2005 Prius: New Michelins--mileage took a nose dive!
Discussion in 'Gen 2 Prius Fuel Economy' started by gawilson, May 24, 2008.
  1. gawilson
    gawilson New Member
    The Goodyear Integrity tires that came with my car had to be replaced at about 20,000 miles and a replacement set lasted about the same or less. I decided to go with Michelin Hydroedge based on long life but I never counted on losing 7-8 mpg in the process!
    I'm told that this is the reason by the Toyota dealership but I truly question this. I wonder if something is going on in the hybrid system, i.e. electric motor failing to engage properly resulting in the gasoline engine doing most of the work or the battery not performing normally. Toyota won't check the battery or hybrid system at all unless a "light" is on in the dashboard. I also wonder if the number of miles requires a greater warmup time and thus more use of gasoline vs electric. I have also had the misfortune for a few wildlife "encounters"--deer hit me! I don't think that any of this would have adversely affected the aerodynamics but at this point I'm grasping at straws. I was getting 56-7 mpg's consistently on my drive to work and a bit better than that at times. It has dropped to 48-49 although I got 51 on my last tank.
    Has anyone had a similar problem? It looks like when this happens all of a sudden, or in the case of a few folks that I've read on this blog where they're just not getting anything close to the manufactures ratings on mileage, that Toyota should double-check the hybrid system as well as the battery. Could they have this policy to insure that no battery problems are discovered before the warranty runs out?
    greg
    [email protected] I'm on dialup-ugh, so if you have a definitive answer or suggestion, feel free to email me.
  2. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Does the car have any alignment issues? Like pulling when driving or braking?
    Did you change gas stations?
    I wonder if the winter gas vs. the summer gas has anything to do with it?
    ZC1
    (of course, it could all be due to tire rolling resistance)
  3. brick
    brick Active Member
    1,083
    79
    Upstate NY
    New tires take a little while to wear-in, and mileage improves a little after that. But you don't say anything about tire pressure. How is yours set? You want those things nice and hard far the best mileage and longevity, with 42/40 or 44/42 being common recommendations around here.
    The other thing that strikes me is that your integritys only lasted 20k. I know it's a lousy tire, but what happened to them? Mine have loads of life left at 27k, albeit having been inflated above 40psi since the beginning. If the edges rounded off, that is a symptom of having had too little pressure.
    Please check pressures and get back to us. Best to take care of this now so that your new tires last!
  4. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    That's normal.
    My new HydroEdges have 4,500 miles on them now. That new tread combined with unseasonably cold weather kept me from cracking 50 MPG until yesterday.
    Break-In is a pain. But fortunately, you don't have to worry about it again for another 70,000 miles.
  5. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Pretty much the same thing here when I put Hydroedges on last year. I estimated a 5-10% hit to fuel economy. I'm certain I've regained some of that now with 15K miles on the tires, but probably not all of it. The Integritys apparently are still somewhat lower in rolling resistance.
  6. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi gawilson,
    When you first got the car, your mileage increased the first 6 months you had it, I presume. Allot of that was engine break-in, but some was tire break-in. The tread edges wear down, and the sidewalls get more compliant. Take a new uninflated tire and flex the sidewalls. Then do the same thing with a worn out tire. You will notice quite a difference. That means, when each sidewall flexes the same amount, the worn out tire generates less heat in the rubber.
    The Hydroedges make allot of noise when new. That is the factory siped (all those extra edges built into the tread). Over time the siping edges will feather in to the roll of the tire. And only come out to play when you put allot of force on the tread.
    I am running Hydroedges, and they are 2 years old in June (about 24 K miles). My last suburban/combined driving tank was at 63 mpg. Summer traffic and construction helped allot with that though.
  7. VaPrius
    VaPrius New Member
    150
    Virginia Beach
    I put those same tires on my Prisu a couple months ago. I haven't noticed any mileage problems but my last set were almost bald. Plus the weather has been changing so frequently in my area any MPG hit has been due to that (I think).
  8. gawilson
    gawilson New Member
    On the integrity tires, i just went with the manufacturers suggestions on tire pressure but on my Hydroedges, i run 42/40. My prius has about 75,000 miles on it and the hydroedges are well past break-in--i haven't noticed a real change yet. Weather does play a big role and i think that's due in no small part to air resistance overall, i.e. less humid is worse.
    One person suggested that i check into the ethanol blend of the gas in my area and i'll do that--seems to be a good possibility. However, I still wonder about the overall hybrid system as the car ages, i.e. old cars run a bit colder than new cars and this could cause the gas engine to run a bit more to warm things up. I also wonder about how effectively the car is switching from gas to electric mode and whether the battery is performing up to par.
    I think it's disgusting that Toyota won't check this without a warning dashboard light. Thanks for all the suggestions. Oh, it's been realigned several times in the past so I don't think that's an issue and even when it was out of alignment, the mileage didn't suffer--it was in the prior ranges I'd mentioned. Also, i did check out rolling resistance numbers prior to installation of the hydroedges and didn't notice that much difference. I notice it now though and it makes sense that it would be higher--this tire is guaranteed to last!
    greg
  9. john1701a
    12,797
    5,280
    57
    That's the basis of your complaint?
  10. F8L
    19,011
    4,083
    Grass Valley, CA.
    Where did you get RR #s for the Hydroedges?
    I spoke to a customer care individual at Michelin yesterday and she said the Hydroedges are an efficient tire but they are not recomended for my area because of a lack of rain, it is a rain tire afterall. She said their most energy efficient tire is the Energy series tires like the Energy MXV4. It seems like she was just reading literature though so I am going to take her advice with a grain of salt.
    Michelin on RR
    What ever happened to the Proxima?
  11. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    I not only purchased the Hydroedge tires, but i did so just prior to winter setting in. My mileage was horrible!!! I mean, I was in the low 40's almost all winter.
    Not only did I get the hydroegde, but I got a size wider which really will affect you mileage. It has added some lateral stability though. One of our moderators here recommended I increase my air pressure and I did so, and now that spring has set in, my mileage is up again to 52-53 on the last two tanks.
    So here are my recommendations. Increase your tire pressure to 50 front - 48 rear. Trust me. You will see an immediate increase in you mileage. My tire guy at Costco also has a Prius with hydroedges, and he runs that pressure too. Fill up the tank, and see if your mileage doesn't return to your prior levels, or quite close.
    The hydroedge is a great tire, and as said above, there is a break in period, which I found for these tires to be around 4000-5000 miles. But the tires last forever. the ride at those pressures is not too harsh.
    Good luck.
    David
  12. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    I wonder what made you buy hydroedges instead of energy mx4's? Im only at 4K miles but am planning and am curious.
  13. brick
    brick Active Member
    1,083
    79
    Upstate NY
    I thought Michelin killed the Energy tire line and was supposed to introduce a replacement LRR tire? Did I get that wrong?
  14. Sheepdog
    1,125
    Sanford FLorida
  15. gawilson
    gawilson New Member
    Thanks for all the info and just a quick note: I'm not complaining---just trying to find an answer. I want to know "why".
    I may check into the Proxima and the other low RR tires but I do like not having to change tires so frequently so...I may stay with what I have. I do think the Integrity tires would have been ok had the dealership aligned the vehicle properly.
    I do wish to reiterate my initial statement: I think Toyota should check a vehicle when there is a radical change or sub-par performance for a properly functioning hybrid system including the battery. Having to wait for a dashboard light, and one that may never come on, is ridiculous.
    greg
  16. FishHawk
    FishHawk New Member
    176
    So maybe you should stick with the OEM tires and get the best mileage. Yes , people think they are not great tires but there doesnt seem to be a tire out there that comes close to the mileage the OEM tires get.
    With gas prices rising everyday it's a choice we all have to make when replacing our tires. FishHawk
