How Important is Tire Pressure for MPG?
Discussion in 'Gen 2 Prius Fuel Economy' started by Sheepdog, May 18, 2008.
  1. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    sorry if the thread is a rehash of last years threads. They didnt really help me.
    I have the std tire pressure levels whatever toyota puts in. havent even checked them yet. Is thir a corolation to mpg and higher pressure in the stock tires?
    stock tire- std pressures-49-50mpg for me.
    would this mean that 42 or 44 psi would increase the mpg somewhat or is it really a wash?
  2. JRGris
    JRGris New Member
    27
    Southern California
    Generally higher tire pressure will result in better mpg because less energy is wasted in the flexing of the tires. My dealer puts in 41 psi all around. The owners manual says 35 psi front 33 psi rear. The tire calls for 44 psi max. Some posts on this forum indicate higher than 44 psi being used. I think that ride sufers a bit at higher pressures
  3. Sheepdog
    1,125
    Sanford FLorida
    I wonder if that 6psi makes much difference?
  4. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    If you haven't checked them, they could be below 35/33 (sometimes dealers lower them for a softer ride, or they could slowly fall over time). But you're getting good mileage, so they're probaby still at the recommended minimum.
    Ask TonyPSchaefer, he swears by higher tire pressure and he's got good numbers to back him up. But I'd say going from 35/33 to 42/40 would increase your mileage at least 5%, or about 3-4 mpg for you. That's a guess, YMMV. Dropping below 30 psi is where the you really get a mileage hit, probably lose 10% or more ( >5 mpg).
  5. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    That sounds like something my sister would say. If you haven't checked your tire pressure, you don't know what's in there.........Don't ever
    nice person-U-ME anyone does anything right, when it comes to your car, or anything else.
    Increasing your tire pressure is one of the first basic steps in the quest for better fuel economy. Slowing down comes first.
    For those that choose to do so, 42psi (f) and 40 psi (r) is considered to give great results, without sacrificing ride quality. I've found above that pressure the ride is little harsh with no improvement in MPG.
  6. Sheepdog
    1,125
    Sanford FLorida
    thks. I am going to 42/40 to see how that feels first.
  7. rpiereck
    rpiereck Regenerator
    289
    On a Touring model you can pump them to 45/45 and still get a nice smooth ride.
  8. ShinerBTX
    ShinerBTX Junior Member
    Jacksonville, Fl.
    :rockon: I am now a firm beleiver in keeping the fronts at 40 and the rear at 38. I have had my Prius since 3/27/08 and this past weekend I checked the pressure of all 4 tires and they were closer to 32 psi all around. Not even close to the 35 psi per factory spec's. Had been averaging a best 48 mpg.
    Me and the wife took a 80 mile round trip from Plano TX to Denton TX to Camping World. Immediately once up on Hwy 380 W bound started seeing 50+ and at the 1/2 way mark 55.2. The wind was stiff yesterday coming directly toward us. Speed on average btw 55 and 60 mph. And if you all are familiar with N. Texas there are hill's on 380. So "YES" I am checking tire pressures at least monthly from here on out.:rockon:
  9. rpg51
    rpg51 Member
    200
    Vermont
    I'm running 50 48 on stock tires. The ride is great. The mileage is great. I'm happy.
  10. richard schumacher
    7,664
    1,045
    United States
    Do note that the max pressure given on the sidewalls of the OEM tires is 44 PSI. Higher pressure may increase the chances of a blowout.
  11. jamgolf
    jamgolf New Member
    22
    Southlake TX
    I have observed a 2-3 mpg increase in fuel economy by going to 42/40 psi.
  12. rpiereck
    289
    That's for the Base and Standard models 15" tires, the Touring has different 16" tires.
  13. etyler88
    etyler88 etyler88
    450
    Dover, DE
    I run about 60 psi all around. I have been doing it for two years. It adds about 4-5 mpg. FYI - low air pressure is more dangerous than high pressure.
  14. priusuk2008
    priusuk2008 New Member
    289
    CAMBRIDGESHIRE
    Do you know what the max pressure is for the 16" tires ?
  15. rwhoyle
    rwhoyle Member
    227
    Tulsa, Oklahoma
    rpiereck,
    Yes, the Touring has 16-inch tires, but Richard Schumacher is correct in that the side wall of the 16" Touring tire states "44 PSIG Max".
    priusuk2008,
    Please see above. Max pressure for the Touring 16-inch tires is 44 PSIG.
  16. priusuk2008
    289
    CAMBRIDGESHIRE
    Thanks for the info rwhoyle
  17. briansabeans
    briansabeans New Member
    53
    San Francisco
    I have the Touring and my side wall clearly reads "51 PSI Max." I will take a picture of it when I get a chance if you want. I didn't want to bump my tires up past the maximum, but when I saw 51 PSI max, I immediately put my Prius to 51 front and 49 rear. I'm thinking about bumping it higher since I do not think the ride is bumpier at all.
  18. rpiereck
    289
    Yep, mine says 51 psi max too.
  19. ystasino
    ystasino Active Member
    793
    Tucson, Arizona
    Top 6 factors that affect MPG in order
    1) Learning to accelerate at the efficient range of the engine
    2) To get the car into stage 4 where the engine shuts off immediately after lifting the foot of the pedal
    3) Tire pressure
    4) Route length and selection
    5) Avoiding rush hour
    6) Avoid using heating or cooling for city driving
    I am at 49.5 since Jan 13th (~5000 miles)
  20. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    I just attended a new owner's event at my dealership. The service manager stressed the importance of correct tire pressure and of a clean engine air filter, in attainment of the best mileage.
    Add proper driving techniques, low traffic roads and a stiff tail wind downhill and you have some pretty good numbers.
    ZC1
