Dead Battery
Discussion in 'Gen 2 Prius Technical Discussion' started by stevejamie, May 26, 2008.
  1. stevejamie
    stevejamie New Member
    Maricopa, AZ
    Every time I wash my car and after it sits for a few hours, the car does not start, it is dead. Thes last time my computer screen did not come on so I had to place my battery charger on the car. After a few minutes the computer screen came on and the car started. I only experience this after I washed my car. Has anyone else experienced this? I have not taken it to the dealer yet because I'm not sure what to tell them.
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Welcome to PriusChat!
    Do you leave the car in ACC or IG-ON mode?
    There have been reports of draining the 12v battery if you do not press the brake while pressing the power button.
  3. richard schumacher
    7,680
    1,060
    United States
    What seasalsa wrote. Turn the car OFF while you wash it. Locking the car will tell you whether it is actually OFF: if it is not, or if you left a light on or a door or the hatch open, it will give a long warning beep.
  4. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    I didn't know that. Thanks Richard.
    ZC1
  5. richard schumacher
    7,680
    1,060
    United States
    You're welcome. I *always* lock it, including when parking in the garage at home; this has saved my battery twice. Killing the battery would be annoying no matter where it happens.
  6. qbee42
    3,081
    I do the same, and I live in an area where no one locks cars. It's a simple test to make sure the doors are shut.
  7. stevejamie
    Maricopa, AZ
    Thanks for the information. I only had my car a few weeks and still getting use to the "no key" thing. The next time I wash my car I will lock it to make sure everything is off and see what happens.
  8. racerbob
    racerbob Member
    138
    S Florida
    If that problem persists, get your dealer to load test the 12v battery. Poor maintenance during storage by the dealer has caused many discharged batteries. A battery that has been discharged often will not fully recover.
  9. taxachusetts
    taxachusetts Junior Member
    39
    Boston
    Does anyone know what the ampere-hour rating is of the 12V battery? It sounds like it has the power of two rechargeable AA batteries.
  10. Chuck41
    Chuck41 New Member
    Midwest
    I read a post that the 12 volt battery was 20 AH
  11. Patrick Wong
    18,210
    6,514
    If you have a Classic, or a 2G without Smart Entry/Smart Start, then the AH rating of the battery is 28. If you have a 2G with SE/SS then the AH rating is somewhere in the low 30s.
