why service at 3000 intervals?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rangerdavid, May 19, 2008.
  1. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    I get the dealer to change my oil and filter. I'm at just over 36000 miles on my 2006 now. The last three or four oil changes I've been using (or at least requesting, and I hope they are using) fully synthetic oil.
    That being said, why do they still set the Maintenance required light to come on at 3000 miles? Is there any way, other than stand there and watch, to be sure they are installing the full synthetic oil? I've heard some folks on here and in Europe going 10000 miles on synthetic oil, so I figured I'd be safe to go at least 5000, if not 7000.
    Any tips, suggestions, or advice? TIA.
    David:D
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Strange on most Prius the light comes on at startup at about 4500 and goes steady at 5000 miles.
    Where did the 3000 mile service come from, Dealer installed option to get more business?
    Take 3 quarts of your favorite synthetic oil, have them add it and return the empties.
  3. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Search for posts by "Jayman". It's worth the effort. The short story is that American Oil standards are set by the oil companies and the European Oil Standards are set by the Car Companies. You can figure out which organization recommends changing the oil every month and which requires oil to preserve the car engine.
  4. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    That's the case on mine too and, I thought, on all US models.
  5. richard schumacher
    7,682
    1,064
    United States
    If you're doing everything the dealer wants you to do, and doing it every 3000 miles, you're getting hosed.
    Go get the Scheduled Maintenance Guide that came with your new Prius. Open it to the appropriate X miles/Y months page. Show it to the service writer and tell him to do what's on that page and *nothing else*. Be firm. Any maintenance items beyond that are a waste of money. (Of course if they find something that's broken and needs to be repaired, that's an additional matter.)
    5K service is basically an oil change. It should not cost much more than $30. I just had 30K service done at a dealer; doing only the Maintenance Guide items cost me $61. The same dealer's "30K service package" costs $199.
  6. aaf709
    3,862
    2022 Prius Prime
    If it does go off at 3,000 miles I'd just reset the reminder myself and wait until 6,000.
  7. pewd
    pewd Clarinet Dude
    331
    Dallas, Texas
    weird - i didn't know the computer could be changed to set it to 3000 mile intervals
    hm, ask the dealer to fix it to blink at 4500 and go on steady at 5000 like its supposed to?
  8. qbee42
    3,081
    And suggest that if they can't correctly set a simple reminder as recommended by Toyota, you will find somewhere else to take your business.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I wouldn't trust a dealer to empty my ashtray. And you don't seem to trust yours either.Why don't you buy your own Mobil 1 and oem filter and use a quickie joint. I do when I don't feel like doing it myself. You give them 3 quarts...stand there & watch them change the filter...4 minutes later your headed home to add the .5 and its a done deal.
  10. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I wasn't aware the maintenance reminder even had a setting to change. Just before 5,000 miles it should start nagging, not 3,000 miles
    Sounds like this dealership knows how to make money
  11. Patrick Wong
    18,210
    6,517
    I understand the nav system allows reminders to be set. Perhaps the OP is referring to a user-programmable reminder that appears in the MFD, instead of the MAINT REQD amber light in the combination meter.
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    Ah, I don't have Nav, didn't know that
  13. Bruce Nyhlen
    Bruce Nyhlen Junior Member
    24
    Grand Forks, ND
    I just had my oil changed a few hours ago by a shop near my work. The last change was by the dealer when I bought the car (05). I was about 490 shy of 5,000 miles and changed it because of a road trip this weekend.
    Will I be getting a warning light when I hit the 5,000 mark from the dealers change?
    If so, is there a way to disable this. The warning NAV I will reset for another 5000. I just don't need a warning light on the Dashboard going off and me thinking it's only the oil change warning.
  14. Patrick Wong
    18,210
    6,517
    Starting at 4,500 miles from the last time the MAINT REQD light timer was reset, the MAINT REQD light should blink for a few seconds each time you start the car. I suggest that you look for this, to confirm what I have written and so that you can see what the light looks like.
    Starting at 5,000 miles from the last time the timer was reset, the MAINT REQD light will turn on solid.
    If you want to reset the timer now, you need to set the odometer to show cumulative miles, not one of the trip odometers. Then turn the car to IG-OFF. Then hold the trip odometer button in while you make the car IG-ON. Continue holding the button while you watch a series of dashes across the odometer reading. When that activity stops, then the timer will be reset.
  15. Rangerdavid
    1,362
    52
    Three Touring
    so you went three years without changing the oil? I think perhaps that's a bit too long, even with syn oil............ how many miles were on that oil change?
  16. seasalsa
    1,278
    Kent, WA
    He said " I was about 490 shy of 5,000 miles"
    Now could you let us know where you get the 3000 mile oil change indication?
    Is it a reminder that shows on the MFD?
    Or is it the service reminder light near the speedometer?
  17. Bruce Nyhlen
    24
    Grand Forks, ND
    No, I went 4,500 some. I bought the car in Jan 08 Used, with 65,000 on it. It came with documentation that showed the 1st owner changed the oil with Moble one every 5,000 miles, give or take a few hundred.
  18. Rangerdavid
    1,362
    52
    Three Touring
    Hi! I'm talking about the light to the right of the READY light that (for me at least) comes on evert 3000 mi. and says "MAINT REQ"
    thanks!
    David
  19. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Yeah, that's weird.
    Rudy's Maint Req. light comes on 5000 miles after reset.
    Always follow the Maintenance Passport that SHOULD have been in the packet with the Owner's Manual. It states 5000 miles (US) between oil changes. Also lists whatever else should be done at each service interval.
    You, too, can reset your own Maint Req light.
