Standard or Touring
Discussion in 'Gen 2 Prius Main Forum' started by Pope, May 17, 2008.
  1. Pope
    Pope New Member
    I am about to make a purchase and would like some information from owners. Primarily, I am concerned with MPG. Does the fact the touring edition has wider wheels make a difference in the MPG? Also, the touring package has stiffer handling. However, the dealer did not have two I could compare. Has anyone driven both and seen differences in the MPG and handling? What other ins and outs can you guys offer? It seems this is a good place for information and an active forum. Thanks in advance for the input.
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I can't speak to MPG since I don't own a Prius yet, but the touring suspension is noticeably more "refined" than the base model.
    Much less body roll and a less mushy ride. On turns, and changing lanes, the base model has noticeably more roll and wobble.
  3. BT Tech
    BT Tech New Member
    885
    South Florida
    I don't think that there is a significant difference in fuel economy comparing the base model to the touring. Having said that, common sense dictates that a smaller narrower tire will have less rolling resistance and result in slightly higher FE.
    I have driven many of the base model as well as the touring. IMO, the touring option is money well spent as the car has a better "feel" to with a less "floaty" feeling of the suspension compared to the base. The ride quality is slightly more harsh so it depends on what you prefer.
    If you like a nice cushy ride and want the max FE you can get, I would recommend the base model. If you favor a bit more control handling wise and don't mind the slightly rougher ride I would go for the touring.
    Hope this helps....
  4. canesfan
    canesfan Culture shocked...
    544
    Jacksonville, NC
    I can't speak to the MPG issue, but I doubt there's a significant difference. I have a Touring and I am having a blast driving it! I had a Chrysler 300C and my Prius handles better and has a better ride.
  5. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
  6. Neicy
    Neicy Member
    834
    Wakefield, MA.
    Love my touring. MPG difference is minimal. Definitely worth it if you can get one.
  7. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    agreed 100%, i'd wait til the 09's come out tho as there are few to be had now and dealers are gouging on those coming in..
  8. Pope
    Pope New Member
    So you believe I could get a better deal on an 08 in a few months? They seem to be very few around as is. Thanks for all the input.
  9. richard schumacher
    7,682
    1,064
    United States
    No, they're suggesting that you'll get a better deal on an *'09* in a few months. The '08s are pretty much gone and the '09s aren't here yet. On The Other Hand gas may well be more expensive in a few months and the '09s might be in even greater demand.
  10. KayakerNC
    KayakerNC Member
    399
    Eastern North Carolina
    As gas goes up in price, demand will climb in lock-step.
    As the dollar falls against other currencies, the MSRP will also have to climb.
    Buy now. Those factors will keep the value of your purchased Prius high. Your trade-in (if any) will NEVER be worth more.
