. Oops, I
    thought, I wonder what's wrong.. I didn't have the leeway to
    stop right there but since it was between a pair of interchanges
    reasonably close together, I decided to loop around and see what
    was up.
    So I started my nice long WS glide toward the next exit, took
    a leisurely path through the routing needed to get me going the
    other way on the interstate, and tooled back to the previous
    interchange ... Prius was still there on the other side as I
    went by, so clearly having an issue. After another leisurely
    180 I started into the on-ramp just after where the dead Prius
    was but hit the 4-ways and slowed down at the end of it to
    drift onto the merge triangle [corrugated concrete, blech] to
    stop and then back slowly up far enough to be in a safe stopping
    place. No need to hurry through any of this or be abrupt in
    my driving behavior -- nay, I *hypermiled* my way through all
    of that routing to get back to where this other car was, because
    what you do in on-ramp and off-ramp accel and decel is where
    some huge gains can be made. Hardly used the brakes at all.
    Many people succumb to the temptation to start all kinds of
    useless abrupt behavior in cases like this because they get
    into some twisted thinking that they're in such a hurry. Taking
    it easy maybe got me to the location what, 20 seconds later
    than endangering everyone around me would? BFD, this poor
    owner wasn't going anywhere for a good long time. As I did a
    nice long predictable slowdown, WITH flashers going, toward the
    end of the on-ramp and clearly heading for the dead zone, this
    butthead in a Cherokee of course made a big deal about finally
    blasting by me on the right because drivers around here are just
    plain intolerant of anyone else's navigation needs. Screw him,
    if I was an AAA flatbed with big yellow flashers he'd probably
    behave in the same ersatz-self-important manner.
    Anyways, I got out and trotted back to this other Prius, where
    the owner was deep in several phone conversations at once and
    juggling AAA and her sister and the state police all via
    call-waiting. But I quickly made it clear that I was there
    to try and help and one of the benefits of Prius ownership is
    that you get this community along with it, and proceeded to try
    and diagnose why her car had suddenly just lost power.
    Well, it seemed to be the classic "engine does not start" case,
    which is often misdiagnosed because of the high crank rate given
    to the engine by the motors during a restart attempt. With the
    rush-hour highway noise next to us it was almost impossible to
    hear what the ICE was doing, but after rebooting the electronics,
    the car tried to spin the engine again but it didn't sound/feel
    quite right. It in fact sounded just like mine did when I was
    doing my pull-the-fuel-pump-power experiments last year just to
    see what the responses were.
    Nonfunctionality of the engine was confirmed by letting it try to
    spin up while in Park, and then shifting quickly to Neutral which
    should have let it just idle if it was running by then, but instead
    feeling it lurch and die. Nothing looked amiss under the hood --
    fluid levels okay, nothing hanging loose, etc. I went around and
    wiggled/reseated various connectors that I could reach -- ignitor
    plugs, crank sensor, MAF/IAT plug, etc, and tried once more and it
    wouldn't go. Felt like a no-fuel problem, even though she clearly
    had above half a tank. A voltmeter showed her 12V nice and solid
    at 12.5, so that wasn't the problem. The throttle motor was working
    fine, holding the flap at the right place and not stuck. Without a
    scantool there wasn't much else I could do to diagnose the thing,
    especially with trucks barreling by at 70 MPH. What I *did't* do
    was get under the dash and check the ECU plugs, which in hindsight
    I should have at least looked at.
    AAA showed up with a flatbed shortly thereafter, and I had her
    power up to IG-ON and put it in Neutral for them because I was
    relatively sure that they wouldn't be able to handle that. While
    they *have* dealt superficially with Priuses before they probably
    aren't aware of the differences and subtleties of IG-ON vs. READY.
    With her HV battery down to one bar and the "main battery" warning
    icon already showing up on the MFD, I didn't want to keep trying to
    fully restart the system until the car got back to her dealer and a
    more controlled environment. I asked the AAA guys if they carried a
    scantool of any sort in their trucks -- answer: no. They're there
    to hook and haul, not get into any diagnosis, but maybe some year
    they'll start being issued cheap scantools for cases where they might
    be able to do something simple and get someone's car started again.
    Not yet, though. This was interesting, though: they fetched the big
    screw-in tow eye out of the back and installed it and used that to
    winch her car aboard, and then powered it down okay.
    Meanwhile we talked and I gave her a flyer and told her about
    the online resources and forums and such. Maybe she'll show up
    here and tell her own story eventually, but in the meantime seemed
    happy to have me be her proxy. I told her to make sure to get
    all the current and stored codes from the Toyota diag guy and to
    email me the results, offered the wild-nice person theory that the problem
    was somewhere in the fuel system, and then she jumped into the
    AAA truck and we all got ourselves out of there.
    It was interesting to note that said dealer, Jaffarian in
    Haverhill MA, actually suggested that she try to drive the car
    in, something over 30 miles with almost nothing left in the
    HV battery. That's how much their service writers apparently
    know about Priuses, so there's one piece of info for the
    archives. We'll hopefully find out how competent they are
    to actually find the problem and fix it. '05, 35K or so,
    theoretically just barely still in base warranty, so we're
    hoping that whatever it is works out to a free fix.
    _H*
  2. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Hobbit
    1) I'm glad she didn't pepper spray you....
    2) Thank you for helping someone out in need, the world could use a few billion more people like yourself.
    3) Thank you for taking the time out of your day to help someone else out. If there is such a thing as Karma, I hope you've paid back into the system or are due some help later on.
    Nicely done.
  3. tochatihu
    tochatihu Senior Member
    9,765
    3,766
    Kunming Yunnan China
    2001 Prius
    Good on you for stopping. Because I was "in a hurry" I drove past an early Prius once, stopped with an early-Prius-tire-underinflation blowout. Still regret doing that.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    H
    You're a good man. We need more like you
    j
  5. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Little does she know the good fortune that it was one of the most knowledgeable Prius owners in the world that stopped to help. Thanks for yet another contribution to Prius-world!
  6. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    Hobbit,
    Thank you for stopping to help -- and for providing real assistance.
    I am reminded once again of a time I was in desperate straits in the high desert in Arizona. My rental car was dead. This was in an era where cell phones were very limited, and there was no place to go, no one to contact. Two guys driving a pickup with Wyoming plates stopped to offer their assistance. They were mechanics who just happened to be carrying all of the right tools. I don't know all of what they did, but they removed the manifold cover to get at the problem. In the end, an oil change was required. They drove off to get oil & a filter, and returned to complete the job. After taking many hours out of their day, they refused any compensation. I pleaded with them to allow me to repay their kindness. Nearly reduced to tears, I begged them to share dinner with me. They agreed. After following me down out of the mountains toward a population center (in other words, after making certain everything really was OK), they declined the dinner invitation, saying they wanted to move along.
    Once again, I asked: "Isn't there anything I can do for you to repay your kindness?" One of them replied: "Help someone else in need."
    Hobbit, I'm glad there are guys like you out there! I'll stop to "help" though I can't offer much except company and a cell phone (as if that's needed anymore).
  7. Spectra
    Spectra Amphi-Prius
    3,123
    17
    S NJ
    Yessir!
    As my Prius driving techniques have become more consistent (& enjoyable) over 4 months of ownership, I get such a laugh out of those pure-bred boba-fide jerks --
    They veer around me in speeding up to a light, only to jam on their brakes when it turns red. Then, in order to vent frustration, they do all kinds of wacko motions to make sure I see them flipping me their puny little bird.
    (for which their massive pickup is meager compensation).
    By that time, they've missed the light changing to green. So, they floor the monster to ensure their gender recognition ...
    ... and as the Hobbster says, 20 seconds later, I'm right next to them at the next light, coolly jiving to Prairie Home Companion.
    Go Figure !
  8. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    Ur a good man Hobbit-san. I note that around Orlando I cannot even get a Pri driver to acknowledge my wave to them or Beep-beep. I see one almost every day on the way to work and not one out of 10 or so has waved back, smiled, or shown anything approaching community.
    I keep trying!
  9. hobbit
    4,089
    469
    Bahstahn
    Well, that's likely to become more and more true as the Prius
    goes more "mainstream", as it seems to be doing as fast as it
    can be shipped. They're everywhere now. And driven by the same
    people who were tailgating you in their Infiniti-qx-whatever-
    makes-you-look-fat SUVs last month. The cozy little cult is
    rapidly becoming diluted, but that doesn't prevent some of us
    from keeping the mystique alive.
    On the other hand, sometimes I get thumbs-ups from SUV drivers
    or passengers, go figure.
    I did find out a little more from the owner. Evidently the
    problem was the air filter not installed right and some sort
    of crud had gotten down where it made a difference to a
    sensor, possibly plugging up the MAF. Damn, and I thought
    I should have popped the air box lid and had a look, but I
    didn't. It was a simple and cheap/free fix and she's back
    on the road now -- insert happy-ending music here. Hopefully
    the engine didn't ingest anything nasty in the meantime.
    _H*
  10. Neicy
    Neicy Member
    834
    Wakefield, MA.
    So is she gonna join PC and join in the fun?
  11. dogfriend
    7,512
    1,190
    Carmichael, CA
    And he shares his knowledge with others with no strings attached. When I have free time, I go to Hobbit's links page and try to absorb as much as possible.
    Thanks for sharing your knowledge with all of us. :first:
  12. Patrick Wong
    18,200
    6,500
    Hi Hobbit,
    Kudos to you for trying to be a good Samaritan. I'm not sure that visual inspection would have allowed you to identify (or do anything about) a MAF sensor problem; that one seems pretty random. Anyway I'm glad that the problem was resolved inexpensively.
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    H
    Know what would be ironic? If she had had a service at the dealership and they were the ones who didn't put the air filter in right!
    jay
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    +1. Always willing to learn and share with us. And his adventures in plumbing are downright exciting - I *hate* plumbing!
  15. hobbit
    4,089
    469
    Bahstahn
    Hard to say whether a MAF blockage would have been visible or
    not, it probably depends on the exact type of detritus that got
    down in there. The sensor is VERY touchy about airflow, though.
    Today I let the engine idle [y'all remember how to do that, right?
    See the Georgia inspection threads] and with the air box cover
    open, simply stuck my finger down over the MAF opening that
    leads into the hot wires:
    Even before my finger got there and was just waving near the
    sensor, the engine note started to change. Once I mostly blocked
    the opening, the engine promptly sputtered and died. So the
    MAF is very key to having it run right, and very sensitive to
    any sort of disturbance. The MAF assembly only samples some
    fixed fraction of the total air flow, so variations in what it
    sees will likely create a more profoundly distorted picture of
    how much fuel to inject.
    So if you play in that side of the air box, keep it very very
    clean! I would have really liked to see what the Toyota guys
    found that afternoon.
    Interestingly, when the engine died in Neutral no warnings
    came up. I guess the car doesn't care what happens to it in
    that state, it only cares when the hybrid ECU has control of
    things and the engine misbehaves.
    _H*
  16. Patrick Wong
    18,200
    6,500
    Hi Hobbit,
    Great experiment. Note that DTC P0101 "Mass or Volume Air Flow Circuit Range/Performance Problem" is likely the DTC that would be triggered by your finger blocking airflow into the mass air flow sensor. This DTC has "two trip detection" logic, so the problem has to happen 2x before the DTC will be reported by the engine ECU.
    It is also interesting to note that this DTC does not allow a fail-safe condition that would allow the car to "limp" home. So if the MAF sensor starts to produce bogus results, the engine will just die as you and the subject of your original post discovered.
  17. Pinan
    Pinan Member
    173
    Murrieta, CA
    Great story hobbit. Kudos to you. :)
    Btw. What do you write in before posting? MSFT Word? Just wondering because the margins are so close.
  18. Huntceet
    Huntceet Junior Member
    85
    Chicago area
    2018 Prius
    I render assistance to the general public usually in the form of breaking into their car after they have locked their keys in. I carry a Big Easy lockout tool in the Prii all the time.
    Last Saturday as I walked out of the Aldi there was a woman sitting on the back bumper of her Caravan with a sad look on her face. I asked if she was locked out and sure enough she was. Told her I could open it. Put my groceries in my car and got out the tool. Back at her car, I ask her to time me ( I always ask them to time me). Before she comprehended what I was talking about I had her door open. She was shocked but the man loading groceries in the car next to hers went wild. Started carrying on about "How could you open that car so easily?" "Could you open my car like that?" Me "Yes". Him "I'll be damned, I gotta' get another alarm on this car."
    I never ask for any money. If they offer I take it if it's not too much. If they ask if they owe me anything I tell them to pay the favor back to someone else.
    Hunt
    "Work like you don't need the money, love like you never had your belongings set on fire and dance like you're not wearing any pants."
  19. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Hobbit, you are a good man.
    I've been rescued, over the years, by nice people, when I've had car trouble (pre-cellphone days)... all of you rescuers are good people!
  20. hobbit
    4,089
    469
    Bahstahn
    It's kinda too bad that car doors are so flexible, huh? If
    they were designed with multipoint latching systems, tools like
    that would be useless. Nonetheless, the locksmith industry
    is still awash in kits to maneuver around the innards of doors
    [and often rip wiring harnesses in the process]. Nice that one
    of the good guys is running around with good intent, but be
    ready to do a lot of explaining if you're in a traffic stop.
    Pinan -- I generally read my forums in a text-based browser in
    a shell window, where 80 columns is still the rule. If you saw
    most posts' data content in the raw, it would be one nearly-
    unreadable huge line out to the end. Narrow columns are more
    readable, as any newspaper layup jockey knows.
    And before you ask, the extra periods are to maintain interline
    whitespace which otherwise doesn't seem to work for me...
    _H*
