New 2008 Prius - BUZZZZER & Oil Economy
Discussion in 'Gen 2 Prius Accessories & Modifications' started by LenS, May 13, 2008.
  1. LenS
    LenS New Member
    S.E. Michigan
    I have a one week old 2008 Prius.
    1) the backup buzzer drives me crazy. Is there a procedure for turning it OFF?
    2) the owners manual talks about resetting the engine oil life but does not mention an "oil life monitor" to tell you % life remaining. I ASSUME the vehicle system terns on an idiot light when the vehicle calculates that the oil life is used up??
    I am sure '1" must have been discussed here many times.
  2. chrisspaulding
    chrisspaulding sexy, high tech, fun
    556
    24
    Kentucky
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    :welcome: Welcome to PriusChat, LenS! The beeps are easy to turn off, follow the link given or search here on PC. The Prius will flash a Maintenance Required light and screen warning every time you start the car starting around 4500 miles; it flashes and disappears. At 5000 miles it stops disappearing. That's the notice to take your car in for service, including changing the oil and oil filter.
    When the service is done, the service provider follows the procedure you read about in the manual to reset the light for the next 4500 miles. If you do your own service, you can reset the light too.
    There are lots of maintenance reminders you can set on the MFD, as well as a few personal reminders. Read up and play with the buttons!
  4. LenS
    LenS New Member
    S.E. Michigan
    Thanks Bill,
    It is now TURNED OFF!
  5. matts5280
    matts5280 New Member
    "There are lots of maintenance reminders you can set on the MFD, as well as a few personal reminders. Read up and play with the buttons!"
    Hey Bill can you elaborate on this? Or point me to any forum topics on it.
  6. qbee42
    3,081
    It's in the user manual.
