Noise from Aux Port (06-08)
Discussion in 'Toyota Prius Service Bulletins - TSBs' started by zenMachine, May 1, 2008.
  1. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Here's the TSB for the AUX noise isolator issue in case anyone needs it.
    If you own an 06-07 (and possibly 08) model, and uses your Aux port a lot, this is a good fix to get while your car is still under warranty.
    DLC82SV and Mylar like this.
  2. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    Thanks Zen.
    I hadn't known about this TSB.
    I'll definitely get it done under warranty on my 2007.
  3. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    92
    Virginia
    Do owners with an 2008 even have this issue?
    DLC82SV likes this.
  4. zenMachine
    3,355
    300
  5. maximus2112
    maximus2112 Junior Member
    Wake Forest, NC
    I just got my 2008, and yes, I hear the noise very clearly. I have
    an appointment scheduled for Tuesday to get it taken care of with the
    dealer. I mentioned to my sales guy it might be wise to go ahead and fix
    this as the cars come off the truck, we'll see.
    DLC82SV likes this.
  6. maximus2112
    Wake Forest, NC
    Update for everyone, I just had the AUX port fixed today. Took about
    2 hours at the dealer. There is a new TSB coming out for 2008's but
    the dealer can use the 06-07 TSB to get the parts. Works like a charm!
    DLC82SV likes this.
  7. rpg51
    rpg51 Member
    200
    Vermont
    I notice a soft high pitched pulsing noise when I use my iPod with the aux input AND the power jack. If I don't use the power jack it goes away. Is this the sort of noise you guys are speaking about? If so, I'll bring it in. What a great forum. I would have assumed it was the power supply plug I bought if I hadn't checked here. Seems like this is something Toyota should just fix on these cars from the get go. They have known about it for years!
    DLC82SV likes this.
  8. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
    I'm having the same problem. Please post if you get it fixed. My serice manager insists my samsung helix is the cause. I even gave him the TSB but of course my 08 built 09/07 is not covered.
  9. mrblaise
    mrblaise Go Lakers!!
    2,248
    525
    Southern California
    Do you know when the new TSB is coming out? My service guy doesn't seem convinced about the issue in the 08. Thanks.
  10. PriusSmith
    PriusSmith New Member
    South Jersey
    I had a hissing noise when using my ipod through the AUX port. My son looked at the settings on the ipod. He noticed I had a limit placed on the volume level and I had the bass turn up high. After resetting these levels the hissing noise has disappeared.
  11. kathyb
    kathyb New Member
    53
    Brooklyn, N.Y.
    Nothing is attached to the PDF file. Please reattach. Thanks
    DLC82SV likes this.
  12. KandyRedCoi
    KandyRedCoi S is for Super!
    860
    SoCal/AZ/NV
    i only have the noise if i have my ipod plugged in the aux ports while its also plugged in the 12v power supply to charge it up while playing
  13. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
    I talked to Toyota USA today.(1-800-331-4331) They claim all models built after 8/07 have the new part. No TSB for the 08s. Please call, get a case number and let them know you hear it in your 08.
    DLC82SV likes this.
  14. Wa1hog
    Wa1hog Old Blind Hippie
    95
    South West New Hampshire
    The easiest way to tell if the noise is from the AUX port or your device is to just shut off the Ipod or Sat radio and crank up the vol while still in AUX mode. I also hear the high picthed noise and engine popping in my 2008. I use an XM radio in my AUX port and when Led Zeppliun comes on and I crank up the volume it is very noticeable.
    I am having this fix when I get my first oil change.
    DLC82SV likes this.
  15. Chris_Kewl
    Chris_Kewl New Member
    Kent, OH
    This rocks, I sent this over to my Toyota dealer, who knows me quite well (sadly) -- long story -- and he will email me when he has the parts in so we can get it fixed.
    Chris
  16. tombellanca
    tombellanca New Member
    53
    Encinitas, CA
    I had my '08 in for its 5k mile service this weekend, I brought it the 06/07 TSB from earlier in this topic. The service guy checked it out and told me the TSB has been update for the '08 model to : TSB 0067-08.
    Unfortunately he needed to order the parts, so I'll have to take it back in to get it taken care of.
    DLC82SV likes this.
  17. blackpri
    blackpri New Member
    Raleigh, NC, USA
    This is also occuring on my new May 2008 vintage Prius. I'm using a Garmin Nuvi GPS as an MP3 player through the Aux port.Only when Nuvi powered by dash or console plug, not when Nuvi on its own battery. I do have its volume turned up near max, have not tried yet to reduce its volume to judge effect on noise as per earlier suggestion in thread. Is the TSB update mentioned earlier to include '08's viewable publicly now to show a dealer in case they dispute it or dont have latest info?
  18. Wa1hog
    95
    Bringing my 08 in for its first oil change next Wed. I also told them about the AUX noise issue. Yes, I do have to crank up the volume but I do that when I hear a good Led Zepplin song. Hopefully they can fix the issue then.
  19. mrblaise
    2,248
    525
    Southern California
    I would also like to see a new TSB that includes the 08's
  20. mrblaise
    2,248
    525
    Southern California
    I just found this TSB and started a new thread in the Modifications section but I'll post the link here as well. Here is the new TSB. Just hold down the control button and cliclk on the link to open the bulletin an Adobe format.
    [​IMG] TSB-0067-08.pdf (461.4 K)
