Gas-Sipper Smackdown at Edmunds: Prius vs. Smart Fortwo vs. Ford Focus vs. 05 VW Jetta TDI
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by cwerdna, May 22, 2008.
  1. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  2. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    In the 2 categories where Jetta TDI won (highway & backroads), the margin was narrow.
    In 2 that Prius won (city & fuel cost), the margin was extreme. The other (greenhouse) was narrow.
    Too bad there wasn't a SMOG emission category. That's another extreme advantage for Prius.
    Of course, what's the point of comparing a MANUAL transmission to Prius anyway? It would be far more appropriate using an automatic... but then, Prius would sweep every category.
  3. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    The Prius won the OVERALL over the TDI. Take notice.
    In Round 1, Driving up hills for prolonged time (see the photos) requires a lot of torque and power. (for those that think it takes power but not torque, shift your bicycle into a high gear and try riding uphill) The battery on the Prius would be exhausted, and the gasoline engine would be struggling. The diesel would be at home driving up hills.
    For Round 2, it's no surprise the Prius won. It's hybrid system is optimized for stop-and-go traffic. The engine even shuts off at stop lights.
    Round 3. For highway driving, I would think the engine with the lowest displacement (liters) would be the most efficient, since all it has to do is simply maintain speed. Any displacement beyond the minimum required to do that is wasted. That is a comparison when all cars are using the same fuel. The diesel won because diesel is more efficient.
    In an earlier thread, many people (including myself) assumed that because diesels have more carbons per molecule and black soot on their rear bumpers, they "must" also emit more CO2, but this article clearly stated "Greenhouse gases are not the visible pollution (called particulate matter) that can be seen chugging out of the Jetta's tailpipe."
  4. Tideland Prius
    16,634
    The video and the text don't match.
    "there's no overall winner..." says the video
    " The Toyota Prius was the overall winner, with victory in three rounds: best city roller, lowest fuel costs and greenest car." says the text
    huh?
    Btw, John, they ALWAYS use a manual Jetta TDI cause they want the max. advantage for the diesel. They did the same for Driving Televisions Hybrid Commuter Challenge. The Jetta TDI was a manual.
  5. JSH
    JSH Senior Member
    2,605
    140
    PDX
    I guess that is one way of looking at it. What I noticed was the HUGE difference between EPA mileage and actual mileage for the TDI. The EPA rates the '05 5 speed TDI @ 30/39. Edmund's got 47 mpg on backroads and 48.9 mpg on the highway @ 75 mph. That is 20.5% and 25.4% better than EPA respectively. It even beat the EPA in the city by 5.2%.
    Why use a manual? Because the object was to get the best fuel economy and that is what they had. VW also sold a lot of 5 speeds mated to TDI's. The auto is only rated 1 mph worse than the manual. (30/38 vs 31/39)
  6. john1701a
    12,840
    5,311
    58
    I thought being objective was to make comparisons as similar as possible.
    Also, keep in mind how much more efficiency can vary when manual shifting is involved.
  7. qbee42
    3,081
    How do you suppose they measured mileage given the uncertainty of the Prius gas tank?
  8. JSH
    JSH Senior Member
    2,605
    140
    PDX
    If the object was to be as similar as possible why include the Smart fortwo at all?
    Why compare a 5-person coupe, 5-person hatch, 2-person hatch, and a 5-person sedan?
    Why use a CVT, Auto, Manual, and clutchless manual?
    Why compare a hybrid, turbo gas, turbo diesel, NA gas?
    Why ask Why?
    I prefer a manual so I don't see a CVT or automatic as being a positive feature. I bought my Prius in spite of it having a CVT and because I couldn't find a Civic Hybrid within 500 miles.
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    it was not to compare similar cars... it was looking at the cheapest way to get around. storage, passenger comfort, legroom, etc...not part of the equation.
    i like the line "The Prius... if you have the money.
    price a TDI jetta lately??? how much money do you save by buying one of them??... not much
  10. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Regular Unleaded-$4.15
    Diesel-$5.00
    which is cheaper now.....? hmmmmmm
  11. Jonnycat26
    Jonnycat26 New Member
    1,748
    New Brunswick, NJ
    Actually, as John knows (but will never point out) the DSG Auto TDI cars get better mileage than the manuals. SO using a manual TDI was putting the TDI at a bit of a disadvantage.
  12. john1701a
    12,840
    5,311
    58
    Wasn't the reason for this to provide data just like that?
    All transmissions have peaks & lows. With it, I could have pointed them out. But they didn't use it. Why?
    Do you have data to support your claim?
  13. Jonnycat26
    1,748
    New Brunswick, NJ
    Just those pesky EPA ratings, which I've sent you before.
  14. john1701a
    12,840
    5,311
    58
    Well, then there's no contest. A minor bump is still not enough.
    Of course, we all know estimates are never as good as real-world.
  15. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    i bet prius could have won out on top in all categories had they chosen to use a non-touring model
  16. Jonnycat26
    1,748
    New Brunswick, NJ
    Dude... I mean, come on.
    I was just pointing out that the manual is not as efficient as the manual, which is what people were saying.
  17. david81
    david81 New Member
    62
    NE Ohio
    I'd be more concerned with the driving styles of the different drivers. We picked up our 08 Touring on Valentines Day and we are currently averaging a bit over 58 MPG. I expect this to climb to around 60 once the weather here in NE Ohio decides to get with it and stay warm for more than a couple hours.
    The differences between Touring and non-Touring just don't effect mileage all that much.
    David
  18. Tideland Prius
    16,634
    I think DSG official mpgs are close to the manual, if not equal. I'm not sure if they're better. (I do not know how different the EPA ratings are esp. with the new ratings).
    But a manual done right can improve fuel economy. Two of my friends have a TSX - one auto, one manual. According to Transport Canada, the manual gets a lot worse mileage than the auto (no idea why.. short gear ratios?).
    Real life, the friend with the manual gets a lot better mileage than the rating and a good chunk (nearly 1.5L/100km) better than the auto friend.
  19. F8L
    19,011
    4,083
    Grass Valley, CA.
    The "soot" is generally considered particulates (PMs) and aerosols (PMs and gas together) correct? Quite different than greenhouse gasses in their effects on our health and local environments. Diesels definately put out more of those than does a gasoline vehicle although one should not discount the fact that particulate size has decreased overall with catalytic converters. This could be deemed even worse than the large particles since they remain airborn longer and are more easily driven through the respitory system (similar to the problems with nanotechnology). Any better info on this? I'm not well served in anatomy. :confused:
  20. allargon
    allargon Member
    113
    Austin, TX
    Wow... my touring never broke 45mpg/tank until I hit 20k miles on the odometer.
