Hidden Hybrid Automobile Dangers, What You Should Know About EMFs?????
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by debos, May 9, 2008.
  1. debos
    debos New Member
    45
    Southern California
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    the EMF fields found near your cellphone and portable radios are higher than the prius in almost every way.
  3. NoMoShocks
    1,292
    82
    Camas, WA
    In the late 80, it was Waterbed Heaters and Electric Blankets.
  4. cdma77
    cdma77 New Member
    NC
    Pure rubbish, you PC monitor emits much higher levels of radiation! Some jackass sold his car based on some psudeo science!
  5. richard schumacher
    7,664
    1,044
    United States
    Curious, we just had a long discussion of this recently, yet the search function returns no results for "EMF".
    Anyway, there were multiple references to published studies from the last 20 years showing no clear evidence of biological effects from weak, low frequency fields such as those present inside a Prius. "no clear evidence" here means "orders of magnitude less dangerous" than things like exposure to Sunlight, second-hand cigarette smoke or Diesel exhaust, being overweight, driving without a seatbelt, and lots of other stuff.
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Oi, here we go again. First the Prius was "smoke and mirrors," then a pseudo-marketing company claimed a Hummer was cheaper to own, now we have these invisible rays zapping us
    Too early in the day for a stiff drink, but I need one right now. Hmmm, wonder what all that drinking is doing to my liver ..... ?
    What else in the area of scare tactics? Oh right, apparently little kids are blundering into hybrid cars because they are "too quiet"
  7. atroader
    atroader Engineer
    39
    Atlanta, GA
    Magnetic flux is proportional to current... so unless you're operating on electric only, there is not much flux b/c there is not much current (generally) coming from the battery. Most of the prius current comes from MG1 going to MG2, so the flux is contained in the engine bay along w/ the high-frequency magnetism coming from the DC-AC inverter.
    You'd be worse-off sleeping with a heating pad all of the time. Anyone work near induction furnaces? Now that's some non-ionizing radiation to worry about.
  8. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    The magnetic fields generated by the cars' systems are -MUCH- lower than the earths magnetic field. So if you're worried, better leave the earth. Bye!!
  9. qbee42
    3,079
    If you wear a tinfoil hat and aluminum underwear you should be okay. I wouldn't drive any distance without protection. :D
  10. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Would this explain all the times I've hopped in my Prius and woken up in a Wal-Mart parking lot with hatch full of chewing gum and a thank-you note from some chick named Lonnie? 'Cause that was kind of fun the first time but gets old as soon as Ebay is so saturated with Wrigley's that I can't make my money back anymore. I also have this new **OOAAAHHHGH** twitch. It's ok, I'm sure others will start posting about it in the technical forum with a link to the TSB. More duct tape in the mean time...
  11. blobpet
    blobpet Junior Member
    28
    2024 Prius Prime
    XSE
    For those worried about EMF, I've got a Q-Ray bracelet to sell you. ;)
  12. madsock
    madsock New Member
    30
    Singapore
    Quoting from the article
    "Neysa Linzer, 58, says that since she bought her Honda Civic Hybrid her blood pressure has increased and that she has fallen asleep at the wheel 3 times. She believes her hybrid is causing her health problems, "I never had a sleepiness problem before," she said. She requested that Honda provide her with shielding material to protect her from the fields but Honda declined."
    Sounds to me like Obstructive Sleep Apnoea, which is a much more commoner cause of daytime somnolence, than the supposed EMF. No input from her physician either.
  13. patsparks
    10,664
    567
    Adelaide South Australia
    She should have bought a Prius, the Honda is so boring it's sending her to sleep. The blood pressure is caused by having to live with her mistakes.
  14. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Tom,
    I think nickel foil would work much better for those magnetic fields. I have seen situations where the fields from a power supply transmformer will go right through an aluminum cabinet of another piece of test equiment and disrupt low power circuits in that other piece of equipement.
  15. qbee42
    3,079
    So you think we need to use mu metal shielding? I wonder if we have to worry about ionizing radiation too? Now I'm really getting worried. ;)
    When I worked with MRI designs, we would use big plates of mu metal to completely line the suites. We had to keep out the RF and the magnetic fields. Without the shielding you could see radio stations in the image: "What's that spot on your liver? Oh, I think it's WKRP."
  16. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    Actually, I have it on good authority that the EMF radiation causes you to post that gas will drop to $2.50/gallon....
  17. richard schumacher
    7,664
    1,044
    United States
    Where's that guy who said he planned to spend thousands lining his Prius with mu metal? I wonder how that worked out for him.
  18. KAR IDEA
    KAR IDEA Member
    465
    Lake Peekskill, NY USA
    Three Touring
    Maybe she kept falling asleep because the Hybrid was too quiet and her blood pressure has increased because of the increase in aggressive drivers! :D
  19. blamy
    blamy Member
    380
    Central Florida
    I'd go with the tinfoil. Those UFO people use it and it works well for them! If it ain't broke don't fix it!:alien:
  20. ELZBETHKW
    ELZBETHKW New Member
    Okay, enough with the jokes already. Is there any scientific data to either support or debunk the story that EMFs given off in a Prius are dangeous to my health? I see where some company is marketing silicon disks the size of saucers to fit over the modules of the batteries at $65 each. So what's the deal with that?
