Top Speed on the Electric Motor?
Discussion in 'Gen 2 Prius Main Forum' started by BubbaVO, Jan 29, 2008.
  1. BubbaVO
    BubbaVO New Member
    53
    Philly
    Again, you are mistaken. It is more efficient to accelerate using the gas engine, and use electric-only mode only for steady-speed driving on flat or downhill roads. The reason for this is that all the electricity drawn from the battery must be replaced later by running the gas engine.
    Lower-than-expected MPG are due to the unrealistic EPA testing procedures, though under ideal driving conditions and with the right technique, people (including some PriusChatters) have exceeded the EPA figures.
    Since I'm very much a newbie, I'm certainly willing to learn. I'll do a comparison over the next couple of weeks of the feathered acceleration I was talking about vs. the quicker acceleration and cruise to maintain. Not a perfect test since driving styles/traffic conditions/etc. aren't controlled for, but at least it'll give me a starting point.
    I drive 50 miles one way (40 miles stop - go- stop -go fast - stop driving and 10 miles of typical city driving). With the techniques I'm using, on a car with less than 1,000 miles, I averaged 48 mpg last week and this week just over 50 mpg. I couldn't be happier with my MPG. And if your technique is better, cool. This will be an interesting experiment.
    Just because I want to make sure we're on the same page. What's your definition of "efficient"?
    On the contrary! Since all the energy for the car ultimately comes from gas, you actually save gas by driving in a manner that minimizes the use of the electric motor. Situations where EV mode is more efficient are relatively limited."
    Not to be flip, the reasoning sounds like Costanza's girlfriend, "absence makes the heart grow fonder" so the more they're apart the more she likes him. Are you really saying that the electric motor is actually less fuel efficient? Following that rationale, should we be driving VW TDIs and forget about the hybrid concept? Built into car is a trade off of sorts - there's some fuel burned to get the electricity (with cruising and braking) at some point the trade off tips to the advantage of teh electrical and at others it tips to the gas. Or am I way off there, too. Again, I'm not trying to be flip, just trying to learn. I appreciate you sharing your experience and perspective.
  2. patsparks
    10,664
    567
    Adelaide South Australia
    Losses through the generator, inverter, battery, inverter and motor are much greater than through a few gears.
    Post 18 gives a brief overview of why HSD works.
    A very good Otto-cycle engine is about 20% efficient while the engine in a Prius is up to 40% efficient.
  3. BigJay
    BigJay reh reh REH reh Torture them!
    2,937
    554
    DFW
    This is good to know, I've been letting the car do that every chance that it gets.
  4. patsparks
    10,664
    567
    I should point out avoiding regen by driving up to red lights and stop signs on throttle then braking hard, or braking in neutral wont work, coasting to a stop or almost to a stop or avoiding stopping by timing traffic and traffic lights will help a lot.
  5. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Correct,
    Purely in terms of fuel efficiency, Friction braking is bad, Regenerative braking is better, No braking is best.
    Also, since most of the fuel is used to overcome friction and drag, the slower you drive the less fuel you use. There is a lower limit to this, but I think it is lower than 20 MPH.
  6. Danny Hamilton
    926
    94
    In more cases than many people realize, yes.
    This is true, and the car's computers do a pretty decent job of deciding which to use automattically for any given condition. People (hypermilers), who make extra efforts to learn what is best and when, can learn to outthink the car because they know what the terrain and driving environment ahead looks like and the car doesn't.
    Keep in mind that the car will operate in a less fuel efficent manner when it needs to for emmissions purposes and driver/passenger comfort. In particular, it will burn fuel to heat the catalytic convertor, to maintain operating temperature of the gasoline engine, and to supply the people in the car with heat as requested via the climate controls.
    Most of the fuel efficiency of the Prius is due to the use of the small atkinson cycle internal combustion engine (ICE). This engine uses fuel very efficiently and provides enough power for cruising a most legal speeds. However, the average car buyer would be so unsatisfied with the acceleration of the car, that few would be willing to buy it. A typical Otto cycle 1.5L DOHC ICE like in the Yaris provides about 106 hp. That's 39.5% more power than the highly efficient Atkinson cycle 1.5L DOHC ICE in the Prius which provides only 76 hp. 39.5% more power in a car that weighs 606 lbs (20%) less than the Prius. The Prius makes up for this shortcomming by adding in powerful electric motors (295 ft lbs torque, 67 hp) to fill in when the acceleration needs of the driver exceed the power available from the ICE.
    While it is inefficent to generate motive power just to turn around and convert it to electricity, and then convert that into chemical storage, which will later be converted again to electricity so that it can be converted back to motive power. . . . There are times when this is more efficient than running the ICE at RPMs that would otherwise be required to propel the car. Also, storing the energy that would otherwise be tossed away by the friction brakes is always more efficent. Storing even 0.1% of the energy lost to braking is better than losing 100% of it, and the Prius certainly does better than that. So when possible the car works to make sure there is enough power in the battery for likely extra power needs later.
    So the ICE is where most of the efficiency comes from, the electric motors make the car sellable, and once you've got those pieces, it isn't very difficult to pick up a bit more fuel savings by shutting the ICE off when the car isn't moving.
  7. drees
    drees Senior Member
    1,782
    247
    Peak fuel economy comes at 41 mpg in the Prius.
    A common pulse and glide speed range is 30-40 mph, though if there is any sort of traffic, this type of driving is not typically feasible.
  8. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
  9. patsparks
    10,664
    567
    Thanks Danny, that is just what I was trying to say but you did it so much better.
  10. drees
    drees Senior Member
    1,782
    247
  11. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    It's nice to see all this being talked about again. It's what the Prius is all about and understanding this stuff is the foundation for getting outstanding gas mileage, and attaining the original EPA estimates of 60MPG.
    Since those EPA numbers have been lowered, it seems everyone 's expectations have been lowered, people are missing what this car is really capapble of, and maybe don't know how to get it.
    Lowering the EPA numbers for the Prius was like the public schools lowering achedemic standards and adjusting test score curves, so the kids not willing to put forth the effort can pass too. Thus they never attain what they're capable of. SAD.
  12. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    That's the old one from the same author, Wayne.
    He revised it for more realistic one.
    Please read the thread again...
    http://priuschat.com/forums/fuel-economy/14675-most-efficient-speed-best-mpg-3.html#post186848
    Ken@Japan
  13. neukin
    neukin New Member
    IN
    Does anyone know the power of MG1 and then MG2? Im guessing the 67hp is both of the motors power combined? Just wondering
    Its been said MG1 cant run past 10K now. That means we can get to about 65mph running power to MG2 just electric before MG1 gets to 10K. I take it MG1 is making power spinning backwards at 9,000rpm?
