Any Zerk fittings on this vehicle?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ZC1, May 24, 2008.
  1. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Wondering if anyone knows of any zerk fittings on the carriage side of this vehicle?
    For those who are thinking, what did he say?
    A zerk fitting is a small protruding lubrication nipple that accepts grease from a grease gun. A grease gun looks like a caulking gun except it is full of lubricating grease.
    Anyways, zerk fittings allow you to add grease to U-Joints, bearings, sleeves, and other pivot type points, which is usually done on a regular basis as part of a maintenance plan.
    I haven't crawled under the vehicle to check, so anyone know?
    ZC1
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    No. But I do periodically spray some lube on all moving suspension parts up front. Door locks...door hinges..etc. Just be careful none hits the front disc's.
  3. tochatihu
    tochatihu Senior Member
    9,844
    3,805
    Kunming Yunnan China
    2001 Prius
    Prius...Zerk-free since 1997
    However we still read of Toyota shops charging for chassis lubrication in packaged service, once in a while. I wish they wouldn't do that.
    Minimal underbody maintenance is look at the CV and steering boots. Better, to check conditions of braking, suspension and steering. Various bolts are to be re-torqued after severe vehicle use, but I never managed to rattle any of them loose. Not for lack of trying...
  4. rpiereck
    rpiereck Regenerator
    289
    Greasing lube points is so old school. I don't expect a Prius to have any, all our pivot points should be greaseless. I know that if you lubricate greaseless joints you can actually damage the fitting, I would put anything that Toyota doesn't specify.
  5. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    really the only zerk fittings on toyotas are on the driveline, and only in the trucks.
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I've searched 4 years now, have yet to find a zerk
    My FJ has them on the front and rear driveshaft. Oddly enough, it does *not* have zerks on the balljoints or tie rod ends.
  7. qbee42
    3,079
    I've seen some on the road, but almost never in a Prius. Oh, you said zerk. I thought you said jerk.
  8. ZC1
    711
    Metro Detroit
    Tom! :p
  9. woodnowin
    woodnowin Junior Member
    Suffolk, Virginia
    I found one. But, what is it for?
    Remove the plastic cover covering the radiator frame and you will find one on a bracket just in front of the inverter. It has a rubber dust cover on it and a hose that disappears beneath the inverter. This is on a 2005. I'm digging through the service manual but I haven't found it yet. I can't stand it. What is it for? What is it for?
  10. Patrick Wong
    18,210
    6,511
    That is not a zerk fitting.
    That is the vent used when purging air out of the inverter/transaxle coolant loop. Look for a repair manual section regarding how to replace that coolant.
    If you start injecting multipurpose grease into that vent, your inverter will not be happy... Rest assured that there are no Prius fittings that require an injection of grease.
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    :doh:
    Please, please tell me you didn't hook a grease gun up to it
    The part in question is for bleeding air out of the cooling system. It's documented in the shop manual
  12. qbee42
    3,079
    Not anymore...
  13. woodnowin
    Suffolk, Virginia
    Man o man, 3 cartridges of grease and I still can't fill it up.
    Just kidding. I get what It's for now. Same kind of fitting as a brake bleeder. Thanks for the info.
  14. patsparks
    10,664
    567
    Adelaide South Australia
    I had a customer when I was mechanicing who was greasing the front end on his old Cortina when he saw the "grease nipples" on the back of the brake callipers. He was unsure why he couldn't get any grease into them so replaced them with new grease nipples and in went the grease. He bought the car to us for a service. I saw the grease nipples in the callipers and rang the customer to ask what was going on and quote required repairs.
    I can't remember what it cost to replace all the seals and clean up the callipers and master cylinder, we also replaced the flexible brake hoses on the front brakes. Thankfully he didn't find the "grease nipples" on the back brakes.
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    Days like that, only a good stiff drink helps at all ...
  16. richard schumacher
    7,664
    1,046
    United States
    "A little learning is a dangerous thing." - Alexander Pope
